Technical => Engine Tech => Topic started by: thundergrowl on May 18, 2008, 06:34:53 PM
Title: HO Conversion and Explorer Cam
Post by: thundergrowl on May 18, 2008, 06:34:53 PM
I got the gear to do the HO conversion on "the Base".  I got a couple diffferent cams. One from an HO and another from an Explorer. Can I use the Explorer cam with out changing out the pistons?
Post by: thunderjet302 on May 19, 2008, 01:16:33 PM
You can use either the HO cam or the Explorer cam with E7s and the stock pistons with no problems. They both have the same HO firing order but I would use the HO cam as it is a much better cam for performance. The Explorer cam is more of a low end torque cam. You'd be much happier with the HO cam.
Post by: irv on May 23, 2008, 10:04:42 AM
according to the 5.0 handbook the E7 heads will neither
raise or drop compression ratio. c c's look to be the
same. i assume because of the dished piston you can
use either cam w/o valve reliefs.
Post by: V8Demon on May 23, 2008, 03:03:09 PM
same.
I've heard that the E6 combustion chamber is in fact 68 cc's and have seen references to support this.  I gotta dig them up.  Here's 2 pics to decide for yourself.  E6 first, then E7, both unaltered.  Swapping to the E7 WILL raise compression, but not by very much.
Post by: vinnietbird on May 23, 2008, 03:08:45 PM
With E-7 heads,the compression ratio goes to 26 to 1 compression.You have to use a ricer 4 banger as a starter.LOL.
Post by: irv on May 23, 2008, 05:28:54 PM
oh boy! a diesel 5.0.
Post by: TurboCoupe50 on May 23, 2008, 09:50:46 PM
Quote from: irv;220394
I usta have a diesel 5.7(for a little while two in fact)...
Post by: Beau on May 23, 2008, 11:01:53 PM
Quote from: TurboCoupe50;220426
And there's a reason the 350 diesel didn't last very long... :hick:
