Technical => Engine Swapping => Topic started by: IRON MIKE on March 25, 2008, 08:03:06 PM
Title: E303 with GT40P Heads
Post by: IRON MIKE on March 25, 2008, 08:03:06 PM
Now that I have two birds,I want to beef up the 5.0. I have a HO EEC-IV,a E303 Cam,and a GT-40 EXplorer intake. Just wondering if the GT40P'S will cause piston to valve clearance problems. I dont have heads yet but can get GT40P'S or E7'S. I know the 40p's are better just want to make sure they will be OK before I buy a set.
Post by: Innes on March 25, 2008, 09:08:13 PM
I’m assuming you have an E6 bock w/ flattops
Almost all get lucky w/the E7s I don’t think I heard of anyone having a problem, though some will tell you to still do a piston to valve check. Pretty sure the regular gt40 will have similar results but be more careful bigger valve and I think I herd of one or two lucky people out there. Now as for the gt40p head it has a smaller chamber and I never herd of anyone put them on an E6 motor.
SCRATCH SCRATCH SCRATCH SCRATCH SCRATCH SCRATCH SCRATCH
 I just reread your post your going w/the E303 cam now you just tighten the odds even more.
Post by: IRON MIKE on March 25, 2008, 10:03:21 PM
I know. I  see that there are several people running e303's with e7 heads and a e6 block,so I guess I will go that way.
Post by: TurboCoupe50 on March 25, 2008, 10:05:31 PM
You'll need mass air with that E303...
Post by: vinnietbird on March 26, 2008, 04:29:30 PM
X2.I know first hand about that.
Post by: IRON MIKE on March 26, 2008, 09:20:51 PM
I have the pigtail and meter from a 92 5.0 GT. What else do I need to go Mass Air? I found a article on hooking up the meter to the EEC-IV, is that what you did?
Post by: TurboCoupe50 on March 26, 2008, 10:19:19 PM
You need the Mass Air EEC... Most of the time they'll be ID as A9L or A9P...
Post by: 86T-bird on March 27, 2008, 09:27:34 AM
Another computer to search for is an A3M or A3M1.  It was a service replacement for the A9L & A9P.  They are not as commonly known, so prices are often considerably less (perceived as less desireable).
Post by: SR71TC on March 27, 2008, 05:47:00 PM
I run the A3M
Post by: Sick88Tbird on March 27, 2008, 07:11:03 PM
I would say throw the E-303 cam in the trash...or E-bay it to a mustang guy...*IN MY OPINION*, the entire alphabet cam line is junk...Lunati makes a few real nice cams with more exhaust duration...I drove an E-303 equipped 'Stang with headers/T-5 and 3.73's...it had mass-air and still refused to idle when cold...I couldn't even come close to imagining driving with an AOD behind it...definitely suffered on low-end torque...the car was stripped down to around 2700lbs and ran 12.70's on DR's...but wasn't very fun on the street.
Post by: vinnietbird on March 27, 2008, 08:03:45 PM
Um,well,I have an AOD and the E303,and the car has some wicked mid-range power,and idles a little "loapy",but is great.I have 3.55 gears.When I floor it from a stop,the tires don't have a chance (255 40 17).
Post by: 86T-bird on March 27, 2008, 09:03:22 PM
My experiene with the E303, fuel injection and a manual trans, was not positive.  It surged and stalled quite often.  It would also buck at a low (engine) speed in any gear.  When it did idle it sounded pretty tough, but what a PITA.
When I swapped the long block to another car, it was carburated with an automatic (with a stall converter). Then it was pretty easy to live with.
The fuel injection set up may have run better with a custom chip tuned on a dyno.  I had a mail order one (specifically listing surging and stalling as the main runablity problem).  It helped, but it was still miserable to drive.
Post by: Innes on March 27, 2008, 10:25:35 PM
Most of my reading on the computer is not positive for the E cam.
I think I read this on corral which made me laugh they stated there’s only 1 E-cam out there and we keep passing it along to the next guy.
