General => Lounge => Topic started by: chri85tc on January 26, 2008, 11:06:55 AM
Title: I really HATE the 2.3 !!
Post by: chri85tc on January 26, 2008, 11:06:55 AM
This thing is really me off !!!
It wont run thru 4th without a hesitation or a "chug" as my mechanic friend calls it.
It really is pushing me to the fricking junkyard 302.......maybe you v-8 preachers are right. Maybe I do need the other half..
, just venting .............aaaaaaaaaaaaaahhhhhhhhhhhh
I want to kill something
Post by: P71 on January 26, 2008, 11:08:52 AM
I made this realization months ago. Even the anemic 4.6 makes me happier, not to mention not having to work on it!
Post by: turboranger91 on January 26, 2008, 11:12:05 AM
don't put a 302 in it. sell me the car and buy an lx.
Post by: SLEEPER T-BIRD 87 on January 26, 2008, 11:29:08 AM
Quote from: Aerobird Motorsports;199979
Ive enjoyed my car way more with the v8 I do miss the boost though:D
ehh 4.6:beatyoass:
Post by: dominator on January 26, 2008, 11:42:16 AM
So you put a boosted v8 in it like i did.
Post by: P71 on January 26, 2008, 11:50:24 AM
I keep staring at the 401 AMC in the garage and the T5 bellhousing...
Post by: stuntmannick on January 26, 2008, 01:10:39 PM
Edit: nm, just saw the other thread
Post by: bhazard on January 26, 2008, 02:05:23 PM
V8? Yawn...
yippie a 140hp junkyard 302...
Post by: 1WLD BRD on January 26, 2008, 02:31:23 PM
Quote from: bhazard;200017
V8? Yawn...
yawn , a stock reliable, or done up, unreliable turbo four... that is still slower then a mildly built 302... what century do you live in? very easy and cheap to drop an HO in it... last I checked they had a few more ponies then 140... even if he does swap in a SO 302.... at least it wont sound like a john deere...:hick:
Post by: Kitz Kat on January 26, 2008, 02:32:42 PM
Sorry to hear that. You"ll figure it out.
Post by: chri85tc on January 26, 2008, 02:35:17 PM
Plus when you mod a lets say a 225hp HO motor there is ton of aftermarket support, and it is much less finicky than the nerve racking brain draining 2.3.
I say twin turbo 5.0 is looking much more like the future for me, if I cant get this issue resolved.
Post by: Kitz Kat on January 26, 2008, 02:42:21 PM
You must of seen thundr306's,That would want to make you change your mind.
Post by: chri85tc on January 26, 2008, 03:30:21 PM
I have not yet seen it in person.....but he might influence me a little :)
Post by: gumby on January 26, 2008, 03:37:21 PM
well, i can tell you this: you will not be the first person to give up on this little motor.
from readin your thread here and on TF, you seem to have access to the diagnostic tools you need and youve got plenty of guys tryin to help you figure this out. its up to you whether you want to get it worked out or not.
Post by: P71 on January 26, 2008, 03:46:16 PM
Nor will he be the last.
Post by: Chuck W on January 26, 2008, 04:40:32 PM
Not to slight anyone, but it's not the motor's fault. It's not even the 20+ year old electronic's fault. It's just the way things happen some times. You could be having similar problems with a 5.0, it doesn't matter.
I've had as many problems with the 2.3T as the next guy (I had to replace a shortblock AND THEN a head this past year before it was finally running right again), but I don't blame anything on the fact that it's a 2.3T motor. My XR4Ti never gave me a fit and idled smoother than any 2.3T I've ever had, and never missed a beat up to 18-20psi on the stock fuel system.
The fact is, the 2.3T is a durable and capable powerplant, even when pushed to over double it's stock power levels. It is however a very dated engine and in most cases, it is running on very old electronics with wiring of the same vintage. shiznit is going to happen, and sometimes it will be hard to track down. That would be the case no matter what engine you were dealing with.
Yes, I will be moving onto a different engine in the car, but it's not because the 2.3 is a bad engine. It's because I want to do something different. I've been messing with them for 15 years.
Take a deep breath and trouble-shoot. From your post on TF it looks like you might have an avenue to pursue.
Post by: chri85tc on January 26, 2008, 05:11:04 PM
Yes Chuck, I will figure it out and I am not going to give up on it. I am just frustrated. I agree with all that you said in your post. I do actually like this motor or I wouldnt have gone as far as I did. I also do have a lot of knowledgible people assisting me, plus the high tech fancy tools. It was just a frustrating morning because this thing is quick even with the problems.
And I am eager to start my next project, which is to get the "anemic 4.6" as someone had described it, in a late model GT stang to be a nasty ride. But I cant in good conscience start that till this is a slam dunk or well at least minus the hiccup.
Thanks to all you guys for your words, it helps with the frustration :)
Post by: Tbird232ci on January 26, 2008, 05:54:35 PM
Quote from: 1WLD BRD;200029
Find me a mildly built 302 that will run me, and I'll tell you what century I live in :shakeass:
Post by: vinnietbird on January 26, 2008, 06:01:18 PM
Let me finish what I started,I'll run you.Heck,I'd run 'em now.All I have to do is bolt on my heads,toss the E303 in,and bolt in the 5 speed,then,hang on !!! LOL.
Post by: Chuck W on January 26, 2008, 06:04:07 PM
That is a bullshiznit statement right there. The 2.3T is more bombproof than the 5.0. They all share the same electronics, so where does the lack of reliability come in? It doesn't.
Post by: Chuck W on January 26, 2008, 06:06:06 PM
Quote from: chri85tc;200058
I'd run a compression check, just to rule out the possibility that Michael stated.
Post by: vinnietbird on January 26, 2008, 06:06:12 PM
I myself have nothing bad to say about the 2.3.I've never owned a car with one,or driven a car with one.I would have to say they were pretty good engines to give the Turbo Coupe Car of the Year honors at Motor Trend.
Post by: 1WLD BRD on January 26, 2008, 06:15:10 PM
Quote from: Tbird232ci;200070
you'll see one at CJ if you care to line up with me... ;) :burnout:
Post by: 1WLD BRD on January 26, 2008, 06:18:48 PM
Quote from: Chuck W;200073
ok, let me rephrase that.... UN STREETABLE.... is what I meant to say... ask anybody who is pushing the 400hp mark with their. 2.3L and see how finicky it is, then ask the same person that same question about their 5.0L pushing the same power...
Post by: Dogcharmer on January 26, 2008, 06:33:33 PM
Ah, the good ole 2.3 vs 5.0 argument. I've had both and prefer the 5.0 engine myself only because it makes more torque down low and is much cheaper to modify (also it's much easier to work on imo). However I have to agree with Chuck in that the 2.3 is a much stouter block than the 5.0. I could run 17 PSI boost through my 2.3 all day long with no problems. Try doing that with a 5.0 block.
Granted 17 psi on the 2.3 was only making around 210 HP...
Post by: gumby on January 26, 2008, 06:34:08 PM
there is a whole board of guys that handle 400hp streetable 2.3Ts.
personally i had one (in a low traction ranger) in the 275rwhp range that would walk all over the "mild" 5.0s around me. my favorite was the kid with performer RPM H/C/I and 4.10s that i took by three lengths....
that engine is now in my car. i hope it runs as strong this spring as it did then.
Post by: Red_LX on January 26, 2008, 06:41:02 PM
I have no complaints about mine, in fact the only problems I've had have been because of stuff I or the machine shop that worked on my head screwed up.
Post by: P71 on January 26, 2008, 08:42:07 PM
Sorry Chuck, I have to have a friendly disagreement with you there. The 2.3T EFI, even in stock form, is just not very reliable. Yes, there are many out there, and quite a few with 200K+ on them, but they are the exception and not the rule (out of the dozen plus daily driver TC's I've owned only one made it past 125K on it's original engine). You know just as well as I do that the heads are notorious for cracking (and wiping cams, and sinking springs, and broken towers, and shredding seals, and blowing seals up the valves, and pounding seats right put). The factory PVC system fails to keep up with even stock boost levels, the factory cooling tubes not only fail to cool reliably or well, but they corrode heavily as well. I can go on and on and on (granted we can all find faults in just about every engine, but even you have to admit the 2.3T has more then usual).
When you combine all of the above with just poor engineering or cheap build quality (piston skirts breaking off, inadequate water pump, disjointed oil pump/distributer/auxiliary drive setup, heavy weight for size, etc, etc) and combine it with poor ancillaries (too small clutches, bad hydraulic forks, poor transmission choices, etc, etc) it's just not going to have a stellar reputation.
Yes, it's a good engine for making power on the cheap, nobody is denying that. But to do it to V8 power levels, and stay reliable, just doesn't happen. Sometimes you just have to face the music, and as much as I hate to admit this, I think MM&FF called it right. This archaic, heavy, limited engine is dead. Nobody "new" is really going to care (because the list of faster, cheaper, lighter engines available grows every day) and it will quietly fade away to old-timer status with the Nailhead Buick, the Flathead Ford, and the Stovebolt.
I think once (if) the EcoBoost comes out, the 2.3T will really finish it's death-throws (in the street-legal automotive world).
Post by: P71 on January 26, 2008, 08:44:15 PM
Quote from: vinnietbird;200075
Did you ever read that? It was kind of like clubbing baby seals. The TC beat 3 different Turbo FWD Dodges and a FWD Pontiac wheezer. It was no contest in any category except for fuel mileage. In fact, over half of the ads in that issue are from FoMoCo.
Post by: P71 on January 26, 2008, 08:46:22 PM
Quote from: gumby;200087
No, there's not. 300HP ones yes, 400HP, no. No ones going to buy that propaganda for a minute man. There's only a few dozen true 400HP+ 2.3T's on earth, and none of them have seen more then 3,000 miles of street time.
Post by: gumby on January 26, 2008, 09:09:10 PM
most anyone with over 300rwhp should be near or making 400 at the crank. you tellin me only a few guys have +300rwhp 2.3Ts?
i think someone is a lil bitter.... :dunno:
Post by: P71 on January 26, 2008, 09:17:45 PM
300rwhp through a T5 is not 400HP flywheel. There is a HUGE difference in between the "300HP" 2.3T's (that can still run stock LA3's, VAM's, and all that jazz) and REAL 400HP+ 2.3T's (that are all on aftermarket fuel controllers with massive turbos). Yes, there are real 400HP ones, yes they run like scalded dogs, no, not a one of them is a real street car.
I'm not bitter, I'm rather disappointed at the 2.3T dying off, but don't spray left-field propaganda here. If there really are street RELIABLE 400HP+ 2.3T's then prove it. I mean ET#'s and mileage logs. You can't, because there aren't any that haven't lunched themselves three times before making 10,000 miles in a year.
Look, just show facts. It's a dead production engine and the question was posed as to whether it's still worth staying with a 2.3 or moving on to a 5.0/4.6/5.4/351/LS1/whatever. I'm maintaining that a swap is the right move, simply because a high-horsepower, reliable, daily-driver reliable 2.3T cannot be done at any price, let alone on the cheap.
Oh, and don't even try to bring up the Huber's. What they did at Drag Week was awesome and all, but they're one-of-less-then-50 unubtanium block cost more then every car I've owned combined.
Post by: gumby on January 26, 2008, 09:20:11 PM
Quote from: Aerobird Motorsports;200112
i didnt say it was.
