Technical => Suspension/Steering => Topic started by: booksix on July 05, 2008, 10:00:34 PM
Title: Center console/floor e-brake installed
Post by: booksix on July 05, 2008, 10:00:34 PM
Just finished up.  I know there are probably quite a few flaws in my design, but I'm new to any type of fabrication/welding and I had to have my parking brake working by the end of the weekend.  So here's what I ended up with  :D  Oh, and there was very little room between the floor and driveshaft to work with (about 1.75" or less).  Hope it's works out with suspension travel!!
(http://img.photobucket.com/albums/v203/booksix/DSC02143.jpg)
(http://img.photobucket.com/albums/v203/booksix/DSC02141.jpg)
(http://img.photobucket.com/albums/v203/booksix/DSC02140.jpg)
Post by: daboss351 on July 05, 2008, 10:30:16 PM
dont look to bad!
Post by: booksix on July 05, 2008, 11:10:58 PM
LOL, you should see it in person.  I think the welds just might make you vomit!  LOL.  But I've learn a lot from this car and I keep learning and I am taking it with the understanding that one day when I'm better I will redo all the things that are less than perfect!
Post by: kendoo130 on July 06, 2008, 12:03:35 AM
Quote from: booksix;226051
Booksix-I have a Mustang (1994) lowered 1 1/2" and  a big problem with these cars when lowered is the drive shaft rubbing the brake cable bracket when you hit a big bump. I had to use washers on my pinion snubber to limit my suspension travel. Hopefully you won't have this problem with your bird.
Ken
Post by: booksix on July 06, 2008, 02:46:43 AM
Wow, that's crazy!  I never heard of that issue.  When I realized I had so little room my first thought was "Ford must have made the hump higher in the mustangs to allow room for the cables."  I guess we'll see, but thanks for the heads up!
And now I should probably double check the diameter of that aluminum DS I just scored from the JY.  If it's larger than my stock one I don't think I'll be having is cut down.
Post by: daboss351 on July 06, 2008, 03:54:53 AM
ah welding is something you catch onto quickly.
just watching the amperage and wire speed, makeing sure you PREP everything first, and have a good ground, and getting good welds isnt that hard.
Post by: Tbird232ci on July 06, 2008, 08:21:51 AM
If I remember correctly, the floor boards in these things are galvanized, so it's rather difficult to get a good looking weld.
Just throw some paint over them and it's all good.
Post by: booksix on July 06, 2008, 01:48:44 PM
Wow, really, galvanized?  So, I never got that...  is it a coating or is it actually in the metal?  I know galvanized welds like , but I always thought it was a coating that could be sanded off...?