Post by: IRON MIKE on March 27, 2008, 10:30:26 PM
Yea alot of people told me to sell the E303. I decided to go with a stock HO cam instead. That way I dont have to find another computer, plus it isn't going to be my race car, I have the 87 for that.
Post by: thunderjet302 on March 28, 2008, 12:06:11 AM
I hope you're not using the stock T-bird short block. If you are those pistons are going to bend the valves on the GT40P heads.
Post by: IRON MIKE on March 28, 2008, 02:07:51 AM
Yea stock short block,E7'S Ported with beehives.
Post by: 86T-bird on March 28, 2008, 11:15:48 AM
If you haven't spent the money on the beehive springs yet, you may want to reconsider a conventional spring.
I found they weren't worth the extra cash, despite all the hype.  Getting them installed correctly was a hassle.  Ended up milling the spring pocket and using a stepped retainer to get the proper installed height.  This was all at additional cost, over and above the price of the spring set.  Of course, the hype tells of lighter weight and superior valve control.  I did not experience better valve control, they floated at 6,300.  In this case I could have bought titanium retainers and conventional springs much cheaper (about 1/2 the cost) and had better valve control.
Beehive springs were developed for SBC, which has clearance issues between the retainer and the rocker arm.  The small retainer of the beehive eliminates this problem.  A SBF has plenty of room for a conventional retainer and rocker arm clearance.
If you have a SBF, beehives can be a pricey and unnecessary upgrade.  It was for me.
Post by: IRON MIKE on March 28, 2008, 12:21:22 PM
Thanks for the info 86. The heads are already ported with standard HO springs,so I will leave them alone. Do I run the Mustang spark plugs or the T-bird spark plugs?
Post by: 86T-bird on March 28, 2008, 01:20:12 PM
Stang plugs should be a good starting point...
Post by: Kitz Kat on March 28, 2008, 02:08:05 PM
Quote from: vinnietbird;211193
Whats you gunna do with stick?LOL,I love how the E cam gets battered,It's a decent cam old school maybe?,It's got its merits if you no how to match it up and dial it in.
Post by: vinnietbird on March 28, 2008, 05:33:16 PM
When I install the 5 speed,I'm going to kill my rear tires quick,then,install new tires and enjoy the car.
Post by: Innes on March 29, 2008, 12:04:02 PM
If your using the GTP heads you can’t use mustang spark plugs
Post by: 86T-bird on March 29, 2008, 07:22:40 PM
I believe he listed ported E7's as head he is installing...
Post by: IRON MIKE on March 30, 2008, 12:33:48 AM
Yep installing the E7's. In the process of tear down now.Anybody got shorty headers for sale? I have stock stang ones on there now,looking to upgrade.
Post by: vinnietbird on March 30, 2008, 07:16:53 AM
No headers,but I do have a complete set of brand new spark plugs for E-7 heads still in the package if you are needing any.
Post by: Sick88Tbird on April 06, 2008, 09:26:38 AM
Sorry Vinnie...it was a "B" cam in that 'Stang...not an E cam...I still don't like any of'em...lol.  I'm about as stubborn as an old mule too.
I was checking out some ISKY cams and they have a nasty low end cam...idle like stock, should work well with SD and stock valve springs....I can't remember the guys name here (I just woke up and am extra lathargic, cut me some slack) with a 10:1, "P" headed 5.0 with a Comp Magnum 266 cam and from my research that's a nice entry level all around cam...he put his new exhaust clip up...I'm sure you guys heard that...idled so nice...zero surge...I think that was the same guy...i don't know...still not with it...where's my coffee?
Post by: thunderjet302 on April 07, 2008, 07:06:20 PM
Quote from: Sick88Tbird;212793
That would be my car;)
Cam works great but I had to bump the idle a bit with SD (it has a 114* lobe separation angle). It bumped mine to idle at 1050 rpm in park and 750 rpm in drive when hot. Works great and I've had no probelms so far.
