Will a 8.8 out of a newer mustang fit my 85 t-bird? If so what year is the cut off?
newer means what?
welcome to the board. As you decide you have questions, make sure to look at the top of each sub section you are in and take note the "sticky" threads. Your answer is probably in one of the three listed in this sub section.
Like mi 90's seems like thiers alot of those. I measued one last night out of a 94 everthing was the same center to center its just the overall lenght that was differnt by 2 inches this would still work maybe offset rims.
http://www.foxtbirdcougarforums.com/showthread.php?t=13253
Lot's of good info here. :D
Like mid 90's seems like thiers alot of those. I measued one last night out of a 94 everthing was the same center to center its just the overall lenght that was differnt by 2 inches this would still work maybe offset rims.
Bolt it right in.why ask?,Let us know.
i was told from the begining of 1987 to 2004 would fit but if you have to just try it and see.someone correct me if im wrong.the only diffrences is the width not the mounting points for the cotrol arms.i dont know abut the shock mounts.this is all again what ive been told so have at it.just dont o anything your going to regret
cant substanciate your info but as for shock mounts im sure you'd lose the stock quad shocks. havnt heard its a bad thing tho.
Well here is the skinny got one out of Georgia from a 98 corbra 3:73 gears posi all the harware from spings to shocks, E brake cables ect. for 600.00 hope it works I will post some pics of my (investment) soon. Thanks for the help
