Technical => Misc Tech => Topic started by: 88tbird5.0 on July 17, 2008, 03:19:00 PM
Title: Shaving weight
Post by: 88tbird5.0 on July 17, 2008, 03:19:00 PM
i have been thinking about trying to lighten my car up, but i dont know of any good places to start. im looking right now to be able to remove some weight without spending money, so any suggestions will be appreciated
Post by: lakenheath24 on July 17, 2008, 04:02:58 PM
gut the interior and remove the sound deadener. is it for the steet?
Post by: 88tbird5.0 on July 17, 2008, 04:09:15 PM
yes it is a daily driver. i was thinking removing the air conditioner and the stereo stuff because the only time its on is when there is someone else in the car with me, which isnt very often
Post by: 347Thunder on July 17, 2008, 04:59:34 PM
Yeah the sound deadener is good for about 50 lbs(trunk also)other then free stuff passenger seat weighs a lot
Post by: 5.8fastcat on July 18, 2008, 11:38:40 PM
Sound Deadner, Feltbackings behind rear side panels,behind rear seat
A/C and heater box,A/C condenser,Smog Pump
Post by: HAVI on July 19, 2008, 08:18:01 PM
remove the carpeting itself if ya want.
Post by: Innes on July 20, 2008, 09:10:18 AM
spare tire all the sound insulation then i laid the carpet back down and put all the panels back w/no insulation behind them.
Anything else unnecessary or what you can deal w/out ex.air pump and A/C
Post by: grutinator on July 20, 2008, 04:35:52 PM
there was definatly a thread on this with the weight loss in pounds of each part. i cant find it though
Post by: 32VFoxBird on July 20, 2008, 04:41:32 PM
sleeper t-bird's thread?
Post by: DVP on July 20, 2008, 06:53:33 PM
there is insulation on top of the front splash guards, only a lb or 2 but still something. Convert to manual seats, pull rear seat, sound deadener above the headliner quad shocks, gut the trunk, switch to base door panels if you dont have them already. tubular k member if you what to spend the $
oh and pull the motor that will shave off a few hundred lbs real  easy:mullet:
Post by: vinnietbird on July 20, 2008, 06:53:58 PM
Manual seat tracks saves a lot of weight.If it's still for the street,and you'll be driving it a lot,keep the stereo.It's not that much weight.Sometimes a few comfort items can go a long way,and removing them is more miserable in the long run,and not worth the effort when it's driven a lot.
Post by: SLEEPER T-BIRD 87 on July 21, 2008, 09:31:23 PM
Quote from: 32VFoxBird;228275
:mullet:
Post by: yellow86coogr on July 22, 2008, 10:10:03 AM
My yellow kitty is turning more into a street/strip car. There was a big thread on this. I remember it. Good luck on finding it.
Post by: 88tbird5.0 on July 22, 2008, 04:06:43 PM
http://www.foxtbirdcougarforums.com/showthread.php?p=85067&highlight=weight+saving
i think this is the thread that you were all talking about?
Post by: Chris1987LX on July 22, 2008, 07:03:52 PM
I removed the sound deadening tar and threw it on the scale. It was roughly 42 or 43 pounds.
Post by: 32VFoxBird on July 22, 2008, 07:09:17 PM
Quote from: Chris1987LX;228581
t-birds have a lot more sound deadening than mustangs. that's fo sho!
Post by: 86T-bird on July 22, 2008, 10:13:48 PM
Turbo Coupe/V8 Mustang front sway bar is 25 lbs.  Plastic race seats w/manual tracks weight 25 lbs less than a power drivers and manual passanger Turbo Coupe seats.  3 1/2 skinny wheel and tires are 25 lbs less than Snowflakes w/Sumitomo 245's (that's for the pair).
Post by: grutinator on July 23, 2008, 09:07:40 PM
Quote from: 88tbird5.0;228554
yes! i knew i wasnt crazy
