ok, while yes, i do have my parts list ready for when i have benjamins, i'm still looking at ideas. twin turbo 5.0's. what can you guys tell me. anyone running such setup? anyone know of any kits? etc etc. knowledge is power, and i like climbing the ladder of power.
Andrew Beedle has it,can see pic of it here.
http://www.foxtbirdcougarforums.com/showthread.php?t=20502
greg, (5.8Lfastcat) has a TT351W in his cat....
Soooooo, you want twin turbos why? And how many benjamins?
Not sayin' 'no', just askin' why. A good place to start is Maximum Boost by Corky Bell.
Here you go. budjet junkyard set up, and propperly set up.
http://toohighpsi.com/
Really? I was under the impression it was a single T70.
I thought he only had one also
i wouldt know, thats why i'm asking :D
on a more serious note, i'd be looking to do a budget build. twin turbo carbureted would be awesome, but it would also be wicked cool to do this to a cfi setup.....and i just so happen to have...a cfi setup.
DISCUSS!!! :D
haha no... his old cougar is a single.. this one is a twin.... I have pics of them if you wanna see them....
(http://i205.photobucket.com/albums/bb170/1WLDBRD/CatJam07/DSC03206.jpg)
(http://i205.photobucket.com/albums/bb170/1WLDBRD/CatJam07/DSC03205.jpg)
(http://i205.photobucket.com/albums/bb170/1WLDBRD/CatJam07/DSC03204.jpg)
turbo and budget dont realy play all that nicely together.......
1) Garrett says there are three times one should consider using multiple superchargers. Good info: http://www.turbobygarrett.com/
2) I'm not really sure why anyone would consider running a carburetor with a turbo these days but some people do. It's not hard to find everything you need for EFI these days.
3) If I were to budget build a TT SBF, the menu would include a couple of TC turbos (either T3s or IHIs depending), forged pistons, one large or two small ICs, and EFI.
hmmm.....i had an interesting idea.
does anyone know the cfm rating and injector sizes in cfi units?
from what i've heard, they use a pair of 42lb injectors in a regular cfi. i was thinking a dual 4bbl manifold with a pair of cfi's on 2bbl-to-4bbl adapters, and a turbo to each cfi.
i understand that the biggest problems with a standard cfi is the manifold, so swap manifolds and go from there.
Thoughts?
The biggest problem would be finding a computer to run the thing... Maybe you could run it on one CFI unit and rig a relay to to connect the second CFI under boost... Likely it would be far from optimum, and probably would not supply fuel for more than 5-6 PSI...
BTW the HO CFI used 52lb injectors, std 5.0 46lb, and 3.8 37lb...
42 lbs injectors, PMAS blow thru tube calibrated for 42#er's, stock eec, locked timing (spout out), 8 psi, intercooler. This simple setup should be good to 400+ hp on a stock block, assuming you don't lean out and split the block in two. Get a good wideband O2 kit with data logging abilities!
I had my entire kit together and was ready to cut my pipes but changed routes. I have a lot of info if you have questions... also have a bunch of stuff for sale (injectors, IC, cheapy turbos, wideband kit, boost gauge, BOV's, mandrel bends, header s, 5.0 TT headers, etc...)
booksix....you might just become my new best friend :D
Let me say from experience there is really no cheap way down the twin turbo road let alone any forced induction road if you still want reliability and dependability. Fuel injection is reallly the best route to go and specifically a stand alone system such as AEM or FAST. I have also heard mega squirt is ok if you know your computer stuff. You could also just get the standard mustang fuel injection system and chip it with SCT or what not but then you depend on someless to do your tuning. I did run a stock 91 mustang engine with twin turbos for 4 years with a set of o-ringed heads but this summer the bearings finally let go so I got low compression forged aluminum pistons as well as h-beam SCAT rods for some more abuse "fun". You got to pay to play I guess.
Andrew, I wish I could see your car in person. My favorite car on this site other than my own.