Post by: Tbird232ci on January 26, 2008, 09:24:51 PM
Aerobird, I'm going to have to disagree with you.
I probably have the most abused 2.3 Turbo engine in my car. It had 130K on it when the previous owner put it in the gray car. He beat the living shiznit out of that car. He even told me how he was bounce the rev limiter in 4th gear, dump the clutch, race it around everywhere, and even told me to do some donuts when I test drove it. He put a good 30K on it. Fast forward to me. I downright beat the out of that car. Went through 3 turbos, a clutch, one head gasket (my fault), 2 fuel pumps, a TFI/PIP, a power steering pump, while making 22-25psi of boost, and driving it daily.
Well, I got my black 88. Within a few weeks, the engine lost oil pressure and seized up. I yank the engine from the gray car, put it in the black car, and I'm back to square one. A lot of mileage, a lot of abuse, some detonation, and not a single drivability issue.
As for the 400 horsepower 2.3T comment, I also disagree with you. While you may know of a dozen on the internet, there are a lot more people with 2.3 Turbos running down in the 10's than what you would think. Just because its not on the internet does not mean it doesn't exist
Also, 400 horsepower isn't exactly difficult to reach, you just have to know what you're doing.
Post by: SLEEPER T-BIRD 87 on January 26, 2008, 09:33:07 PM
Boy this is fixin to get ugly...
Post by: 1WLD BRD on January 26, 2008, 09:48:20 PM
muhaha...... :evilgrin:..... notice nobody has said anything about the sound of them?.....
Quote from: Dogcharmer;200086
17psi, and you just barely got past the STOCK power of a 5.0L.... add 14 psi (VERY streetable and reliable) to a 5.0L and you double that number...
Post by: Dogcharmer on January 26, 2008, 09:57:24 PM
Quote from: 1WLD BRD;200127
Exactly:rollin:
Post by: dominator on January 26, 2008, 10:33:58 PM
Well i gotta get in on this one. Now having owned both engines in my TC and having a few light mods done to my 2.3L(when i had it) with the boost at 17psi, i gotta say 5.0L wins hands down. This about the stock 302 block(which actually displaces 299cid in stock form) being weak is just that . Consider this, a stock 5.0L block is riddled with holes in between it's two 2.5L halves pulling each other apart at 6000rpm. You've got 16 lifter bores,a long front to back camshaft bore, oil galleries and oil drainback holes in a V style block. The 2.3L has the same but is however not a V-style block but instead an inline 4. If you where to take that inline 4 and make it a v-block(2cyl per side) with all the same holes i bet it wouldn't even handle the stock power let alone mods. Now as for the 4.6L handling 700+hp on the stock block well of course it will, it has no holes in the center of the block(no cam bore,no lifter bores,and no oil drainback holes) therefore it is much stronger with it's 2.3L's per side pulling in either directing to 7000rpm. I run 14psi through my modded 500hp 5.0L all day long and the only problem i've had in 8000km's is a leaky water pump gasket. Had this have been a 500hp 2.3L I never would have made it around the block let alone 8000km's on any of the stock components. 2.3L's with that kind of power don't live long and are track cars only, not to mention you would probably spend twice as much money and time getting that kind of power from the 2.3L opposed to the 5.0L. Don't get me wrong i'm not a 2.3L hater, i love the 2.3L and would like to have another in almost stock form(sans 18psi) to play around with as a NON daily driven car. Basically it all comes down to: "There's no replacement for displacement". Not that i would let anyone drive my car(many have tried non have ever driven) but no 2.3L with the same kind of power as my 5.0L will ever have as much low end torque as my v8
Post by: Tbird232ci on January 26, 2008, 10:35:50 PM
Keep in mind, 15psi is stock, 2 psi to gain another 20 horsepower. Add 2psi to a 5.0, and you probably wouldn't notice dick.
Post by: SLEEPER T-BIRD 87 on January 26, 2008, 10:48:16 PM
Quote from: dominator;200138
:shakehead
(http://www.mrnitrous.com/cracked_block.1bmp.jpg)
Post by: dominator on January 26, 2008, 10:49:05 PM
UMMMMMMMMMMMMMMMMMMMMMM 3psi in a 5.0L is eqivilent to 30-40hp in a 5.0l(approx 12hp per psi in a 5.0L as opposed to 6psi per hp in your 2.3L)might wanna do some research before ya post! I love a good ol grudge math muhahahahahahahahaha!!!!!!!!!!! Yes sleeper exactly what i was getting at,holes in the block resulting in less strength,still impressive at 500hp with all those holes man.
Post by: chri85tc on January 26, 2008, 11:02:10 PM
Well, first off I dont plan on and never intended for this to be a daily driver. I just wanted to keep the "Stock" 4 cylinder in the car because thats what it came with. I also wanted to have FUN when it would run respectable alongside or even pass the average V8 car that is on the street.
With that being said, This thing is just g me off...that doesnt mean i am quitting it. This is my first 2.3 Turbo car ever, and I have owned over 50 cars so far, most of which where v8 Mustangs and Camaro's. Basically I never had these kinds of issues with any of those like I am having with this car. So really I dont care about the comparison of the 5.0 vs 2.3, they are 2 differant animals each of which has there own personality.
I will surely be complaining about my 96 4.6 GT sooner or later too.
Christ, I cant even stand my Nissan Titan anymore and I have had it since it was new. thing cant stop making me burn off those expensive tires all the time. Stupid 305 hp 5.6 liter !!!
Post by: TurboCoupe50 on January 26, 2008, 11:05:03 PM
Quote from: SLEEPER T-BIRD 87;200149
:shakehead
You ain't trying hard enough... :hick:
Why have one when you can have two...
(http://members.pen 15s.net/mr428/split50.jpg)
It's a never ending argument, but for a daily driver in MY opinion a 350-400Hp 2.3T is NOT practical... Yes you hear stories about so & so's and such & such's running big numbers, but I'm yet to see one that wasn't basically a stripped out race car... I'll keep my FAT girl with all her power options, and cruse in comfort with the AC and tunes blasting...
Post by: Tbird232ci on January 26, 2008, 11:13:43 PM
Assuming you are correct about the boost levels, only ASSuming, how much power would your source of forced induction suck up before you feel the benefit of boost?
If you can tell me that bolting on a supercharger or a turbo, and creating 3psi is 100% free 30-40 horsepower, and you can prove it, I'll pat you on the back or something, maybe send you a cookie. The bottom line is, any "addition" to the engine is going to suck up power before you create it, you're going to lose power, then use boost to make up for it, and then some.
I also want to know how a 400-500 horsepower 2.3L is not streetable? It's exactly like saying an 800 horsepower nitrous engine is not streetable. If you build the car right, it's very easy. A ported, big valve head is streetable, correct? A header is streetable, correct? A gutted/knifed intake with larger throttle body is streetable, correct? A large turbo is streetable, correct? A proper turbo cam is streetable, correct? Methanol injection is streetable, correct?
If you use your head, and avoid a cam like the A237, which isnt even a truly turbo friendly cam to begin with, you wont have any streetability issues.
So explain to me why yours wasn't streetable, just couldn't drive it properly to get it into the torque bang?
Post by: Clayton on January 26, 2008, 11:19:41 PM
i like both motors they both have potential
why be mucking up this mans thread with the age old discussion of der 8 is bettah then 4! its 2008 who cares most of us are free white and over 18.
act like it.
Post by: Red_LX on January 26, 2008, 11:59:37 PM
Watch the video clips I have in my sig and tell me my car sounds like a tractor.
Post by: 1WLD BRD on January 27, 2008, 12:02:09 AM
Quote from: Tbird232ci;200154
um, shawn, why would you build something for the street that is a totally gut less piece of in NON useabale street rpms? and why would you try and argue with that fact? to make ANY kind of power out of the 2.3L, stock OR done up, you have to really wind them out... that ISN"T streetable, or condusive to reliability in ANY motor... just because you CAN drive it froma short point to another doesnt make it streetable... hell thats like saying those 6second stangs are street cars.... com'on give me a break... you raise a good point about the amount of power a SC sucks up, and makes me curious what the EXACT amount of boost is needed to overcome any drag, (IF there even is any at such low boost levels...) and start to make power... Maybe I will email MM&FF and bring it up to them, see if they can do a dyno test for us...
yep... john deere..... with fart cannons... :p
Post by: Red_LX on January 27, 2008, 12:04:31 AM
You have to "wind out" a 2.3L turbo to make power?
Is 3000-6000 RPM winding it out?
Post by: V8Demon on January 27, 2008, 12:41:38 AM
If you want reliable 12's or faster?!! IMHO -- yes
Quote from: Gumby
Quote from: Gumby
i didnt say it was.
Ummmm....you pretty much did...300 RWHP is around 360-380 through an AOD depending on parts used and the level of abuse it's taken...
Shawn, your car makes a lot less power than his....
Quote from: Dominator
Got #'s for that one....From what I know it's 302 C.I. and 4.94 liters.....
As for my opinion on the strength of a 5.0 block read here: http://www.foxtbirdcougarforums.com/showpost.php?p=142247&postcount=39
They need to be SET UP CORRECTLY
Superchargers by nature have some parasitic loss....30-40 HP on a 5.0 @3PSI.....What RPM range are we taling?
My 4.6 has 6 PSI of boost and with tuning has over 100+ RWHP gain @ that 6PSI....
A turbo on a 5.0 @ 3 PSI will deffinetely show gains upwards of 40 HP...
Lastly:
Step away from the 2 valve, Step away from the 2 valve. 3 valve and boost FTW!
Post by: P71 on January 27, 2008, 12:52:27 AM
Stop talking you evil V8Demon voice in my head, I can't hear you! Bla bla bla bla!
Seriously though, show me some real, street-driven, 400+HP 2.3T's. I was in that scene for over 5 years, drove a 300+HP one 10,000 miles in 18 months and I've never seen a higher HP one driven harder. Look, the 2.3's can MAKE power, NOBODY is saying otherwise. What we're saying is, 2.3's can NOT do it AND survive on the street (without direct influx of 1-off parts and cubic dollars, ala Huber's $100K Mustang), period.
If you want to go fast (12's or better in a full-weight, real car) and drive it everyday, the 2.3 is the bottom of the heap (OK, maybe the 3.8, but you get the point).
Look at the Top 25 here. The fastest 2.3T car is Sluggo at #8. Now his TC is bad ass, there's NO doubt about that. But call it like it is, a trailered race car. We've seen the pics, it's pretty gutted. The next one is Sleeper's in the 13's (very close to the 12's) and we all know how much lighter his car is. Ask him whether or not he likes that 305 Chevy better? Every other 2.3 car is a street car, and slow (yes I'm including myself).
Cougar5.0's car is the epitome of awesome street cars on here. I mean come on! 11's out of a full weight, full option Cougar with a blown small block! I can guarantee he has less money in that setup then most 13 second 2.3's.
Just the facts man, just the facts...
PS - They sound like a tractor!
Post by: 1WLD BRD on January 27, 2008, 08:47:08 AM
Quote from: Aerobird Motorsports;200174
;) Dont forget about 5.8fastcats ANIMAL!.. that thing is plain sick, AND streetable, as he showed at CJ...
