Technical => Suspension/Steering => Topic started by: CatCarMan2012 on February 21, 2008, 11:27:11 PM
Title: Power Steering Leak
Post by: CatCarMan2012 on February 21, 2008, 11:27:11 PM
The car has had a leak thats rust proofed the entire underbody.  I knew it was coming from somewhere near the pump and today I poked the hose coming out the driver side of the pump.  The hard line rotates in the fitting.  I am guessing it shouldn't.  Before I order another one and find out its a leaking at the reservoir..... Should it rotate in the fitting?
Post by: vinnietbird on February 22, 2008, 07:48:17 AM
Yes,it rototes in there,but,it's highly likely the seals are bad.The hoses are worth replacing,and I's also go ahead and replace the return hose as well.All that holds it on is two small worm clamps.Buy the high pressure line and the return line and do them both.It'll probably take about half an hour.The fitting for the pressure line on the steering rack takes a little time to remove and replace,but worth it in the end.
Post by: CatCarMan2012 on February 22, 2008, 03:25:34 PM
Can I just replace the O rings?  Theres really nothing wrong with the hose itself.
-dZ
Post by: slowfoxbird on February 22, 2008, 10:34:35 PM
No, just get the line, its probably less than $20.
Post by: vinnietbird on February 23, 2008, 12:26:18 AM
X2.Get the lines,do it right the first time and be done with it.Take the car to the carwash and clean it all up first and the rack included.You'll be glad you did.
Post by: Prototype Services on February 23, 2008, 06:11:14 AM
My PS always leaked at the shaft seal behind the pulley.
Even a replacement pump leaked soon after install.
Post by: vinnietbird on February 23, 2008, 07:39:29 AM
I've never had a pump leak there.I also always use Lucas steering fluid.Awesome stuff.Costs more,but worth it.
Post by: jcassity on February 23, 2008, 02:36:11 PM
Quote from: Prototype Services;205773
x3
this is more common than the hoses.  the fitting at the rack will take more than just a little time.  You best have a line wrench as well.
those lines up at the rack/pinion are a rats nest cobe webb imho.
Post by: CatCarMan2012 on February 24, 2008, 03:58:59 PM
I bought the line but itll have to wait.  Busy for the next couple weeks.  On a plus note, I got the t5 in and the h-pipe installed. Just for kicks, I ran it up and down the block to piss off the neighbors.
Post by: vinnietbird on February 25, 2008, 05:22:47 PM
My 5 speed is coming soon to a Tbird near me.
Post by: CatCarMan2012 on March 01, 2008, 09:15:40 PM
I have a brand new t-5 Separator plate.  Its from mustangs unlimited.  I paid 30+9$ shipping (and tried to cancel when i found one local but it was too late).  If you want it we can work out a price.
Post by: vinnietbird on March 02, 2008, 06:25:53 PM
I saw some new ones for $25.00 on Ebay.Aftermarket ones.I don't remember who makes them.PM me with what you're asking for it.I'll warn you now,after buying the Mach 1 spoiler and the two replacement wheels for the Sport,my budget is not as great as I wish it was.LOL.
Post by: CatCarMan2012 on March 03, 2008, 11:33:42 PM
This is the one I bought.
http://cgi.ebay.com/ebaymotors/FORD-289-302-T-5-CONVERSION-BELLHOUSING-SPACER-PLATE-SB_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ6763QQihZ002QQitemZ120226536922
You have helped me out before on here so 24$+shipping?
 Its still in the box but i can take some pictures if you want.  I bought this one because its embossed like the stock ones.  Like I said, I found one local and put it in before this one showed up.
-Dan
Title: New line, New leaks
Post by: CatCarMan2012 on March 09, 2008, 01:34:21 AM
So i managed to stop the drip..drip..drip... from the High pressure side to the pump.
I filled it up and it worked great.  Now, however, I notice that It seems to be leaking out of both ends of the rack when sitting!! :punchballs:
I noticed the return hardline that enters the rack is very loose.  I checked the manual and it doesn't seem to have any good info on how it comes apart.  I haven't thrown in the towel on the rack yet and I just want to cover all the bases before I do.
Anyone know how the short hardline for the return side is removed from the rack?
Also, I just read that I should put ATF in the PS Pump.  Is that true (maybe thats why its suddenly leaking)?
_dz
Post by: JeremyB on March 13, 2008, 10:57:38 PM
Quote from: danzajax;208333
Just remove it with a std. wrench. If it isn't leaking, you don't need to deal with it.
You'll need to put on a new teflon washer if you remove it. Dorman part #82540. Dental pics and immersing the washer in boiling water will help get it on.
Use Type-F, not Mercon/Dexron.
Post by: CatCarMan2012 on March 14, 2008, 12:48:14 AM
I tapped the return line back down.  Refilled it with type-F and most of a bottle of Lucas stop leak.  Not a single drip now.  Not sure what fixed it exactly but the pump is nice and quiet now.
Post by: jcassity on March 14, 2008, 01:02:03 AM
i got a bunch of info on the rack/pinion in my diy.  you just gotta read.
Bet you did not know the OEM inner tie rods are adjustable,,:D
I told ya it was a beyoch to get at the main at the rack.  Patience and a line wrench will work wonders.
step back and decide what is in your way that your wrench is going to conflict with.  once that is done, start getting things out of your way.
I think i removed my rack bolts first then the bushings. this gave the rack some play to lower it a little so i could get up in there with a line wrench.
Have you had your power steering fluid tested for contamination?  pretty cheap test and good shops will do it if you bring in a sample.
if your leaking on both ends, you gotta switch up to something thicker than plain jane power steering fluid.  Im glad i see more people here have done this, i got heat about it a few years ago.
My brake system on the white coug was also ATF for many years before the wife took it in for something or another and they redid it.  Im loving my corroded zerk fittings now.
Post by: CatCarMan2012 on March 14, 2008, 12:09:18 PM
Ive never heard of ATF in the brake system.  I have, however, done my fair share of custom line bending.
As for the rack. It doesn't leak anymore.  The Lucas oil was as thick as syrup but since its a fair weather driver anyway I'm not concerned about it gelling up in the cold (Cold in San Antonio...pfft).
I could only get at the high pressure line by moving the low pressure return hard line out of the way.  When I did this, it "popped up" a little and I think that it may have been what was leaking.
I tapped it down with a dowel and a mallet and it re-seated.  Now everything seems to be leak free.  The car is getting torn apart this week for paint so it really only needs to not leak for the next few weeks.  Check out my junkyard 5-spokes!  :hick:
(http://memimage.cardomain.net/member_images/5/web/3005000-3005999/3005732_19_full.jpg)
