Technical => Engine Tech => Topic started by: cougarXLS on August 17, 2008, 05:43:33 PM
Title: The Distributor is Making Me Dizzy
Post by: cougarXLS on August 17, 2008, 05:43:33 PM
I had to change the TFI module awhile back, and managed to break one of the mounting bolts. I patched it up with some wire... it did a great job. Until recently, I've been having a few (seemingly, unrelated and all extremley intermittent) issues, from fast idling, overheating, rough idle and what feels like a misfire/hesitation when accelerating under load especially when the engine is cold.
So, I realize that before I can begin a proper diagnostic, I need to fix my TFI mounting problem properly. So, I began work today, only to find that I didn't just break one mounting bolt, I broke them both :punchballs: (whether or not I did it on installation the first time, or removal today, I don't know. It came off, broken, so easily as if it was always broken).
I figure I can rebore the holes, but that would require a purchase of some tools (it will happen eventually, as this type of problem as plauged me more than once).
But , it just so happens, that I have a spare distributer assembly.
Here's where my headache begins:
The Part Numbers
The first number, is off the assembly from Cougar X:
E7SE-12A332-CA W/MOD
8 A 20 FAN
E6SE-12127-EA
I have since concluded that the top part number indicates an 87 Thunderbird, Engine Component, with I assume the TFI module
The second row tells me that it was manufactured Jan 20, 1988 (but I don't know what FAN is).
Then there is the second part number, which indicates an 86 Thunderbird engine component.
Here is the second number, off the assembly from a lone TBird in a boneyard:
E6SE-12A332-FA W/MOD
6 J 18 FAN2
E6SE-12127-EA
This one, built on Sept. 18, 1986 (probably for the 87 model year, which is what the loner bird appeared to be).
As you can see, the bottom two part numbers are the same.
The top two are so close.... it's just the CA / FA that I can't seem to figure out what they mean.  What do they mean?
And what's this about FAN vs FAN2?
Bottom line question (and I am leaning towards, yes) is, are these two parts directly interchangeable??
But all in all, those three questions might aswell be making me dizzy.
Post by: jcassity on August 17, 2008, 10:26:19 PM
you broke both mounting bolt heads off?
i tood a 7/32 socket and ran it against the grinder to make it a thin wall socket.  works great.
if your bolt heads are broken off, you gotta yank it out and swap it.
i would guess your other dizzy will be fine.
do both dizzys have 8 fins passing through the stator assembly inside the dizzy?
Post by: TurboCoupe50 on August 17, 2008, 11:56:42 PM
If it came out of a '87 5.0, don't worry about the numbers, Ford changes them every few months just to screw us up... As long as the TFI has six pins in the front connector(some trucks have three) it's basically the same whether it's from a 2.3 or 5.0HO...
Post by: cougarXLS on August 18, 2008, 03:56:32 PM
Quote from: jcassity;232463
Yep.
That's a great idea... wish I had thought of it before hand, but will remember that trick for future jobs... thanks!! :)
It is as I feared, but I could still rebore the holes? No? I Dunno, as I mentioned, I don't have that particular gadget with the right size pieces (heck, I am still vauge on the terminology). But since, I do have another dizzy, my first attempt will be to swap it.
i would guess your other dizzy will be fine. do both dizzys have 8 fins passing through the stator assembly inside the dizzy?
Both do, but I made a startling discovery whilst out counting the fins... about the second (my spare dizzy).... see below...
Quote from: TurboCoupe50;232478
'Tis what I figured... I just wish I understood the difference between CA vs FA or FAN vs FAN2. I've decided to install the spare dizzy...
The TFI gadget is identical:
(http://www.cougarxls.com/pf/tfidizzy/TFICompare.jpg)
(http://www.cougarxls.com/pf/tfidizzy/bothTFI.jpg)
'cept for a difference in brandname :hick:
Here is two pictures of the distributors side by side:
(http://www.cougarxls.com/pf/tfidizzy/dizzyside.jpg)
The spare is on the left, and Cougar X's on the right (for the first picture).
(http://www.cougarxls.com/pf/tfidizzy/dizzytop.jpg)
Cougar X is on the left, and the spare is on the right.
So, as you can see, they are so close it's not even funny.
But here is where I run into another dilemma:
Whilst cleaning the spare, I noticed the shaft running from the rotor all the way down to the gear... there was far more play in the spare, than on X's.
Observe - The dizzy on the left is CX's, the one on the right, the spare.  Look at the seperation noted with the red ovals.  This was acheived by pressing down on that spot of metal that the plastic rotor sits upon.
