Technical => Engine Tech => Topic started by: Dansbirds on July 04, 2008, 08:02:02 PM
Title: oil pressure drops
Post by: Dansbirds on July 04, 2008, 08:02:02 PM
Sorry I dont have alot of info as the car isnt here and I am only relaying what I was told. It a 302 in a 80 Bird abd after about an hour of driving, which it runs fine, the oil pressure drops and of course the rattling begins. Any thoughts?
Post by: daminc on July 04, 2008, 08:07:21 PM
main bearing?
mine drops from 50 lbs to about 0 in 40 min.
then the clunking starts
Post by: Thunder Chicken on July 04, 2008, 11:37:27 PM
Main bearings would be my guess as well - they're so sloppy the oil pump can't keep up with the oil being thrown off the crank when it's hot (and thin). Try an oil change with a heavier oil (20W50 or so). It won't repair the problem but it might buy some time...
Post by: dudeman351 on July 06, 2008, 10:33:12 AM
it could be the pick up tube screen is clogging up. if the plastic cam gear goes south all that plastic goes into the pan. the reason i say this is if it were bearings it would start to rattle as soon as it is warmed up. where if it is the tube plugging up it happens after a while of driving. sorry but my guess is that the oil pan needs to be pulled and cleaned out. and also you might as well put a pump and tube in while you're there.
Post by: jkirchman on July 10, 2008, 03:50:08 PM
Quote from: dudeman351
Which is one helluva job with these cars.