Post by: SLEEPER T-BIRD 87 on January 27, 2008, 08:54:56 AM
My 2.3 would had went faster if i wasnt soo lax on the boost It never seen over 15 psi at the track and I never sprayed it at the track I just was tired of spending money with what I will call a "little" return.I still like the 2.3 and for what they are there a hell of a strong motor.about 75% of 2.3 owners are unhappy because they seek the low end torque of a v8.
And yeah ive actually got to have more fun in general with the chebby sometimes you have to remember your goals and what your willing to do to reach them in the ultimate scheme of life.
Post by: EricCoolCats on January 27, 2008, 09:10:37 AM
2.3L...meh.
5.0L...bah.
Everyone knows the 3.8 is THE sleeper engine. Bow down to the almighty 3.8 V6!!!11!1! :bowdown: :bowdown: :bowdown:
Post by: Thunder Chicken on January 27, 2008, 09:22:08 AM
Quote from: EricCoolCats;200195
2.3L...meh.
5.0L...bah.
Only the CFI versions, of course. We don't need no stinking superchargers or split port induction muddling things up :shakeass:
*EDIT* Completely unrelated but I just noticed Cougars 2 Go's light sage green four-eye in the banner. Dayum, that's a nice car. The colour looks good with those BBS wheels. I wish I still had my green T-Bird...
Post by: TurboCoupe50 on January 27, 2008, 09:26:36 AM
2.3L...meh.
5.0L...bah.
Yeah if you don't mind replacing your hood hinges every week or two...
Isn't that about how long they last, with the amount of opening and closing necessary to keep one of those things going???
Nope actual displacement IS 301.5936 cu in...
Figure it yourself, works for any engine... Bore X Bore X Stroke X .7854 X # of cylinders...
Post by: Tbird232ci on January 27, 2008, 10:57:26 AM
Quote from: 1WLD BRD;200163
You want to get down and dirty, you only have to wind them up to launch them. You need to load the engine on the clutch to get it into boost to get any sort of 60ft time. Just like guys running a 2-step on ANY vehicle
Quote from: V8Demon
That is just hearsay. He had faster parts, but it doesnt mean his car was faster. I had a buddy with a big valve, ported head, A237 cammed, hybrid turbo, worked over 2.3L, and I drove around him.
Parts dont make a car fast, a combo does, you of all people should know that.
Im growing very tired of this thread. Most of the people that have experience and knowledge on the 2.3L are staying quiet because theres no hope of winning against the typical "theres no replacement for displacement" argument. Catch me on the streets, I prove that argument wrong all the time.
If things go as planned, I'll have my TC and my red bird out at CJ. I probably wont have all of my planned mods for the TC done by then, but Ill let some of you drive it, and see how slow and unreliable it really is.
Post by: Clayton on January 27, 2008, 11:14:18 AM
and to prove a point all those at CJ last year all know... eric's V6 could kill my 5.0
my V8 is slow. hell i drove alex's xr7 and it put a smile on my face... and that was after riding in gregg's tt351.
I dont get it... why bitch about equal power and somewhat better mileage? None of you guys remember the old saying "TNT comes in small packages" ? you only start talking shiznit about the 2.3 when someone has a problem with it! you see a built one that runs youre all oooooh and awwwwweing at it like its somthing precious.
thats all ive gotta say
oh yeah nb4lk.
Post by: dominator on January 27, 2008, 11:16:53 AM
LOL i'll catch your little 2.3L on the streets any day man and make you look like you where standing still,hell i'll give ya a 5 car length head start in the 1/4 and still blow your doors clean off in my 3800lb full load car. I love how you always think you know what your talking about shawn when you actually don't it makes me laugh lol. This is why you and i got into it last time,because you truly don't know yet think you do and i get completely sick of it. If you'd listen to half the people with far more experience than you with the 2.3L telling you that the 2.3L will never out perform the 5.0L and still be streetable then you might have a clue but since you won't maybe you should just go out and buy the board game. And no big turbo's,big heads and big cams are not streetable in the FORD 2.3L without large money which is what i said earlier if you'd read which you don't,what are you like 18 get some experience????!!!
As for the 302 being 301cid i know i read that ford stated it was 299.8cid or something like that and it matches the displacement of the 4.9L inline 6 but since that displacement was already in use they had to bump it up to the public as a 5.0L so they would not get confused when buying a car as to what engine it had in it. I'll try and find some info on that.
Post by: Tbird232ci on January 27, 2008, 11:34:37 AM
Quote from: dominator;200212
You know what, youre a waste of time, you do nothing but run your mouth, and have nothing to back it up. You had a 2.3L that ran 17psi of boost. BIG DEAL. If YOU knew about the 2.3L, youd know that 17psi isnt dick. I was running 22psi, and was running the MPH for mid 13's with a STOCK head, a STOCK intake, a STOCK throttle body, a ranger roller cam, with an SC50, a log header, 3" exhaust, a fuel pump and a cold air intake.
I guess my buddies with big heads, big cams, big turbos, big injectors, gutted/knifed intakes, big throttle bodies, and headers have completely unstreetable daily drivers now don't they? A good friend of mine gets better gas mileage in his Turbo Coupe than his girlfriends Saturn! Guess thats unstreetable too. With all of this gibberish you talk about, it sounds like you're a GROWN MAN that needs some experience. I'm open minded, and I do my own homework, and I've had my hands in every part of a 2.3L other than building the bottom end and EEC tuning. I guess I have no experience now too.
I don't know what kind of picture you have painted of me in your head, but you better learn otherwise. I'm 22 years old, I've been in this scene for since I was 15 years old, I'm on my third Thunderbird, 2nd Turbo Coupe, and 3rd turbo car overall. If you weren't so full of yourself, you might actually see that I know what I'm talking about, especially since you gave up on your 2.3L because you couldn't make it work.
When did we get into it last? Oh wait, the fuel pump issue, thats right. And yes, I didn't know what was going on. I fixed the issue, and because you were such a prick about that issue, I've done everything to avoid you. I don't care how knowledgeable you think you are, I do not and will not listen to your gibberish.
In other words, do YOUR homework before you try to insult someone over their age and experience. And grow up, you are not top dog in this forum, you've just spent more money than most of everyone else.
Post by: 1WLD BRD on January 27, 2008, 11:44:28 AM
Quote from: 87thunderbirdBlackJack;200211
my V8 is slow.
hell we know that.... ask cluade if he would mess with a white XR-7, with it again.... ;):evilgrin: :D
wrong shawn, he probably has less in that combo then you do NOW in you TC... I know the car and the power it has... Chris does know his shiznit you just wont listen to it... and all that shiznit in those cars.... garauntee they dont run smooth all the time... Chris' car runs and drives like the day it came from the factory.... as was said, just becasue some people DO drive them like that, DOES make it a streetable combo... 90% over the people out there expect there DD to be a noproblem, get in and drive anywheres car, with NO issues... Garauntee yours wont be that way when you are done... and I would like to see the video clips of your TC running with these done up cars before I say anything about that..
com'on guys this is a good debate thread... lets keep it clean and keep it from getting locked... there is a lot of decent facts from both sides on here right now....
Post by: Clayton on January 27, 2008, 11:48:11 AM
Quote from: 1WLD BRD;200220
my bird lol not the cat lmao. but you get the point
Post by: V8Demon on January 27, 2008, 12:30:03 PM
And I'm confident his setup was done properly. He's been with the 2.3's for a while. Shoulda learned something:hick:
Post by: Erie Bird on January 27, 2008, 12:40:48 PM
as a mechanic with thirty yr's of spinnin' wrenches,.. i send 2.3's to canadian tire
Post by: chri85tc on January 27, 2008, 12:58:09 PM
Hey you guys forgot about me ?
I wasnt serious about the Title when I started this thread.
Lets face it we are all Ford lovers ( except for Sleeper T-bird 87 with his chevy motor:))or we wouldnt be here, who cares what engine is in your ride.
I personally like em all, even 3.8's and 4.6's.
In fact I want one of each, but my wife wont let me.
Post by: P71 on January 27, 2008, 01:07:55 PM
Never said I didn't like them (hell for the last 3-3.5 years I've been one of the biggest "keep the 2.3!!!" guys on the net) but we are debating whether they make good streetable high-HP motors.
Everybody knew my car, at least six people here on the board saw it race, and a few have driven it. That car was beat on far more then a "daily driver" should have been. Went over 10,000 miles in 16 months, went from the Canadian border to Lake Tahoe and back, twice (including dealing with really bad snow and ice in the Siskiyou's, Shasta, and Bellingham Bay), and made over 75 passes in under a month. I blew a lot of parts, and a good portion of them weren't my fault. But when you shove 25psi down any engine's throat stuff is going to break! Talk smack about it being slow all you want, I won't argue with you (every single option still functional 88TC with a stereo in it too, ran 100+MPH trap speed, went a few 14.7's going through the lights in 3rd with 2.6 60's for having to "drive it off the line" since I was still on 225/60 street tires).
That car taught me that when it comes to going fast, and being stone cold nuts reliable, the 2.3 is not the way to do it.
Shawn, I'll take you on anytime. I've DW's motor going together here and it's a near-nuts clone of Layla's. We're going to stick into an optionless 88 with slicks and see what's what. It still won't be a street car though ;)
Post by: 87badbird2613 on January 27, 2008, 01:16:09 PM
this thread should just be locked cuz this is down right rediculious we all have our own opinions and thats it there is no reason to be fighting over cars!!! i have a 5.0 and a 2.3 the 2.3 is my daily driver and my 5.0 is my toy but i love them both for there own reasons the same way te 5.0 guys love theres and the 2.3 guys love theres. so lets just all take it easy!!!:burnout:
Post by: P71 on January 27, 2008, 01:48:27 PM
Why should it be locked? This has been one of the most civil and fact-filled 2.3 vs 5.0 debates in a long time. I'd call it healthy conversation, not a name-calling baby-momma-drama argument.
Post by: turbo83coupe on January 27, 2008, 03:04:12 PM
My 2.3 dont sound like a John Deere, so I dont know what your all talking about? I wouldnt say it sounded anything like or close to a V8, but definatly not a John Deere!! Just about anything could be built to be reliable and strong, but money possibly could be an issue. I have PERSONALLY rode in a 2.3 that is making a good bit over 300HP, that is a TRUE daily driver, that is PERFECTLY streetable, and pretty dang reliable for making 150++++++ passes a year off of a junk yard short block, and I would have no doubt in my mind that my mom would have no trouble driving this car with NOOOO issues whatsoever. Maybe were just freaks over here ;)
Frank M.
Post by: daboss351 on January 27, 2008, 03:08:19 PM
god you all have a right to your own opinion and to argue it but dont be calling each other stupid because you dont think they know as much as you on a specific topic. You need to know when to draw the line. making personal attacks in someone elses thread about a topic is ridiculous. Your all old enough to be civil and understand each arguement has there ups and downs. Hell its like arguing chevys better then ford, they both have there ups and downs
Post by: P71 on January 27, 2008, 03:33:23 PM
Quote from: turbo83coupe;200270
That's the whole point!
We've said that. Now find a 400HP one. See the point I'm trying to make?
Post by: 1WLD BRD on January 27, 2008, 03:36:15 PM
I still say prove it, with dyno sheets and milage logs
Post by: P71 on January 27, 2008, 04:54:52 PM
For me or Frank? I assume you're asking Frank since I know my car wasn't even 300rwhp let alone 400!
