I know, I know, this can be almost impossible to find, and describe in a thread. But my thinking is that maybe, just maybe somebody has had the a similar issue.
Ok, ever since I had a 351 put in my car, I have something in my dash vibrating under higher RPMs. It only happens right before it shifts to second at around 34 mph.... and then as it shifts to third.
It is a loud buzzing vibration coming from I think somewhere behind the digital dash, up top, and toward the middle of the dash. It sounds like plastic vibrating together... (I realize this is vague)
I have had all of my molding off and drove around. I did not take the digital dash out, becasue there is this white tube attached to the bottom of it that I'm not real sure what it is for.
Anyway, any suggestions would be GREAT.
you pulled out the speaker grills yet? there is also a plastic cover that goes under the sterring colum and the fuse box as well.
Yep, pulled the speaker grills, but did not pull speakers. But the sound seems to be coming from toward the top of the dash, to the left of that square piece in the center that is removable. However when I take that out, the clock out, and feel back in between the vents, etc., the vibration seems to be somewhere to the left of that, sort of behind the digital spedo.
I am not sure how to get that spedo out of there...becasue of not knowing what that small tube. That should probably be my next project.
It's not a small noise either.... very distinct....
It is definately inside of the dash, and cannot be stopped by pushing on the top of the dash or by sticking my fingers in the vents...
arrrggghhhh
my dash is almost completely out, and its an 88, ill take a look and see if anything behind the cluster can vibrate... i also dont know how different they are from 85 to 88...
Could the engine/trans be making contact?
I'll take a look, thanks for the suggestion.
the white tube is a cable that moves your shift indicator from p to r, n, 1, 2 ect.
You disconnect it up in your cluster, its just a loop on the cluster end that you pop off.
I'd check out your suspension. We had something similar happen in a work truck allthe time, to the extent everyone thought it was normal. A couple of months later it wouldn't stop making the noise, and it ended up being a bad wheel berring.
Thanks. I appreciate that. Now I will not be afraid to take it out.
The suspension is all new. Everything in the front and rear is new. Springs, etc.
Thanks for the suggestion. I'll keep looking.
I think once I get the cluster out I can get my hand back in there and figure it out.
Keep the suggestions, coming, however. I really appreciate them!
Sounds kinda dumb, but the check the trim around the windshield. I had a similar problem recently and it turned out I was missing a screw near the top where the door closes. It took MONTHS for me to figure out wtf was going on.
I'll give it a look, thanks.