(http://cougarxls.tripod.com/pf/tfidizzy/compare.jpg)
I can appreciate that I am working on a 20yr old engine, although running strong, still old none-the-less... I do not want to place any unneccesary strain upon the block (or heck, even the timing chain itself).... So I confess, I really don't know what to do.  Unless I am worrying about nothing, and you members may say something like, oh, it's fine, it's within specification... I dunno, I have to ask.
Between CA's and FA's, FAN upon FAN2, play in the shaft of the spare, reboring holes..... what do you all think?  :bowdown:
Post by: Kitz Kat on August 18, 2008, 04:04:50 PM
You better look for another one,Thats a bit more play than I would want.
Post by: Kitz Kat on August 18, 2008, 04:43:25 PM
I went through some stuff I have, I got a dizzy with no tfi and no gear oh yeh no play! It's yours for the shipping.
Post by: jcassity on August 18, 2008, 11:22:45 PM
hog wash,, thats not too much play.
stuff it in, you wont notice a thing and neither will your cam drive gear.
lay feeler guages in the gap from your original and compare that to the slack in the spare.
If you have no side to side play, roll with it.
Have fun aligning the hex oil drive shaft up into the base of that dizzy.  Hope you kept track of where the rotor was pointing and the angle at which the dizzy was sittting.  it makes for an easier swap.
Post by: jcassity on August 18, 2008, 11:29:08 PM
also,
inspect the magnet down on the stator.  if there are little fuzzy thngs poking out from it, get a stronger magnet to lure them off and onto your stronger magnet.
you have to remove the metal thing with fins though to get at it.
Post by: booksix on August 19, 2008, 12:06:23 AM
Great idea Scott!  But you guys do know there is a 'tfi tool' you can get from autozoo, right?  just checking!
Post by: jcassity on August 19, 2008, 12:29:17 AM
Quote from: booksix;232638
that takes all the fun out of it.
Post by: Kitz Kat on August 19, 2008, 03:43:03 AM
Side play is what I mean, in the pic the shaft lookes crooked.
Post by: jcassity on August 20, 2008, 12:45:55 AM
holly ,, i didnt notice that.
ITs gotta be a camera thing or something about how it was resized to post here......I hope
Post by: cougarXLS on August 20, 2008, 10:21:39 AM
I will make sure that its not a camera issue.... I didn't notice that.
I had almost decided to rik it today, but after checking this thread... I'll double check the 'bend'
oh and kitzdnm, I'll let you know.  Thanks.
Post by: Kitz Kat on August 20, 2008, 09:20:41 PM
Side to side is bad, A little up amd down is ok.
I'm talkin about the dizzy to.
Post by: cougarXLS on September 12, 2008, 10:56:58 AM
Wow, it's been awhile... life can get busy!
Where were we?
Quote from: jcassity;232802
I didn't notice the side to side play, there is at least a 1-2 degree movement in side to side and a good couple of milimeters up and down. It's not a trick of the camera or the light.
I am glad you guys noticed it, I almost didn't.
Needless to say, I did not put it in.
Quote from: kitzdnm
I may just take you up on that. Pics? Price? Thanks.
I'll be looking around the boneyard in the meantime. Thanks all!
Post by: Kitz Kat on September 12, 2008, 03:29:36 PM
Give me a zip code I'll check shipping,thats all I want for it.
Post by: cougarXLS on September 12, 2008, 04:06:46 PM
Quote from: kitzdnm;235974
Cool!  PM'd you.
I've got another question for everybody.  I stopped in at NAPA today and inquired about a new distributor assembly.  He asked me, "cast-iron" or "steel".  I went, ummmmm.... I dunno.  He also told me that these two cannot be interchanged.
I believe I have a steel distributor, but how can I tell?  What did the 5.0L in 1988 come with?
Post by: jcassity on September 13, 2008, 12:21:49 AM
will a magnet stick to aluminum:hick:
I think need to ask,, if they mean the dizzy gear (which i am positive thats the case.)
Post by: cougarXLS on September 13, 2008, 09:43:33 AM
I figured they were talking about the dizzy gear.
I asked kitzdnm the same question and the reply was "That would be steel for a roller cam."
Makes sense.  Learn something new everyday.
So, kitzdnm, I'll let you know on Monday or Tuesday about your dizzy.  In the meantime, I'll be getting to work on a few other jobs on X that need to be done.
Thanks everyone for your help!!!
