Technical => Drivetrain Tech => Topic started by: 20thanniver-ls on November 16, 2008, 10:33:17 PM
Title: clutch problems
Post by: 20thanniver-ls on November 16, 2008, 10:33:17 PM
i have a problem with my clutch, im pretty sure it is going out, but not totally sure ill have to replace the whole thing. It goes into gear fine, it will shift through the gears with no problem, however, when i get on the throttle a little more than normal:evilgrin: the clutch slips a little then grabs again. Should i have to replace the whole clutch, or just the plate, dont know much about repairing them so im kinda clueless, any suggestions?
Post by: 5.0 tbird on November 16, 2008, 10:40:06 PM
You should at least replace the pressure plate, clutch disc, throwout bearing, and have the flywheel resurfaced. I would recommend replacing the pilot bearing as well since you're right there.
So really just buy a clutch kit and have the flywheel resurfaced. :hick:
Post by: 20thanniver-ls on November 16, 2008, 10:44:10 PM
:toilet: that sux
Post by: 20thanniver-ls on November 16, 2008, 10:47:26 PM
and sounds pretty expensive
Post by: vinnietbird on November 16, 2008, 11:12:48 PM
It depends on what kind of clutch kit you buy as to the cost.If you want expensive,they are out there.If you're on a pretty tight budget,get a clutch kit from Autozone for less than a hundred bucks,and,it has a lifetime warranty.I had my flywheel done and my driveshaft balanced at the same time,cost me $50.00,so the surfacing couldn't have been too much.
Post by: Cougar5.0 on November 16, 2008, 11:23:45 PM
In the end you save money by doing it right. A properly set up clutch with resurfaced flywheel will last for many years.
Post by: Turbo 88 on November 16, 2008, 11:52:16 PM
Ain't it the truth. The TC I bought it a replacement for my GF's that croaked at 327,000....STILL with it's original clutch.
Obviously she doesn't drive like I do
Post by: 20thanniver-ls on November 25, 2008, 08:05:45 PM
well this car is my daily driver ( its actually a '90 toyota :rice: :makefun: :toilet: ) and was wondering if you had to pull the tranny and the motor to replace the clutch - if anyone knows? It is front wheel and the manual says u have to but i was wondering if anyone knew another way around it?
Post by: 88turbo on November 25, 2008, 09:10:42 PM
should be able to drop your tranny to get to the clutch. as far as resurfacing you should be able to get it done at your local parts store on their brake lathe.
Post by: 20thanniver-ls on November 25, 2008, 09:25:45 PM
what would i be resurfacing? ive never messed with a clutch - i know the whole clutch isnt gone really just the pressure plate and if i had the money i would replace the whole setup but im trying to get away with just the plate - i really dont want to dump a whole lot of money into the car ( much rather put my money in a cougar lol) i know i can get the presure plate at autozone for like 40 bucks is there anythin else i should have to replace with that like bearings or anything? Your help is very much appreciated.
