im looking at getting a set of rear upper and lower control arms. i would like a solid upper set like the jegster brand, and somethink like the granatelli designed ones that i can adjust the lower spring pad height to set preload/ ride height. ive asked jegs, summit and granatelli, and they all cant give me a straight answer, will the upper and lower control arms for a fox body mustang fit under a t-bird?? also as far as the ones with heim (SP??) joints in it are those better for stuff like drag launches, and/or corner as to keep the rear end from binding as the rear end rolls or squats?? sorry im a noob and i did a few minutes of searching but couldnt find a definative anser
No, Mustang RCA's are different than Tbird/Cougar ones, especially the uppers.
CHE makes Tbird-specific RCAs.
thanks for the reply. but which is all around better and still durable. adjustable or fixed ends??
Heims are not really good for a DD as they transmit a lot of noise thru the car. Depends on your tolerance of that kind of stuff I guess.
On my drag project, it has rod ends on all of the RCA's. On my DD/ weekend strip warrior, I just ordered uppers and lowers with the urethane ends and am replacing the upper axle bushings with spherical bearings-trying to get my 60' times lower than 1.67.
Adjustable is good for setting pinion angle (uppers) or adjusting ride height (lowers). HTH.
I'm running the CHE lower w/adj. perch & upper arms on my Cougar. The ride is decent for the street, yet they are quite firm for drag-racing. This year I was running 1.5x 60' times with this setup - launches straight as an arrow. And I'm dumping the clutch @6000 RPM on these launches.
CHE Products (http://"http://www.cheperformance.com/cartgenie/prodList.asp?scat=30")
(http://i43.photobucket.com/albums/e360/Domeskull/DSCF1250.jpg)
(http://www.cheperformance.com/cartgenie/images/large/CHE1G.gif)
(http://www.cheperformance.com/cartgenie/images/large/BLK2A.jpg)
You can get heim joint adjustable uppers from CHE if you don't mind the harsher ride and absolutely need adjustability.
(http://www.cheperformance.com/cartgenie/images/large/CHE2B_C.jpg)
look here for the exact differances
http://foxtbirdcougarforums.com/showthread.php?t=14683&highlight=mustang+control+arms
