Technical => Engine Tech => Topic started by: tireshredder on August 09, 2008, 03:40:09 PM
Title: Sensor hole?
Post by: tireshredder on August 09, 2008, 03:40:09 PM
Use to be a 302, but now swapping in 351.  GT40 lower.
There is a hole in the intake behind the throttle body.  I can't find any info on what should go there, but I'm thinking a sensor.....which one, don't know.  Any help would be appreciated.
Title: Sensor hole?
Post by: 32VFoxBird on August 09, 2008, 04:45:38 PM
are you talking about the EGR port? you would have to remove the throttle body to see it.
Title: Sensor hole?
Post by: tireshredder on August 09, 2008, 05:27:38 PM
I don't know, thats why I'm here. :D
You'd have to take off more that the throttle body for this.  The heater core lines block it too.
Here are some pics with the hole circled.
Title: Sensor hole?
Post by: CougarSE on August 09, 2008, 05:41:09 PM
Thats for the water line for the egr spacer.
Title: Sensor hole?
Post by: vinnietbird on August 09, 2008, 08:31:14 PM
But,that's not a GT40 lower.
Title: Sensor hole?
Post by: tireshredder on August 09, 2008, 09:18:20 PM
Quote from: vinnietbird;231367
Yeah, the GT40 is on the engine, and I couldnt get a good picture. Thats the stocker.  Same size and place.
Would it make a difference?
Title: Sensor hole?
Post by: Bob on August 09, 2008, 10:48:48 PM
I blocked mine off, than you need to plug up the port on the black coolant hard line also.
Title: Sensor hole?
Post by: vinnietbird on August 09, 2008, 11:52:27 PM
I plugged my water lines to the throttlebody spacer as well.I have never been able to tell a difference.
