Technical => Suspension/Steering => Topic started by: ~AC on February 15, 2008, 02:37:37 AM
Title: complete suspension going through
Post by: ~AC on February 15, 2008, 02:37:37 AM
The car just walked over 150,000 miles and it needs the suspension completely gone through.  the car isnt bent but it turns left different than it does right.  so i need springs, struts, etc.
the thing is all i can think of is a complete bushing kit, springs, struts, and MAYBE rear shocks b/c they only have about 10,000 miles on them. i'm thinkin really hard about the balljoints b/c with warped rotors i think they take a thrashing.  what else am i missing thats a good thing to do after 150,000 miles.
also, any suggestions for brand of parts?  which struts, bushings, springs (thinkin mach 1 but i might be too stock) etc.  i dont think im in a box on this b/c it should be cheap enough.  i kinda wanna keep stock on the spring, so im probably be limited on choice of springs other than aftermarket, eh?
buisness has picked up.
Post by: t3skidoo on February 16, 2008, 12:35:21 AM
You might need tie rods.  CC plates are a nice upgrade.  Install grease fittings in the BJs, a/s bar bushings, and maybe the control arms, depending on the bushings.
I'd get underneath the front end and check the a/s bar frame mounts.  While that's apart it would be a good time to repair that.  Max Motorsports, and maybe others, sell a reinforcement plate that's welded in place.
Post by: Red_LX on February 16, 2008, 11:37:51 PM
I'm going over mine this spring as well, or at least the front end (strut mounts, new shocks & struts all around, new lower control arms)
I'd like to buy at least lower control arms for the rear, but I dunno yet if I'm gonna or not.
