My newest project is a 86 bronco II. Seeing how I'm going to college soon and going to be driving back and fourth to and from Fort Wayne to Indianapolis on the weekends.... I needed somthing that would get decent mileage and be fun as hell to drive at the same time. Well, I got this from a buddy. It needs a new 2.9L and some brake lines but other than that its a pretty set little toy
4wd 4speed with buckets and lockouts. yeah!
(http://i18.photobucket.com/albums/b150/Tcj429/bronco001.jpg)
(http://i18.photobucket.com/albums/b150/Tcj429/bronco002.jpg)
(http://i18.photobucket.com/albums/b150/Tcj429/bronco003.jpg)
(http://i18.photobucket.com/albums/b150/Tcj429/bronco004.jpg)
(http://i18.photobucket.com/albums/b150/Tcj429/bronco005.jpg)
anybody got a good running 2.9 layin around? ill gladly take it off your hands :D
sweet! Should be a fun toy.
yeah, and all i gotta do is rebuild the motor.... (joy)
throw in a sho motor and carb it.
There are two bothers here by myself and they both had Bronco II's that had slight lifts and were really clean!! They drove the shiznit outta them things!! Good little trucks, I had to have a fullsize when I got mine :D At least you wont get 5 or 6 mpg :D
awesome little ride you got there!
update... the 2.9 has 1 bent rod....and had about a gallon of river water in the oil
easy fix
...is that...is that good?
Decent mileage? Lol I hope 15 mpg is decent to you :)
you should just put a 2.3 in it...
Sheeeeit! throw a stock HO and a 5 speed in 'er and rock and roll and get 18mpg!
Doesn't take a lot...
all i need is a piston rod, bearings and gasket set and im good to go
good deal!!
still waiting on my connecting rod and piston. but the other 5 are re-ringed and re bearinged.
soon as i get tht other piston and rod... its on like donkey kong... even tho i have to send out another $100 for heads and exhaust manifolds... mine are fubard.
Shes Commin along nicely.
the bottom end of the deuce is back together now. new rod, piston bearings, oil pump 60$ OUCH, waterpump, and gaskets.
As soon as I get my heads and exhaust manifolds she should be back up and running. but before then Ive gotta buy Oil a filter and coolant.