My best ET was: 14.767@92.06 with a 2.33 60' (launch at idle, shift at 6,000, went through the lights in 3rd). My best MPH was on a 22-second run (it stalled :hick:) went through the lights in 4th at 101.22. My mileage log went with the car when I sold it, but I sold it at 180,005 miles, the new-shortblock engine was installed at 168,9xx in Nov 05, so it went 11,xxx miles in 22 months, but it spent 7 months in a storage garage with a blown turbo and other maladies.
Again, my car was NOT fast, nor did it make 300rwhp (maaayyybe 300BHP at the flywheel). It was certainly not reliable enough for me to trust as my only form of transportation.
Post by: nirvanagod on January 27, 2008, 05:32:08 PM
This thread reminds me of something:
http://www.youtube.com/watch?v=xaiEHNv2g6w
Post by: 1WLD BRD on January 27, 2008, 05:45:07 PM
Quote from: Aerobird Motorsports;200299
not you Aero, the claimed 300rwhp 4 cylinder DD car with 150+passes on it.:hick:
Post by: gumby on January 27, 2008, 05:57:27 PM
well, i can see that your problem must have been b/c it was a 2.3T [/sarcasm]
ill take your example of devastation and raise you one example of my reliable setup.
my motor put down 246rwhp @ 15psi. using dominators generalization of 6hp per additional psi, i would have been makin 276rwhp @ the 20psi i normally ran around with, but i never dyno'd it with 20psi....i did run it at the track. my best et was 14.68 @ 94.8mph; my best ever trap was 98mph. consistent 2.0-2.1 60fts my engine had 164K on it when i swapped it into the [first]ranger and the longblock(exc. RR cam) had over 200K when i pulled it to use in my current car. the engine sat for 5yrs behind the dealer i worked at before i ever used it in the ranger. i slapped a new oil pump in it and some fresh gaskets to keep the oil inside the motor. i have NEVER had the head off*knock on wood*, and it was my fair weather DD the entire 36xxx miles it was in my ranger with no issues what-so-ever beyond a TFI and a set of plug wires.
while your personal experiences with your motor may lead you to believe the 2.3T is unreliable, mine make me think otherwise. if i was runnin 276rwhp that would put me ~325 at the crank(using 15% loss). this was with ZERO tuning, other than an AFPR and a timing light. i dont see how porting a head, addin some larger injectors and a tuner would have hurt the reliability of my motor. i do however think that these things could get me an additional 75fwhp....
maybe ill drag this back up when i get there. ;)
Post by: martin0660 on January 27, 2008, 07:04:57 PM
Quote from: 1WLD BRD;200308
Frank was talking about my old TC and current Capri combo. Both cars where (TC) and are (Capri) daily drivers, and when raced, I bracket race, so they are tuned to go rounds, not all out ET's in general. I got into the parts hard this year with the Capri because I was pushing the T3's at the track beyond any reason. Anyone that has seen my cars at the track knows I drive them like rental cars, Neither ever left me stuck aywhere on the street, and I would (and have) driven either of them anywhere.
I can assure you, I've got nothing to prove to anyone.
Bob Myers
Post by: P71 on January 27, 2008, 07:05:19 PM
Were you running a ball-bearing SC50R? (I was the first running TC with one) 46# injectors? A237? Ported head?
Your car actually exactly proves my point. You're at that "happy line" on the 2.3 (300BHP, stock electronics/fueling). They will go high-mid 14's all day long on street tires, and generally be fun and reliable cars. Or basically equal a near stock 302 n/a.
Step over that line into the monster turbo/bigger injector/etc territory and everything changes. I've yet to see any 2.3T car do that, AND be stone-cold nuts DD reliable.
Whereas a 13-second or faster V8 can do it without breaking a sweat.
Post by: kingcars on January 27, 2008, 07:05:34 PM
My dad and I were JUST talking about the 4 vs 8 thing today while riding in my car. It really comes down to what kinda money you have to spend and what you want to get out of your car. For max horsepower and reliability out of a particular budget, there is a much better likelihood of a V8 getting the most out of your money. And like someone said earlier, reliable high hp 4 cylinders are the exception, not the rule. And even then, everybody needs to remember that two 5.0 blocks may look the same and that two 2.3 blocks look the same, but they are completely different. One 5.0 might drive 200,000+ miles with only regular maitenence and no problems. Another 5.0 might not even make it home the first day without blowing a head gasket or something. There will be horror stories on both sides of the fence, and there will be good stories as well. However, since the 5.0 is extremely popular, there will obivously be more overall stories, so take that into account also. So then we must go to precentages and ratios of good to bad stories. Judging by what I've seen on this forum and what I've heard from Mustang guys, I'd take a 5.0 any day.
Post by: P71 on January 27, 2008, 07:06:38 PM
You crossed that line with the Capri Bob. Hence the lunched shortblock, the half-dozen T3's, and other maladies.
Post by: TurboCoupe50 on January 27, 2008, 07:20:53 PM
You're reaching... LOL
MY figures PROVE it's 301.5936... As for the 300 I6, using the SAME formula figures out to 300.08563... The 300 I6 did appear in the trucks in '65 some three years before the 302 first saw light of day, but it was never used in any passenger car...As for 5 liters, each is 61cu in, 305cu in is a true 5.0...
The first mention of 5.0 was on the '78 King Cobra Mustang II... The large 5.0 emblems that's so familiar, were first used on the '79 Mustangs and Capris... The 4.9L ID was still in the future...
Post by: 1WLD BRD on January 27, 2008, 07:24:31 PM
Quote from: gumby;200310
ok with that kind of power you ran the same MPH and ET as my 260XXXmile all original, 180rwhp, (IF i was lucky!) 302 in my bird WITH a 3.08 gear and open rear... something doesn't add up here.... I have video of the run and timeslips...
Post by: gumby on January 27, 2008, 07:37:34 PM
Quote from: Aerobird Motorsports;200321
i ran a stock T3(94mph) and a SC50(98mph). please go back and actually read my post. the answer to all the rest of your questions is there.
you wanted to split hairs earlier when i said "over 300rwhp" and implied ~325rwhp; dont under rate my combo now. the numbers say it should have been ~325bhp @ 20psi not 300.
check my trap speeds. the truck ran mid-14's because i suck as a driver and it was a ranger. the traps along with the 3030 race weight are good for 13's with a better driver. and it was still fun and reliable.
you stepped over that line, and hardly went any faster than my combo. thats your experience. ill let ya know how mine does when i cross the line further, but i know there are more than a few guys who have reliable combos makin more power than me; not every person who has more done than me is constantly breakin stuff jus cause you did.
Quote from: 1WLD BRD;200325
ive got the dyno sheet, and the timeslips here as well.
dont get me wrong. i like my 2.3T, but 5.0's still have place too. the one in my mountaineer is great!
Post by: 1WLD BRD on January 27, 2008, 07:41:35 PM
Quote from: gumby;200328
check my trap speeds. the truck ran mid-14's because i suck as a driver and it was a ranger. the traps along with the 3030 race weight are good for easy 13's with a better driver. and it was still fun and reliable.
wrong, with that wieght and MPH your BEST possible ET MIGHT be a 14.0 or a 13.99.. IF your lucky and get a perfect run...
NOT an "easy" 13 by any means
Post by: cougarcragar on January 27, 2008, 07:48:18 PM
I recently sold my turbo 2.3 Cougar, and I can say with complete confidence that my next Fox project will have a 5.0 under its hood.
I can see the performance potential with the 2.3, but I guess I'm addicted to the sound and feel of a V8. I miss my '88 XR-7...
Post by: gumby on January 27, 2008, 07:50:17 PM
Quote from: 1WLD BRD;200329
oops you are correct. i snagged the wrong calculator.....a straight HP to weight calculator showed mid 13's, but didnt factor in trap speed.
still yet, all the calculators show my driving abilites werent up to par with the vehicles capability
Post by: chri85tc on January 27, 2008, 07:58:36 PM
Someday when I get my 2.3 running right I will post a Dyno Sheet. I spent way to much money on this thing to change now.
Also before I went hog wild on this car I had over 160,000 miles on the engine as a daily driver pumping out 18psi on stock green tops and not cutting it any slack at all. I mean every light was a "Tree" at the track for this thing. Then I spun a rod bearing, and I still drove it home, ran pretty good too except for that unholy knock sound coming out from under the hood. So I do believe it to be a pretty reliable engine.
Post by: 87badbird2613 on January 27, 2008, 08:33:11 PM
ok maybe not locked but the im glad to see that people sayin that each other dont no about is done!!! but it is definitely been quite a debate!!!
Post by: JeremyB on January 27, 2008, 08:58:57 PM
2.3L...meh.
5.0L...bah.
Dat's what I'm talkin' 'bout!
Quote from: TurboCoupe50;200199
My T-bird has gone 50,000 miles without any issues besides regular maintenance or owner stupidity. My cougar has averaged a breakdown every ~11,000 miles.
Between the three motors, there are more 3.8Ls on the road than 5.0s or 2.3Ts (at least in cars). The 3.8L was the last to die. So, really, the 3.8L is the best. ;)
Post by: daboss351 on January 27, 2008, 09:01:10 PM
Quote from: martin0660;200320
Bob Myers
God yes bob you beat the living shiznit out of that car! U gave the other cars a hell of a run, till u destroyed that turbo
Post by: 1WLD BRD on January 27, 2008, 09:10:42 PM
Quote from: gumby;200331
I dont use calculators, I used my experience from watching and reading and doing drag racing...;)
Post by: P71 on January 27, 2008, 09:18:17 PM
Quote from: 1WLD BRD;200352
AMEN!
Post by: dominator on January 27, 2008, 10:30:39 PM
Thank god you avoid me like the plauge shawn, believe me i've done the same with some of your non proven ideas. However when i post things and you get on my back by callin me names, then your gonna get it back 10 fold. As i thought your a 22yr old KID with no life experience spoutin untruths,i've known many of your kind and stay far away from them. I was driven bird's and working on cars before you ever knew what a thunderbird was!!!!!!.... So don't try and out rank me on your knowledge of these cars. I'm in my mid 30s and am a licensed class A mechanic and your what,o yea a snot nose kid you thinks his car is the fastest on the street, hell my bone stock 91sc would probably beat your car. I own one of the 5-10 fastest cars on this board and you own what,o yea a 14sec 2.3L ahhhhhhhhh i see. Look at my car and it's list of mods dude, i don't play when it comes to my car. Thanks ron for backing me up against this kid, as a person with a head on their shoulders and one who speaks from experience on my ride. To all else who don't like me,good for you, those who know me know i'll go to the mat to help them but i can't stand snot nose kids who think they know it all. I never wanted to start with anybody in this thread but as usual it would be shawn as he can't keep the insults to himself calling me an ASS and tellin me he'll send me a cookie,Yea ok! Aerobird has probably the most experience with the 2.3L as do a few others and he also stated(as did most of them) that it's v8 all the way(for major hp and reliability) due to the many problems he and many others have had with their 2.3Ls and again SOMEONE don't take well to constructive critisism. Also you speak of no proof, well where's yours with YOUR many friends who run 4-500hp 2.3L's on the street reliably, Bullshiznit i say,prove yourself, My proff is in my RIDE!!!!!!!!! Dominator OUT!!!!!!!!!!
Post by: 1WLD BRD on January 27, 2008, 10:44:47 PM
alright guys lets not get back in to the insults, you guys want to talk shiznit about each other put it in PM,s, please keep this thread clean....
