not sure what years will work, but I just looked at mine and they have several dents in them and I would rather just get another set.I need all four thanks.
Are those pieces from the body (right ahead of the quarter windows) and from the doors? If so, we may have pieces from the body. Also if so, how did you get them off of the doors w/o wrecking them?
very strong fingers lol, you have to pull back towards the rear of the car for the front ones. the back ones 3 screws and snap clips on the window
Yeah, I've pulled the back ones off before, but have never had amy luck getting the door pieces off. Maybe I need to heat them, so the adhesive softens up. Anyway, I plan to start stripping another 87/88 TC over Christmas. I will see what I can do on the trim for you.
They have clips on the 86' maybe the 87-88 are different
Geez, I need to pay attention. We only have 87/88 TC parts, so I "assumed" 87/88. I don't know if they're interchangeable, but I'll still see what I can come up with.
87 has trim adhesive
http://www.foxtbirdcougarforums.com/showthread.php?t=20802 (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=20802")
bump
There is an 83-84 Bird at the yard. Ill look fo you this weekend. I have a feeling they are dented
bump
I got 88's,
