NEED PICs of 86 5.0 Engine
Anybody got any detailed engine pics? I need some top shots from both sides and all angles...I have a few brackets waiting to go on that I forgot where they go. Thanks!
Rick
I don't have A/C anymore, but everything else bolts up the same.
and one more From the other side: If you need something specific lemme know
thanks! is yours different than mine? My ac compressor is on the top side of the drivers side bracket...the one that holds the power steering too. There are rod like brackets that bolt to the brackets that hold the accessories...got any pis of them?
Rick
My A/C is gone. I took it out and put in The Ford A/C eliminator bracket and a power steering Bracket from a mustang (The power steering bracket on our cats and birds is different and will not work with the eliminator.) As ar as the rods they went from the back of the A/C down to the power steering bracket if I remember correctly. I don't have any pics of those. Master Blaster has some perhaps? :dunno:
Anyhow here's a couple more that might help
Thanks!
Hey Paul, what size belt you running?? (sorry for the hijack) ;)
Why does everyone assume that *I* would have... oh, that's right.
Never mind. :hick:
Just a few pics I took after work (1am).
thanks!!! I got it now!
That's right.... You NEVER have pics of stuff...... :rollin:
EDIT: Cougarman, the belt is Dayco part# 5060875. All pulleys are stock size.
anybody got the belt size for when you delete the smog pump? Its gone, and nothing is there to replace it....
