Technical => Engine Tech => Topic started by: the_intimidator03 on January 10, 2009, 10:36:29 PM
Title: Oil idiot light acting...well like an idiot
Post by: the_intimidator03 on January 10, 2009, 10:36:29 PM
Well on my 86 5.0 cougar there is a sensor just forward and above from the oil filter on drivers side.  it was leaking just under the nut below the 1 wire connector.  what the sensor is i dunno exactly but i had the guy at the parts house look at it and grab one for me.  I just did an oil/filter change and changed the sensor out.  now every time i fire the car up the idiot light stays on constant lol  what gives?!?
Post by: Chuck W on January 10, 2009, 10:42:46 PM
Wrong or bad sensor?
That is the oil light switch.  It's not a sensor or sender.  If he grabbed you one for a gauge instead of a light, it will be the wrong one.
Post by: daminc on January 10, 2009, 10:48:50 PM
or there's low pressure and the light works
Post by: the_intimidator03 on January 10, 2009, 11:12:47 PM
ok... i just checked the part number from Niehoff.  shows up Oil Pressure Gauge Sender,  application for thunderbird 88-81  and cougar 88-85
guess i better get another one?  or install an electric gauge?