Post by: cougarcragar on January 27, 2008, 10:47:22 PM
Come on, folks. Use PMs for the mud-slinging - keep the thread to technical debate.
Edit: 1WLDBRD beat me to it.
Post by: TurboCoupe50 on January 27, 2008, 11:12:25 PM
Quote from: JeremyB;200349
Now that's a scary thought...
Guess if you start with twice as many, you can make that statement...
Anyway once a buddy started having HG problems with his 3.8 '84 LTD(Not Crown Vic), decided I'd never own a 3.8(from Ford at least)... A couple dozen 2.3s(14 turbo), and a dozen or so 5.0s later, I'm still true to my word...
Post by: Tbird232ci on January 27, 2008, 11:47:58 PM
Quote from: dominator;200365
Non-proven eh? I drive my car every day. End of story.
You need to get your head out of your ass, you directly insult me based on age and experience, and you try to say that I started calling you names?
I don't care how old you are, maybe you should start acting it. Being a class A mechanic means nothing. I'm a diesel mechanic. But next thing I can hear you saying is that I don't have experience bla bla bla. Grow up and get over yourself, you're no better than a single person here. As a matter of fact, you're the most arrogant member of this forum that I can think of, with no reason.
If you actually read this thread, you would have seen the discussion was based on mild 302's and 2.3's. My car walks all over mild 302's, mild 4.6's, and mild LS1's become a drivers race. I don't understand what you're trying to prove. Also, don't think your SC would beat my car, because it wont. A friend of mine has 4 of them, one is moderately modded, as in a raised blower top, 10% blower pulley, 5% jack pulley, headers, full exhaust, cold air, and a hand full of other mods. Dead even race. My car isn't the fasted on the street, and I know that, but its very respected around here.
NEWS FLASH! No one cares!
So I guess you're a better person than me, because you have spent THOUSANDS more on your car than I have. Man, I need to rack up credit card debt so I could be cool like you.
I love how you try to refer to me as a kid. You act more childish than ANYONE in this thread, even those that are 18 and younger. No one in this thread cares about your car and how you say its fast. Your car was never part of the discussion, and yet you some how come in here defensive and wanting to attack me. Grow up and get over yourself.
You came off as an arrogant asshole, and I said that if you had proof, Id send you a cookie or something. How the hell is that an insult? Are you smoking something?! Whats this "as usual it would be shawn as he can't keep the insults to himself calling me an ASS", I never called you an ass untill you attacked me! Read the thread. And this about me not keeping insults to myself, first off, I never insulted you, and second, I hardly post in this place anymore. I think you had it out for me to begin with. You're the one that started the insults, youre the one who came off as being completely arrogant and full of yourself, and now you point the finger at me. This is HIGHSCHOOL DRAMA.
I take constructive criticism well, I dont take ignorance and flatulence of the mouth well. You spoke no proof of this "horsepower per PSI of boost" junk, which if you knew about compressor maps, you would know its purely based off of the volumetric efficiency of the engine, along with the lbs/min vs PSI of the forced induction setup you use. 6psi will respond different in a H/C/I car than it would in a dead stock car. I guess you already knew that being a Grade A mechanic and being 30 something.
Also, I never said my friends made 4-500 horsepower. I said my friends had built, streetable engines.
If your proof is your car, why are you pushing so hard in this thread. You're worse than my girlfriends drama loving friends.
Post by: Tbird232ci on January 27, 2008, 11:54:32 PM
Quote from: cougarcragar;200374
Don't worry, I'm done with this. This is the exact reason I hardly post. Ignorance.
Post by: P71 on January 28, 2008, 12:11:40 AM
First, stop the mud-slinging BOTH of you! This was getting to be a pretty CONSTRUCTIVE debate in a healthy manner and it's quickly deteriorating into e-thuggery.
Second,
Quote from: Tbird232ci;200386
Sorry, but I call BS on that. The GTO runs 13.09 DEAD STOCK. DR's make 12.7's, "mild mods" have hit 11's. Don't even remotely think you're in that league. You *might* stand a chance in a 3rd gear pull at highway speeds against a 200K mile stock LS1 auto, but I'd still bet against you. Considering you haven't even hit bottom 14's yet and EVERY LS1 is at most high-13's stock! Look man I respect you and your car, but don't throw BS onto the field, you will be called on it.
Post by: vinnietbird on January 28, 2008, 12:18:23 AM
10 pages......10 whole pages of this stuff.Is it really that big of a deal to go on that long and get that "sensitive" over a 2.3 vs. 5.0 thread?Who cares????If you like the 2.3,good for you.If you like the 5.0,good for you as well.If you like them both,pat yourself on the back.Drop all of this already.Surely there's something else to do around here.Every week there seems to be some drama of some kind started from the simplest post or question asked.Lighten up already.For the most part,we're grown men around here.But,after reading some of the posts,I'd actually have to question that.Think before you talk.
Post by: kingcars on January 28, 2008, 12:21:41 AM
I also dont know why everybody thinks 1/4mi times are the be-all-end-all. I run mid 15s, which is slow as poo when compared to some other cars, but I enjoy the living out of every bit of it. Isn't that what really matters? Who cares if a car runs 12s, 14s, 15s, etc or has a 2.3, 5.0, 351, or 3.8....just enjoy the thing!
Post by: JeremyB on January 28, 2008, 12:27:34 AM
Quote from: vinnietbird;200395
Luckily, it's only 3 pages for me.
Post by: P71 on January 28, 2008, 12:38:02 AM
Quote from: JeremyB;200398
How?
And you're missing some great, constructive debating in at least 7 pages of it.
Post by: JeremyB on January 28, 2008, 12:58:43 AM
Quote from: Aerobird Motorsports;200400
How?
Go to "User CP", then "Edit Options"
I'd go insane if I could only see 10 posts per page. One forum I'm on has 100 posts per page as an option, heaven...
Post by: P71 on January 28, 2008, 02:09:54 AM
Aaaaaaah I see!
Post by: t3skidoo on January 28, 2008, 02:17:42 AM
Quote from: kingcars;200396
+1 TCs were never designed to be drag strip kings. Ford used the 2.3 for weight distribution, not weight savings.
Post by: 1WLD BRD on January 28, 2008, 09:14:32 AM
Quote from: t3skidoo;200408
either way there is no chance a TC will run with ANYTHING with an LS1 Hell, My bird would walk stock fox stangs, but even I knew I didn't stand a chance against somthing with an LS1... They have handling AND power... TC has handling... I want video proof...
Shawn, when you get you car done.... yeah that thing will be an animal.... That suspension it going to ROCK, and I wanna go for a rip at CJ... but I cant see you staying with some of the cars you say it can... next time you go out and play with these cars, get it on film for us.... Personally, I dont know where you think Chris has thousands into his car... He was VERY smart, and patient with his money and found KILLER deals on the stuff... As I said, he has about the same amount in his car NOW as you do in yours...
Post by: tc² on January 28, 2008, 10:44:26 AM
What the hell is happening to this board?
Yes, a V8 is going to produce more power than a 4 cylinder. If you bought a Turbo Coupe so you could beat everything on the street, I've got an island I'm selling cheap in the Nevada desert. So what's the argument here? That its unreliable? I don't see how anyone can prove it either way. But I certainly don't think you should shoot down a motor that half the people of this forum are running without anything to back it up. You can share your personal experience, but just because it didn't run perfect for you doesn't mean the motor is horrible. My $.02.
Post by: oldraven on January 28, 2008, 10:58:40 AM
So what's the verdict, then? Is it Shawn or Dominator who has the bigger dick? :rolleyes:
I love my 2.3T, and will NEVER own a 302. That's because I'm happy with keeping my 2.3 as a DD and under 300hp. That and I believe the thing that made the TC special was the motor, not the hood scoops and rear end. If I want a crazy fast rig, it won't be with either engine. If I want to build a toy, I'll use my 383. But I really enjoy being able to drive my 2.3 to work every day, (or at least, I did, when we could afford having two cars on the road), and sipping fuel all day long. When I want to use the turbo4 for fun, I can. I won't embarrass many built cars on the highway with it, but I'll still have fun.
There are people and cars for whom the 2.3T is a perfect fit. HP junkies who don't want to do frequent repairs just aren't these people.
Who drives a Ford for their reliability anyway? :shakeass: You drive it because it goes like a raped ape, two days of the week.
Post by: tc² on January 28, 2008, 11:00:04 AM
Quote from: oldraven;200448
+1 lmao
Post by: stuntmannick on January 28, 2008, 11:08:04 AM
I probably won't wrench on a v8 until I can afford to turbo charge one.
Post by: Chuck W on January 28, 2008, 11:22:37 AM
Quote from: 1WLD BRD;200431
My Bird (with its old set-up) ran door to door with an LS1 T/A from 20-100 mph.....he didn't start to pull away until 100+. Could I have taken him in the 1/4...no, for multiple reasons.
I never claim that it's the fastest thing around, but I know it can hold its own, and would do even better if I could drive for shiznit. You can't use the it costs a bunch of money to make a 2.3T move in my instance because I NEVER dump a bunch of money into my cars. If your only concern and measure about a car is the 1/4 mile, then yeah, most TC's aren't going to put down the numbers. You can't count out a TC on the road though.
Now, onto the rest of this thread....shiznit better calm back down, or it will be my turn...
:beatyoass:
Post by: ZondaC12 on January 28, 2008, 11:30:59 AM
I like 0-60, and actually in the case of my car with the 2.73s, 0-50 since it will do that in 1st gear. :hick:
Though the way the HO powerband is I like holding it in 1st, easing up to about 25ish and stomping on it. WHOAAAA
Post by: kingcars on January 28, 2008, 12:41:03 PM
Quote from: ZondaC12;200452
Yeah I startled myself a while ago on a cool, crisp night and stomping it from a 30mph roll. WOW she took off!
PS - post once more already, Mr 999 posts.
Post by: gumby on January 28, 2008, 12:44:12 PM
and gettin back to reliability of a built 2.3T once more, this is how i see things. when you build a 5.0 you have a HUGE aftermarket supporting you. seriously, any shmuck can build a 5.0. please note i did not say every person who builds a 5.0 is a shmuck, so lets not go there. you can build off of thousands of combos before you, and pick from hundreds of vendors to tune it. you build a 2.3T on the other hand, your choices are much more limited, and you hafta figure out alot of things on your own. sure guys have tried lots of things, but that doesnt mean it gonna work for you, everytime. the reliability of a built 2.3T is set squarely on the shoulders of the person buildin it. it is not the motors fault, period.
as i have stated, i have not jumped into the world of tuning as of yet. i have left my combo workable with what ive got for a few reasons, but that will change in the future and my next engine performance purchase will be a WBO2. i am curious however; how did you tune your combo aBM? i have never seen any tuner/tuning or even a WBO2 in any of your mods lists...
Post by: Chuck W on January 28, 2008, 12:56:39 PM
Quote from: gumby;200463
*licks finger and sticks it in the air*
:hick:
That about right, Michael?
:D
Post by: ipsd on January 28, 2008, 01:15:49 PM
the reason you build a 2.3t are because you don't want to be like every other person and build a v8. the dare to do it different it what it is all about. yes you can make good power with a 2.3t and still get decent mileage. if you want your 2.3t to go faster in the 1/4 mile then put the motor in something that weights less. if you want to make your bird/cougar a 1/4 mile killer now matter what motor you use it will take lots of dough. one thing is certain coming on here and talking trash or and moaning won't do you any good.
