Technical => Engine Tech => Topic started by: Lion-O on July 03, 2008, 11:02:24 AM
Title: flex-a-lite spacer help
Post by: Lion-O on July 03, 2008, 11:02:24 AM
I plan on replacing both my fan clutch and fan by flex-a-lite. The book said i will need a spacer, but i don't know want inch spacer i need so i will know b4 i head to summit to buy it. The question is, have any1 put flex-a-lite clutch and 1300 series fan in they're 86 ls 5.0 serp belt cougar? thx in advanced!
Post by: 84cougarV8 on July 03, 2008, 11:03:43 AM
i need the same info for a 84! i've heard 1" but doesnt sound right to me
Post by: 32VFoxBird on July 03, 2008, 12:00:23 PM
my bird had a 2" spacer, but those mechanical fans suck so much power! my motor would barely rev. stick with a clutch fan, or buy an electric one at a junkyard for around $25.
Post by: dudeman351 on July 04, 2008, 07:21:25 AM
make sure you check your water pump rotation. reverse w/p uses a different fan than regular w/p
Post by: Bob on July 04, 2008, 09:27:44 AM
I'll never forget what Nick said to me ~6 years ago
Quote from: blown306cougar
"flexfans are good for one thing, cutting off fingers"
go with a factory electric fan (taurus, mn-12 tbird, markviii) with a good controler like dccontrol fk-35 and it will never give you trouble. I say a factory one because they could be had in any u-pull-it lot for under $20 and if you ever need a motor you can goto any autoparts store and get one.
Post by: Lion-O on July 04, 2008, 10:58:35 AM
I was planning on buying their clutch (flex-a-lite) and the 1300 series fan. The 1 they say at high rpm's it flattens out to create less drag. You guys saying their mech fans are no good. Oh and it is a "2" inch spacer i need 2 do the swap? My car has the reverse rotation.
Post by: Carpimp1987 on July 05, 2008, 02:39:04 AM
yeah my 88 T-bird has a 2 inch spacer for it
Post by: Lion-O on July 05, 2008, 11:30:45 AM
Thanks carpimp. Are you doing they're same set-up as I? And how do you like it so far?
