Computers/PCs => General Computer Forum => Topic started by: jcassity on March 12, 2008, 11:54:41 PM
Title: monster vs spybot
Post by: jcassity on March 12, 2008, 11:54:41 PM
while running monster.com, spybot resident keeps poping up telling me there "could" be problems with xyz url.  This happens everytime a pop up shows or search is clicked or just simply drilling into job listings.  It slows up the computer and puts a red x on most of the advertisp00gets monster uses.
My brother in law finally got his monster account built and this started happening.
Latest ver spybot downloaded as well as latest update on symantic.
this is a global problem on all accounts with this machine.
I do not see where i can chose to disable spybot.
Post by: blown306 on March 13, 2008, 09:36:52 AM
When you installed Spybot you installed a SD helper for internet explorer which blocks some pages from loading properly. You cannot disable this feature after it is installed, but you can uninstall spybot and reinstall without installing the SD-Helper uncheck the tea timer also or it will drive you crazy with registry change alerts.
Post by: CougarSE on March 13, 2008, 10:09:00 AM
Actually its very easy to disable the resident.  You have to go into advanced mode and uncheck a box :p
Post by: Haystack on March 13, 2008, 11:38:31 PM
Quote from: CougarSE;208926
+1
Post by: blown306 on March 15, 2008, 10:29:45 PM
HA! Good answer CougerSE, But unless you uninstall the resident shield it is still installed in the IE folder and can still cause conflicts on certain pages.
Post by: jcassity on March 30, 2008, 01:09:05 AM
Quote from: blown306;209327
for a temp solution, spybot is uninstalled.
I searched through the different options on spybot prior to uninstalling and found nothing unusual.
I am going to reinstall it soon and see if that changes anything.
thanks sheldon,,
Post by: cougarXLS on May 22, 2008, 05:48:23 PM
jcassity, when you go to reinstall spybot, be sure to install only the program.
From my own expierence I found that SpyBot is most powerful (and usefull!) when one does NOT install the automated solutions, i.e. the tea-timer & the SD helper, but rather uses SpyBot exclusivly as a search and destory on command.
Just a thought....