Title: I really HATE the 2.3 !!
Post by: P71 on January 28, 2008, 01:34:06 PM
Quote from: Chuck W;200466
:hick:
:D
Yup :hick: I tuned it at the track using the timeslip, AFPR, Gillis Valve, and adjustable cam gear. 30-33MPG on the highway (cruise on, 70MPH) and it trapped 92-94 in 3rd. My tune was pretty conservative (and pretty good for no dyno time).
You guys have to realize that I agree with oldraven. Kept to stock, or very mildly modified levels, the TC/2.3T is a BLAST! I have such a hard time not buying a clean, low mileage one to just drive everyday and enjoy. On the street, for the money, you just can't beat the fun of a TC.
MY problem is, I also want to go fast and rip-snort through the 1/4 mile. That's why I'm going V8 from now on, on my race cars.
As for the "not the 2.3T's fault" comment, sorry, but a lot of it is. It's called "basic design principle". If the engineers make a fundamental mistake/design flaw, it stays with the engine until it's fixed by the factory (think PI 4.6's vs. non-PI ones) or by the aftermarket. The 2.3T is pretty stout, but it does have design weaknesses, and more so then the 5.0 or a 4-cylinder should have. But it's old so I can't really bad-mouth it too much for that.
I like this debate (partly because it's been raging in my own head for over a year). There are plusses and minuses to both engines (and other's like Sleeper's SBC and Cad-T-Bird's 500). My opinion is, a TC is best loved near-stock, and on the street. A V8 is what you want for ET/$.
Post by: TurboCoupe50 on January 28, 2008, 02:25:51 PM
Quote from: Aerobird Motorsports;200469
On the street, for the money, you just can't beat the fun of a TC. My opinion is, a TC is best loved near-stock, and on the street. A V8 is what you want for ET/$.
I'll X2 this... I've used TCs as daily drivers and the 5 speeds defiantly put a grin on your chin... With the boost up to 13-14 psi, the A4LD auto ran good in the now 5.0 TC... Power brake it to a few psi and it launched good from a stoplight... Hold it till about 6-7 psi(all it would make against the converter) and she'd smoke the tires 5-6 lengths...
Post by: oldraven on January 28, 2008, 02:48:08 PM
Wow! I got an X2 from Tom!!!
I breakin out the Scotch.
Post by: TurboCoupe50 on January 28, 2008, 03:06:09 PM
Quote from: oldraven;200476
:cheers: (and a couple hours later)... :drink: (I'm on the right)
I don't think you can find any post where I've said I did not like the 2.3T... If I did, musta been like the guy on the right...(fornicateed up)
It is an amazing piece of work for a early 70s engine... They had serious problems the first few years, common to bust #1 piston and wipe camshafts... By the time the TC's debuted some 10 years, late most of the issues had been resolved...
Post by: oldraven on January 28, 2008, 03:40:43 PM
Nah. I didn't really ever hear you say it was a bad engine. Yours was the first 5.0 swapped TC I'd ever seen, so I remember always giving you shiznit about it. ;)
Post by: TurboCoupe50 on January 28, 2008, 03:59:50 PM
Quote from: oldraven;200488
If the Sport had received the virtues of a TC, I wouldn't have had to make the swap... AFAIC, my car is the Sport Ford should have built...OK it's a modified Sport that should have been built...
Still I've been told I should have modded a Sport... Screw 'em, for me it was far easier to swap just engine, transmission(which would have been necessary anyway) and a little wiring... No way I wanted to mess with brakes, rear end and add other TC tpuppiess to a Sport... Had a rust free '87, junked it...
Post by: gumby on January 28, 2008, 04:30:59 PM
while the 2.3 is not perfect, i cannot agree with this. if the lima had so many basic design flaws the same issues would be consistent through out the line, including all the +200K mile n/a 2.3s runnin around in rangers. granted they arent pushin any power, but a design flaw is a design flaw. see below:
i also must disagree with the use of this combo as an example of the reliability, or lack thereof, of a 2.3T how could you tell it was conservative w/o a WB, or even a FP gauge in the cabin, to look at? honestly it sounds like a recipe for lean to me. im not tryin to pick you apart personally, but the combination of parts and that level of boost just does not seem to add up to anything good.
Post by: V8Demon on January 28, 2008, 04:56:01 PM
I thought he had upgraded the injectors a few months before the sale?
Post by: gumby on January 28, 2008, 05:00:30 PM
that might be so, i pulled that mods list from the sale ad. i would still be concerned, even with larger injectors, that the stock PCM wouldnt be up to the task of keepin everything happy from idle to redline and all points in between.
Post by: Tbird232ci on January 28, 2008, 05:39:04 PM
Quote from: Aerobird Motorsports;200394
Call me on it all you'd like. Track numbers mean absolutely nothing on the street. Anyone who races on the street would know that. Ive put a fender on a Saleen S281, and had a fender put on my by a 2005 GTO. He had a throttle body, cold air, MAF, and lers. It was about 45* that night, I was running 24psi of boost through the SC50, and the car was running great.
Also Mike, how do you get 11's out of mild mods? Ive put many hours in a shop called F-body Central here in Maryland. Full bolt on cars go mod-high 11's, and when I say full bolt on, I mean everything other than heads and cam.
Quote from: 1WLD_BRD
I doubt it. I had just about 5K in my gray car TOTAL. That includes the turbo, header, exhaust, wheels, tires, brakes, 5-lug, clutch, short throw, EVERYTHING other than the CD changer, pillar pod, and other trivial items. This car doesn't half the entire setup from the gray car, nor will it get all the of brake mods and whatnot. The Red bird in the signature will be more of the animal, since thats getting the suspension, brakes, and a mild 5.0 in it. Even though this thread makes me disgusted to have a 5.0 on a stand.
Post by: P71 on January 28, 2008, 05:43:11 PM
I upgraded the injectors to 46#'s after it went 14's. Then when the head kept letting go I threw in a spare on with the stock ranger cam and swapped the 35#s back on and sold it.
I was using my car as an example of "crossing the line". My problems didn't surface until the larger injectors and what not. I went from a reliable, fun-to-drive car, to a total basket case in a single round of mods. The point I was trying to make is, if I had left well enough alone and been happy with the stockish combo I'd probably still have the car because it was so much fun.
And Gumby, you DO hear about the design flaw problems! How many threads are constantly being made about dizzy gears/auxiliary shafts? Slider cams wiping lobes? PIP/TFI systems pooping out? Heads cracking? E3's cracking? Pistons breaking? The PVC system failing? Fuel rails leaking? Granted there's going to be more as time marches on and these cars get more miles, but a design flaw is a design flaw. AMC V8's have to run an internal oil line to keep from starving the rear lifters. We also have to run sleeves in the integral oil pump (because steel gears on an aluminum housing = accelerated wear and poor oil pressure). It's just a design flaw that has to be overcome.
Post by: V8Demon on January 28, 2008, 05:45:31 PM
Ask Eric how to do up a 3.8:hick:
Post by: P71 on January 28, 2008, 05:46:14 PM
Heads and a cam ARE "mild bolt ons" for an LS1. If you don't have L92/LS2/LS6/LS3 heads on at the very least, you're not trying. L92's outflow stock LS1's by a huge shot and are under $500.
Take a gander at the LS1GTO ET lists, especially the "cam only" class and tell me what you see. This is 2008 man, not 1998. LSx motors have come so far it's not even funny.
Post by: gumby on January 28, 2008, 05:47:01 PM
Quote from: Aerobird Motorsports;200520
and the point of my line of questions was to find out if it was properly tuned after it "crossed the line."
IMO the stock PCM isnt gonna be happy with that combo, and w/o at least a WBO2 there is less chance on knowing that.
Post by: P71 on January 28, 2008, 05:51:49 PM
That's the point. At the cost of getting a 2.3T "right" over that line, you can have a 5.0 going 2 seconds faster. That's why I said "screw this" and sold it.
Post by: jlewis05 on January 28, 2008, 06:18:29 PM
Quote from: Aerobird Motorsports;200526
Bah.
Post by: Tbird232ci on January 28, 2008, 06:27:20 PM
Quote from: Aerobird Motorsports;200523
Explain to me how heads and cam are considered mild? Heads and cam is what makes the engine what it is! Any engine. Where is the power? Heads and cam. Those are not considered mild mods because youre taking the engine down to a shortblock!
Look man, I can tell you've done your homework, but just because you can find heads for under 500 bucks doesn't make them a "mild" bolt on. You can say a cam in a 2.3L is mild, because hell, I can do a cam in 1.5 hours without rushing, and getting it timed in. I still don't consider it mild. Thats what changes the entire characteristics of an engine.
Thats like saying running on a treadmill is mild weight loss, along with liposuction. Liposuction takes a few hours, so it's pretty mild, right?
Post by: P71 on January 28, 2008, 06:39:21 PM
The same way any 4.6 not taken to "PI" status is considered not even worth playing with. Updating to the latest factory parts (swapping on an E6, IC, square intake, big VAM, 35#'s, ranger roller, etc) is considered "mild" mods (if even mods at all).
Post by: kingcars on January 28, 2008, 06:58:19 PM
Unfortunately, whatever is considered "mild" will vary from person to person. But the point still stands that if you want THE MOST straight line speed for your dollar, a 5.0, LSx, SBC, 351, etc will out run a 4 cylinder any day. That's just how it is.
Post by: Tbird232ci on January 28, 2008, 06:59:11 PM
Yes, but those can be considered bolt ones. I mean, header, intercooler, intake manifold, VAM, injectors, and things of that nature are bolt ons. Heads and cams are internal. Thats a big undertaking, where as a turbo or header can be done by anyone with some sort of decent experience.
Post by: jleews6 on January 28, 2008, 07:04:23 PM
Well its good to see that everybody has been keeping this a good thread (debate?). Just remember that thats why they make all kinds of motors because everybody likes something different. Myself, I bought my first TC in 1988 it was a brand new car that had a sticker of over 20K and that was alot of money back then. We owned the car for about a week and I was ready to trade it in because I hated the 2.3 and the best it would run was 15.9 @88 @ mph@NED. Needless to say about three months went by and I was at the dealer trading it in. The next year (summer of 89) I was driving a almost new black 88 TC with a stock 5.0L HO swap with a 5 speed and to this day that was one of the best Daily driver cars I have ever owned. It wasnt fast and only ran mid 14s @98 MPH but it was just overall a much nicer car to drive with the V8. Myself = I have never liked the 2.3 and although it is a great motor and is very strong they are just not for me. Give me a 87/88 TC with a mild 302 with an S trim and I will be a happy camper.:D
Oh and one of the first guys to do a 87/88 TC 5.0l swap in this country was a guy named Rick that owned Manards auto in NH. Back in the late 80s he had already done about 8 of them.He did them before Windsor fox did.
Post by: SLEEPER T-BIRD 87 on January 28, 2008, 07:05:58 PM
Quote from: kingcars;200544
But the point still stands that if you want THE MOST straight line speed for your dollar.
Then you build a chevy..:D
Post by: kingcars on January 28, 2008, 07:10:43 PM
Oh jeez, Sleeper, the last thing we need is a Chevy vs Ford engine debate :P
It's also worthy to note that my dad used to race N/A 2.3s, and when built correctly, were very stout (although not at any real high hp range).
