Technical => Drivetrain Tech => Topic started by: Thunder Chicken on December 28, 2008, 01:58:00 PM
Title: Pressure plate question...
Post by: Thunder Chicken on December 28, 2008, 01:58:00 PM
...Or rather, pressure plate bolt question...
I was out in the garage working on the AOD-T5 swap. Got the pedals in, got the exhaust unbolted (that was a treat - thank God for torches), got the old tranny out, got the pilot bearing in the crank, bolted on the flywheel, and even made up a clutch alignment tool (by modifying one I'd made for my old Nissan truck). I was hoping to have the T5 tranny bolted in today, but hit a snag that is preventing this: The guy I bought the engine and tranny from did not include the pressure-plate-to-flywheel bolts.
D'oh!
Ok, so I grab the bolt bin, drag it under the car, and start trying to screw random sizes in. None of my SAE stuff would go in more than a turn or two (by hand). Knowing it's a mid 80's Ford I figure the holes might be Metric, so I start rooting through my Chicken Parts drawer for bolts. I find a few that look close, so under the car I go with 'em. The first one I tried threaded right in. Out comes the thread pitch gauge, and by all appearances it's a M8X1.25. This leads me to my question: Are the pressure plate bolts metric? Flywheel is an E6 part if that matters...
Post by: Thunder Chicken on December 28, 2008, 02:04:52 PM
Nevermind, I googled it. The bolts are indeed metric, 8X1.25. Looks like I'll have to hit the bolt store tomorrow...
Post by: Jim_Miller on December 28, 2008, 02:40:07 PM
Also they may not be just ANY 8X1.25 metric.
The ones in my 70 Stick had a real low profile head on them, I believe it was for clearance for the fingers on the PP. I would suggest sourcing these direct from ford, they couldn’t be much more $. Consider the cost in labor if you have to pull it all back out and change them.
Post by: shame302 on December 28, 2008, 02:44:07 PM
i would source them from ford. i remember having the same trouble. i thought they were a tapered thread or something stupid like that. regardless, id get them new from ford. the good news all the hard stuff is done ;o) its weird driving it the first time after the 5 speed conversion!
Post by: Thunder Chicken on December 28, 2008, 03:08:32 PM
Quote from: Jim_Miller;249107
The bolts go on the outside of the pressure plate housing, so clearing the fingers on the PP will not be an issue. I think you're thinking about the flywheel-to-crank bolts. I did use the factory bolts for that (I even used the proper ones for the 5-speed - they're slightly longer than the automatic ones).
Quote from: shame302;249108
Still gonna have to wait to drive it, at least until April or so. After all the bodywork I will never let salt anywhere near this car again. I did get sort of a preview with the parts TC the one time I drove it, though :hick:
I'll look into factory Ford parts, but when I googled it I read nightmares about Ford dealerships charging $8 per bolt. Given we get gouged for everything from dealerships in Nova Scotia (little competition, so they charge what they want - in fact they'd probably try to sell me a whole pressure plate to get the bolts) I'll probably end up getting some grade 8.8 or stronger metric bolts from the bolt store (it's a huge store in an industrial park that sells nothing but bolts).
Post by: Jim_Miller on December 29, 2008, 05:18:05 PM
Quote from: Thunder Chicken;249117
You are correct, my bad! I missed it in your first message where you very clearly stated....
Post by: 5.0 tbird on December 29, 2008, 07:11:23 PM
I got mine from Lowe's. Just make sure you get grade 8+, and use lockwashers.
Post by: Tbird232ci on December 30, 2008, 02:56:07 PM
I paid 13 plus shipping for mine. Ford racing part.
Post by: Thunder Chicken on December 30, 2008, 03:20:41 PM
Just got back from the city. I picked up eight grade 10.9 8X1.25-20 bolts and 8 lock washers for $3. I know I only needed 6 bolts & washers, but since there was a $3 minium charge I picked up a few extra. The tranny will be in the car tomorrow.
:D :D :D :D :D
