Technical => Engine Tech => Topic started by: 85cat17 on June 24, 2008, 10:08:58 PM
Title: need water pump bolt pattern
Post by: 85cat17 on June 24, 2008, 10:08:58 PM
hi i just went to put a new water pump on my 85 cat and forgot what bolt goes were on the pump is the any one who can give me this info
Post by: ipsd on June 25, 2008, 09:23:00 AM
What motor might help!
Post by: 85cat17 on June 25, 2008, 05:01:13 PM
sorry my car has a 5.0 in it
Post by: jkirchman on June 25, 2008, 07:28:25 PM
Well you could have noted the positions of each of the bolts as you removed the pump from the block.  But since you didn't do that, your car is still sitting in my garage while you are driving mine!
Just kidding, bro.  I hope someone can help you out because I can't remember where they go and they aren't the same as the ones in my '87 LS.
If anyone knows the answer to this question, please let us know.  I tried a forum search to no avail.  If you need pics, let me know and I'll see if I can get some decent ones.  Thanks in advance.
Post by: jkirchman on June 27, 2008, 05:10:01 PM
No one can help?  Does anyone know if we could just use trial and error?  Like run the longest bolt into each place until we find the one it fits in?  Then do the same with the next longest bolts?
Post by: 84cougarV8 on June 27, 2008, 05:12:27 PM
pretty much!
Post by: TurboCoupe50 on June 27, 2008, 06:59:33 PM
Start any one with the pump in place...
THEN keep swapping them around till only 5/8"-7/8" of each bolt protrudes from the pump... After most are correct, swap the original if it is a noticeably different length from the others...
Post by: Lion-O on June 29, 2008, 12:22:53 PM
Hey guys i hate to jack a post, but what is the rotation on our water pumps? Is it standard or counter clockwise? 86 5.0 ls cougar, thanks in advanced.
Post by: Thunder Chicken on June 29, 2008, 01:42:19 PM
Depends on which side of the belt drives it. I'm pretty sure all serpentine belt 5.0 cars have a reverse rotation pump (pulley driven by smooth side of belt). If the pump is driven by the ribbed side it would be forward rotation.
Post by: TurboCoupe50 on June 29, 2008, 02:26:28 PM
Quote from: Thunder Chicken;225156
Only on the Fox bodies... The full size 5.0 models use a dual belt system with a clockwise rotation pump(runs on the ribs)...
Post by: jkirchman on June 30, 2008, 11:22:32 AM
Thanks for the input guys.  And thanks Lion-O for jacking the post!  LOL
We got the pump back on correctly. Now we've got to tackle the bolt that broke off inside one of the holes on the alternator bracket.  *sigh*
Post by: Haystack on June 30, 2008, 08:37:37 PM
Don't you hate that? There impossible to find unless there used(IE junkyard). I broke all three when I did my timing chain cover.