Post by: Chuck W on January 28, 2008, 07:13:54 PM
And Gumby, you DO hear about the design flaw problems! How many threads are constantly being made about dizzy gears/auxiliary shafts? Slider cams wiping lobes? PIP/TFI systems pooping out? Heads cracking? E3's cracking?Pistons breaking?The PVC system failing? Fuel rails leaking? Granted there's going to be more as time marches on and these cars get more miles, but a design flaw is a design flaw. AMC V8's have to run an internal oil line to keep from starving the rear lifters. We also have to run sleeves in the integral oil pump (because steel gears on an aluminum housing = accelerated wear and poor oil pressure). It's just a design flaw that has to be overcome.
OK..how about stepping in your own poop a little more. First you state that a "design flaw is a design flaw", then you tout that your vaunted AMC V8 has a design flaw, that has to be over come. Double-standard much?
I also have issue with your list of "flaws". The only SERIOUS flaw is the aux/dist gear. The rest are all things that were fixed in the production runs, or a problem with EVERY EEC 4 vehicle. Slider cams wiping lobes is not a common thing, the TFI/PIP thing is an issue on every Ford with that system, so it's not just a 2.3 thing, Heads cracked due to overheating, which is due to poor maintenance, not a design flaw. The E3 thing is just a grasping a straws, it was a resolved issue from the factory. Pistons "breaking"?? Seriously? The early carbed ones yes, the later EFI ones, no. Fuel rails leaking? Again rare and could happen on any application. PCV system failing? Perhaps it's not adequate, but that is just another "flaw that has to be overcome".
I guess you can talk yourself into anything if you want, but you're grasping here for a lot of those to try and make a point.
Post by: 20th anny 5.o on January 28, 2008, 07:37:59 PM
Don't the stock heads on the SO 302 also have a design flaw , one that starves the 8th cylinder of air?
Post by: V8Demon on January 28, 2008, 07:56:51 PM
Quote from: 20th anny 5.o;200563
Not just limited to SO's.....HO's had it too....Was an intake issue.
Title: Come pick on ME
Post by: MrBill88Tbird on January 28, 2008, 08:05:37 PM
My 2.3 was in a PINTO! LOL Talk about design flaws, good thing I took out the stock gas tank and installed a fuel cell.
BTW, I came close to building a sleeper Pinto with the 2.3:shakeass:
My 2.3 ran over 7 full seasons from 5500 to 7200rpm Yes it was only 200hp but I love that engine!!!!
Here is my old school 5.0 actually 289 bored 40 over circa 1979 (http://img.photobucket.com/albums/v173/kingcars/Billscar.jpg)
My 2.3 experience circa 1994 (http://img.photobucket.com/albums/v173/kingcars/Meandtheracecar.jpg)
Our modern 5.0 project (http://img.photobucket.com/albums/v173/kingcars/recentpic1.jpg)
the other 5.0 (pos) (http://img.photobucket.com/albums/v173/kingcars/transam004.jpg)
The 6.3 aka my beast!!! (http://img.photobucket.com/albums/v173/kingcars/NewChevellePics004.jpg)
All of these cars have brought me countless hours of grief, aggravation, blood, sweat and tears.and many fond memories and TONS of Fun. This is why it is a Hobby, it's our escape and our pleasure. Let's just enjoy it!!!!
Post by: jlewis05 on January 28, 2008, 08:36:42 PM
Nowhere Michael have you said yes or no about using a wideband, if you weren't using one then forget it, nothing you say can be valid when it comes to what did or didn't blow up.
It's not rocket science, if a 2.3 detonates under higher power levels it will likely blow. If the aux shaft does not break in properly, has a defect, you run the wrong oil in cold weather, or run a high volume pump, it is more likely to fail. It's a high power density engine and so things happen, parts break, if you can't handle that then stick to what works for you and quit all this arguing.
Essy makes parts to fix the problems, billet aux shaft which is honestly well worth the money if you want to race. You can't skimp on parts that increase reliability when it comes to a turbo engine. Head cracking? Get an Essy head for 1500, bolt it on and do the math on the HP/dollar, or if you have the time and desire do a Volvo head, either is a big improvement over stock without the cracking problems.
Post by: P71 on January 28, 2008, 08:49:14 PM
Quote from: Chuck W;200554
Ummmm, no? I was pointing out that the AMC engine had design flaws, just like the 2.3. It's a bad thing and it just has to be dealt with.
And you're pretty annoying. It took Ford FOUR YEARS to fix the cracking E3, and the E6 sure isn't the most "un-crackable" item ever. How many fuel rails are in the "Wanted" section every month on TF? Seriously Chuck, the 2.3 is not a "God" motor and it DOES have problems. There's a reason nobody has good fuel rails in stock (or aux gears, or 87/88 TC clutch forks, etc, etc). Come on man. It's a debate not a race for a winner.
Post by: CougarSE on January 28, 2008, 08:50:53 PM
Well looky here, more ABM bitching about Ford engines.
Hey here is a great site. http://www.ls1.com/forums/ How about you get the **** out of here and go circle jerk the rest of your LSX buddies? Appears they are looking for a good pivot man.
Post by: P71 on January 28, 2008, 08:53:28 PM
Quote from: jlewis05;200574
I've never claimed nor used a WB. Then again neither has Bob (martin0660), Frank (turbo83coupe) or anybody that raced before 2002. Come on man, get real. $1500 buys a wicked set of 5.0 heads vs 1 2.3 head that's only marginally better out-of-the-box then stock?
The aux shaft fails for no reason. Some guys get 200K out of them, some don't last a week. It's a design flaw.
Post by: P71 on January 28, 2008, 08:53:56 PM
Quote from: CougarSE;200580
WTF is your problem?
Post by: kingcars on January 28, 2008, 08:57:24 PM
Wow don't let this thread get ugly again...
Cmon guys, ABM (and mostly everyone else) has been just saying it how he sees it. It has nothing to do with manufacterer.
Post by: SLEEPER T-BIRD 87 on January 28, 2008, 08:59:12 PM
Quote from: kingcars;200589
Post by: CougarSE on January 28, 2008, 08:59:49 PM
No one here gives a flying shiznit about an LSX engine. If an LSX had a dick ABM would be all over it.
Post by: MrBill88Tbird on January 28, 2008, 09:01:57 PM
Like I said, come pick on me!!!!! Lets throw my pinto into the mix :shakeass:
Post by: Thunder Chicken on January 28, 2008, 09:04:12 PM
I think SO 5.0's have a design flaw that deprives all 8 cylinders of air. How else could you explain 155 horses from a V8?
As for the "bolt-on VS major mod" debate: I personally consider everything from the deck up a "bolt-on", plus the cam. Yes, they do completely change the nature of the engine, but the parts are still bolt-on parts that can be changed in a day, or at track side. Anything else (crank/rods/pistons/block) ain't a bolt on, they're an overhaul...
Post by: SLEEPER T-BIRD 87 on January 28, 2008, 09:08:05 PM
Quote from: Thunder Chicken;200595
I think SO 5.0's have a design flaw that deprives all 8 cylinders of air. How else could you explain 155 horses from a V8?...
I can think of worse cough 255 ;) and the 221 v8
Post by: jlewis05 on January 28, 2008, 09:30:38 PM
Quote from: Aerobird Motorsports;200584
Yeah, and I disagree with them on that probably, because the wideband is tuning for the masses and I think it's the way to go now. Bob has tons of experience. Frank has gleaned a lot from Bob so that explains that. In the days before widebands we had EGT which was not a substitute but could keep you from "melting the mill", also reading the plugs, which some people still stand by if you know how to do it well. Bob also has only used T3 turbos to my knowledge and has managed to go amazingly fast with it. With a T3 and jacked fuel pressure, yeah the stock fuel management can work. Get into 50 trim territory and really crank it up and you need to rethink your whole engine management system. I love standalones, they make life so easy and change the way the engine works so dramatically.
I don't have positive things to show for all the different work I've done, the pieces have never fallen quite right for me and I have other obligations, but I know the ins and outs and problems with these engines and can honestly say I've examined lots of other options and still consider the 2.3T one of my favorites, the only other thing by Ford I'd consider going with is the 4.6 DOHC for any current projects of mine, and even that I wish I could do turbocharged but it's quite expensive.
I'll be honest and say a stock TC engine isn't all that impressive, it has a big torque hit and then instantly chokes. My first ride in my white TC was with an engine I rebuilt and prepped the way I thought was best and it made all the difference over the stock TC (as I got to drive one later). It's easy to poke fun at a stock TC's times and forget just how big of a difference the intake, exhaust, extra boost makes, but also I went farther and did porting and a cam, and that truly made all the difference. Unless you do a big valve ported head, the stock ranger cam just doesn't cut it, it's lame.
Post by: kingcars on January 28, 2008, 09:45:10 PM
Quote from: CougarSE;200592
You're acting very bitter...what's your problem? I haven't seen any LSx fanboy-ism from anyone in here...
Post by: P71 on January 28, 2008, 10:30:31 PM
You need a timeout *******.
Yeah, because somebody that owns two 302's, an AMC 401, a Pontiac 3800, two 2.3T's, and a 4.6 2V is an LSx "fan boy". Please. Get over yourself. I like a lot of engines, hence the diversity, something you know nothing of. Now go away, you're annoying me.
Post by: P71 on January 28, 2008, 10:36:59 PM
Quote from: jlewis05;200599
I like a lot of what you have to say. WB's are definitely the way of the future, especially now that they are affordable for the masses. That may have helped my setup immensely. I also agree on the stand-alones, although I don't think the market is quite there yet (yes, MS is awesome, but for people who suck at wiring it's not viable). I think in another year or two we'll be singing a different song though, and "bolt-in" stand-alones will be par.
I am giving the 2.3T another shot on this engine I'm building for DW, but I swear I'm keeping it under "that line" and doing as much as I can with it there. We will be drag testing it and dyno-tuning it so hopefully we can lay down some decent #'s on the LA3/35#s/VAM.
I think your last paragraph speaks a lot of truth (cam especially). And while the TC (or So 5.0, or hell even the HO 5.0) seem "lame" compared to cars of today (300HP 3V Mustang, 400HP GTO, 303HP FWD Grand Prix, etc, etc) they are still fun drives. I still smile when I see one on the road (V6's included) and taking a nice one for a cruise is a treat to be enjoyed.
Post by: CougarSE on January 28, 2008, 10:47:36 PM
No diversity huh? Might seem that way since I don't preach my life here like yourself. What you consider diverse is very narrow to what I have in my garage.
Post by: SLEEPER T-BIRD 87 on January 28, 2008, 10:56:16 PM
Quote from: Aerobird Motorsports;200622
LA3/35#s/VAM.
3 of things that limit power the most.
Post by: P71 on January 28, 2008, 11:00:45 PM
Quote from: CougarSE;200629
Prove it.
