Technical => Engine Tech => Topic started by: Chris F. on March 01, 2008, 02:08:38 AM
Title: 1988 5.0L HO Questions
Post by: Chris F. on March 01, 2008, 02:08:38 AM
Ok, I am not that  knowledgeable when it comes to cars, but I am trying to learn. My grandfather recently gave me his 1987 Thunderbird 5.0L, it currently has 40,600 miles on it. It recently had to have a new fuel pump, and AC, I guess from sitting in the garage for so long; and I am about to have its transmission rebuilt(or might just get a new one, it is AOD). Anyways I would like to convert the engine to HO and really do not have a clue where to start. I have been reading the articles about Stock to HO Conversions and Mass Air Conversion, and was wondering the differences and if I should do both. If so what type of computer should I use, and what type of parts do I need to obtain (I know, I have seen about 1,000 posts on this). Mainly, I just want to do the HO and Mass Air Conversion.
Thanks!
Post by: 1WLD BRD on March 01, 2008, 05:13:10 PM
if you read the SO to HO swap info then the parts and computer you need are already listed....  Not sure what else you are looking for...
Post by: V8Demon on March 01, 2008, 05:26:15 PM
1987 Thunderbird 5.0L, it currently has [COLOR="Red"]40,600[/COLOR] miles on it
Please tell me you have a garage to keep it in or at the VERY least a car cover!
Post by: Chris F. on March 01, 2008, 06:38:12 PM
Quote from: 1WLD BRD;207116
Bascily i was wanting to know what each seperate conversion provides HP wise, and if I do both at the same time is there anything special I shoul do? One thing I am a bit confused about is the computer for the HO and the computer for the mass air, if I am doing both conversions do I just use the mass air computer for the AOD?  ( sorry if this seems jumbled, i am typing this from my phone at work).
Post by: Chris F. on March 01, 2008, 06:44:37 PM
Quote from: V8Demon;207120
Yeah I keep it in the garage, that is where it has been for the past several years, and most likely why the fuel pump, AC, and transmission died. Paint job only has a few minor scratches, the most being on the black molding. The interior is pretty much brand new, only one person has sat in the back seats haha. BTW the paint is the maroon/red and same with the interior.
Post by: TurboCoupe50 on March 01, 2008, 06:57:05 PM
A stock speed densety HO runs quicker than a mass air one...
Unless you are planning other mods, don't worry about the MA...
Post by: daboss351 on March 01, 2008, 07:08:25 PM
Im with turbocoupe50, unless you plan to cam or supercharge it, you really dont need the mass air!
Post by: Tbird232ci on March 01, 2008, 07:27:09 PM
It really depends on what your future plans are for the car.
If you want something a little peppy, and don't intend on doing much more, the HO swap with speed density would be great. You just need a computer from an 87-88 5.0 Mustang, and then the associated parts to convert it to HO, and you can consider it pretty much done. You're able to do all the smaller bolt ons with no issues, but anything significant will be difficult with speed density.
The mass air conversion is best if you plan on doing things such as heads, cam, forced induction, etc. This is essentially providing you with more potential. To do the mass air conversion, you need an adapter harness, which isn't very difficult or expensive, the 89-93 Mustang 5.0 computer, a mass air flow meter, a proper intake tube, and the rest of the HO conversion.
Post by: Chris F. on March 01, 2008, 08:29:15 PM
Quote from: Tbird232ci;207142
I do plan on doing additional modifications at a later date, so I guess I should do both the HO and mass air conversion, if so do I need the A9L ( I think that is it) computer?
Post by: 1WLD BRD on March 01, 2008, 09:09:10 PM
Quote from: Chris F.;207155
yep, do both then, and use the A9L
Post by: ZondaC12 on March 01, 2008, 09:33:45 PM
HAH since no one has yet PLEASE post some pics of that thing in the User Rides forum! It must be just gorgeous.
Post by: Chris F. on March 01, 2008, 11:02:37 PM
Quote from: ZondaC12;207161
Will do, hopefully my camera on my phone will be ok (3mega pixel). Like I said there are a few scratches here and there, mainly on the black molding, and the tint is starting to peel. Biggest thing that makes me upset the most is that the previous owner was an older lady who smoked, so in the passenger seat on the edge near the shifter, there is a pencil eraser sized hole where she burnt it. Other than that, the interior looks brand new.
Actually I should get it washed because it is real dusty, it has been sitting in the garage since Christmas because we haven't gotten the transmission fixed, but that is changing this week.
Post by: Chris F. on March 02, 2008, 02:33:09 AM
Quote from: 1WLD BRD;207157
Actually my transmission is an AOD, so would I use the A9P instead of the A9L?
Post by: TurboCoupe50 on March 02, 2008, 05:01:45 AM
Quote from: Chris F.;207212
Makes no difference, but my car has better manners(no bucking)on a  A9L...
Post by: Chris F. on March 02, 2008, 11:15:45 AM
Also another question, jumping a bit ahead of myself.
How much HP will be in the bird after the HO and Mass Air conversion? 225hp or more? And after conversion, if I wanted to hit 300hp, what would be the easiest thing to do?
Post by: TurboCoupe50 on March 02, 2008, 11:58:03 AM
All HO 5.0s from '87-'92 were rated 225HP, in '93 the same engine was rated at 205HP... Change in numbers was said to reflect minor internal changes to the engines over the years... Basically I figure most of the difference is in the speed densety to mass air change over in '89... It's always been said the early cars ran quicker than the later ones...
I proved it by installing mass air on a '86 Stang 5.0 HO(engine had the SO 5.0 E6 heads)... With the original SD system and the car modded with later T Body, HO intake, 1.7, rockers & 2.5" catback system, went 14.51 best... Always had severe traction problems, with sticky tires I figure 14.2s would have been easy... After the the mass air change, it felt soggy on the street and went 14.74 best... Swapped it back to SD(at the track between rounds) was instantly it's old self again and went a 14.52...