Post by: P71 on January 28, 2008, 11:01:26 PM
Quote from: SLEEPER T-BIRD 87;200632
Well, when you're going for 100pt Concourse correct under the hood, there's limitations :evilgrin:
Post by: SLEEPER T-BIRD 87 on January 28, 2008, 11:03:57 PM
Quote from: Aerobird Motorsports;200640
fake vam, GN compressor and wheel,aftermarket injectors painted to look like brown tops and megasquirt :D theres ways around it
Post by: P71 on January 29, 2008, 12:06:32 AM
You are seeing where we're going :D But the VAM will be real. .454 slider cam, Essy gear behind the timing cover, 3" downpipe, T3 hidden behind the A/C compressor, Bob's gutted/ported intakes, ported E6, etc, etc. All hidden behind a clear-powdercoated and painted 100% stock looking 2.3T.
Post by: turbo83coupe on January 29, 2008, 12:39:17 AM
I personally have never had an engine management system because I dont even have all my dang parts on the car yet (my fault), and there are more things like maintanance, or cheaper go fast parts to be bought on a budget. Some sort of engine management will be bought in the future!! One big reason that I like my 2.3 is because it is different!! You dont see one everyday! It also gets decent gas mileage to boot, which is nice. I dont care what ANYBODY says, if you keep up on the maintanance, and build the thing right, it CAN and WILL be strong/reliable!! There is soo much more than just throwing parts at it, I think that point has been proven already however... BTW, whats the heck is a 5.0?? :flip: :shakeass:
Frank M.
Post by: Innes on January 29, 2008, 12:41:50 AM
HOLY SMACK 165 post in 2 days gotta admit I did read them all yet but it is interesting
I am a V8 guy and did own a turbo coupe year’s back friend of mine now has the motor (not goanna get into that story). But what’s the weight difference between the 5.0 and the 2.3 and weight ratio from front to rear wheels. I’m sure that might be a plus 1 for the 2.3 side.
Post by: turbo83coupe on January 29, 2008, 12:53:01 AM
I dont have actual numbers, but I am pretty sure the 2.3 is a PIG!! And may actually be heavier with an iron head, could be wrong....
Post by: Innes on January 29, 2008, 01:32:52 AM
Quote from: turbo83coupe;200693
Come on it can’t be heavier I thought that was part of the reason of the T/C wonderful handling.
Post by: 1WLD BRD on January 29, 2008, 02:20:11 AM
i think a fully loaded tc is actually about the same weight as a 5.0L bird... dunno.... all the extra they put on the tc added weight....
Post by: Chuck W on January 29, 2008, 07:00:07 AM
A fully-dressed 2.3T is only 50-60# lighter than an iron-headed 5.0.
It sits back farther though for better weight distribution.
Post by: V8Demon on January 29, 2008, 07:36:28 AM
I laughed at this!
So my Twisted Wedge headed 5.0 is about the same weight as a 2.3?!:eek:
Post by: gumby on January 29, 2008, 07:50:56 AM
Quote from: V8Demon;200705
yup. as chuck stated, the advantage is in the position of the weight. the accessories on a 2.3 are also tucked back, more next to the motor, rather than hangin off the front.
Post by: Chuck W on January 29, 2008, 08:18:49 AM
Quote from: Aerobird Motorsports;200579
Get over yourself Michael. I think you trump me in the annoying category anyway, so I wouldn't go down that road if I were you.
I never said the 2.3 was a "god" motor, but neither is the 5.0 or even the LSX stuff. I admitted to the things that were actually "faults". Hell, I'm not even going to have a 2.3T-powered car eventually most likely, but it's not because it's so terrible. It's due to the fact that I have been messing with them for 15 years and I want to do something else. If I had room, etc for another car I'd sure have another.
There's a reason you see alot of those parts popping up in the "wanted" section. The main reason, which is the same with every other Ford product, they were abandoned by Ford. The difference between the 2.3 and the 5.0 is that the mass aftermarket has taken ahold of the 5.0 and the 2.3 has been the stuff of the cottage-industry aftermarket. There is a difference. You just can't find new clutch forks, etc as they just aren't made any more, so folks have to try and find good used parts when they wear out. Don't blame the 2.3T, blame Ford, or blame the V8-happy american car buyer.
I have never seen or had a fuel rail leak, and the only reason I've needed one was for an intake swap, or I needed to swap that or the fittings on the lines. Also, a lot of guys are looking for inline fuel rails because they are builing their own upper on the old inline lower. They all aren't needing them because they are pumping gas all over the place.
Like I said, you can try and talk yourself into the "fact" that the 2.3T is so terrible if that's what you need to do to feel better about moving onto something else, but don't sit there and call me annoying for not humping your leg and agreeing with you 100%.
Post by: oldraven on January 29, 2008, 09:00:16 AM
There's this concept of 'speak for yourself'. Try it some time. So your contribution to this thread is to be an even bigger shiznit disturber than anyone else? Good job.
Go outside and take a breath of air, Ford fanboy. If you can't appreciate anything, no matter how good, from anyone other than Ford, I feel very sorry for you. You're missing out on a lot.
Post by: CougarSE on January 29, 2008, 09:30:03 AM
Ford Fanboy Eh? So I can't appreciate anything other than Ford? I guess the 5 350 engines, two TPI engines and 454 in the garage down at the farm are Ford engines? Another uninformed person passing judgment. I guess my 73 Nova is a Ford, my 80 K10 is a Ford and shiznit all the Dodges I've worked on have been Fords. My current Nova is my fourth Nova.
Post by: oldraven on January 29, 2008, 09:42:36 AM
Then why freak out when someone talks about an LS engine, then tell them to go over to an LS board to talk about it? If he has a valid point about a good engine, why piss and moan? Taking a shiznit on a message board because you don't like someone's comments, that you can't argue with, makes you look like a bit of a joke.
I'm not getting sucked into these g matches. Some of you guys are just acting like four year-olds and need to get your shiznit together. You're enthusiasts? Act like it.
Post by: jlewis05 on January 29, 2008, 09:58:02 AM
I had a fuel rail start spraying fuel out under the FPR, directly out of the side of the rail, so it can happen apparently, it was either a porosity in the rail that opened up or it fatigued from fuel pressure or vibration somehow, but these rails are constructed just the same way as any 5.0 or other Ford rail of that era. I could never find any crack in the rail and it definitely wasn't a gasket or o-ring leak, could've been a crack so small I couldn't see. I really think this is a rarity though, I haven't heard of many cracking, and jacked fuel pressure doesn't help I'm sure.
Post by: TurboCoupe50 on January 29, 2008, 11:16:22 AM
Never had a fuel rail leak, but I've seen 6-8 injectors g fuel from between the body and plastic top... All but one were brown top 35lb turbo injectors... The last was a 14lb SO 5.0 inj in the old '86 Grand Marquis...
None leaked when hot, but three or four poured when cold, including the SO inj(fuel puddled on the intake)... I bought a set of 35lb at the junk yard(one of those leaked), cause I used up the ones from the 2.3 out of my white Bird...
Post by: martin0660 on January 29, 2008, 10:52:55 PM
EXACTLY. The auxilary shaft is just fine as long as its installed right in the first place, doesnt have the extra load of high volume or high pressure pumps, or SAE 50 weight oil.
Again, for some reason you think you know my junk. I have been running a wideband on mine for the last two seasons. It confirmed a lot of what I am/was doing as right, also exposed why some things worked like they did for me. With Tweecer, a wideband and my Innovate datalogging, I pretty much know whats going on. What would surprise everyone is knowing how close to stock my junk really is.
Indeed I have a little experience with this junk. It's my fasination, it keeps me into racing. I can assure you, a 347 would be easier, but it really those guys off when a 2.3, 5 speed, street driven cars takes them out heads up, let alone bracket racing. I can assure you, I would have lost interest a long time ago with a windsor based engine, but thats just me.
/rant / BTW - Frank is friend of mine, and will help him any way possible, but...... I WILL NOT, nor have I, done it for him. I try and keep him on the right path, but its his deal, and I'm making him learn the way I did. It actually gets frustrating to sit back and watch him learn (and make mistakes) but I can assure you, if I'm not around any more, he will know how to make his junk run too. I geuss I dont want everyone to think Franks stuff is my doing. /end rant/
You are correct. I have only ever run T3's, sometimes there might be an IHI on there when I'm in between JY turbo's. As Mike likes to point out, I've fragged quite a few of them, but all of them where junk yard parts with unknown history. Hell, i've put them on, and broke them within an hour trying to set the boost :D Since i bought a rebuild with 360 bearing and good parts, its been bulletproof.
Bob Myers
Post by: P71 on January 29, 2008, 10:58:23 PM
Bob, We're talking about your TC, which never ran a WB to your own claim. The Capri is not in this conversation *sigh*.
Post by: daboss351 on January 29, 2008, 11:11:29 PM
Quote from: martin0660;200879
Bob Myers
lol just to be a ball buster like this one bob! (http://i31.photobucket.com/albums/c384/boss3512/lincolnnew099.jpg)
Post by: daboss351 on January 29, 2008, 11:14:51 PM
but seriously guys if your gonna dispute the engines fine, Stop with the personal shots. Its the freaking internet....
Post by: turbo83coupe on January 30, 2008, 12:22:23 AM
Quote from: Aerobird Motorsports;200882
When I initially broght Bob into this several posts back saying I knew about a well over 300hp 2.3, I was not talking about his TC, I was meaning the Capri. I can vouch fo rthe fact that the Capri could run without the Tweecer in it. That is pretty much the SAME setup that his TC was!! Just a big front mount now and a few other SMALL odds and ends.....
Frank was talking about my old TC and current Capri combo. Both cars where (TC) and are (Capri) daily drivers, ......... Anyone that has seen my cars at the track knows I drive them like rental cars, Neither ever left me stuck aywhere on the street, and I would (and have) driven either of them anywhere.
Bob Myers
He is not hiding a thing, its what he says it is. A daily driven, 12 sec ride with no dyno time. For what it is, I would consider it rather reliable!!
Post by: oldraven on January 30, 2008, 07:22:11 AM
I thought the conversation was about the 2.3 turbo.
Post by: Chuck W on January 30, 2008, 07:40:36 AM
Quote from: oldraven;200932
It is.....
Post by: P71 on January 30, 2008, 08:51:31 AM
I don't know anything about his Capri so I was speaking about his TC. If his Capri is sorted with the Tweecer/etc and goes faster then the baseline TC engine setup all the better. All I've heard about the Capri was a serious of JY T3's blew, a shortblock blew, and then when it all got buttoned back up something happened to the rear axle. Last I heard it still hasn't gone any faster then the "baseline" setup, though the tracks are closed ;)
Post by: LittleAngel1198 on January 30, 2008, 12:16:53 PM
dayum 19 pages of this stuff??? And guys complain that women have drama! :rollin:
your calling a technical thread about two different engines drama? So what's your experience on either of these engines.... good or bad?:hick: :shakeass:
Post by: LittleAngel1198 on January 30, 2008, 12:57:04 PM
No, I'm calling the bitching about which one is better and who knows more about each of them "drama". The discussion about the engines is cool, however, the name calling, the ''you don't know anything because of your age" stuff is BS. There are 19 pages of the same thing being said over and over again..... drama.
Now, RJ don't be hatin'! ;)
Post by: 1WLD BRD on January 31, 2008, 12:08:04 AM
Quote from: LittleAngel1198;200985
yeah that the 2.3 sucks...
I aint hating... its a fact.. ;):shakeass:
Post by: Carpimp1987 on January 31, 2008, 02:03:46 AM
it i don't want to hear it project Twin Turbo TC coming sometime the year or next. I want a new project and i will have a V8 for a DD if the TC breaks down.
Post by: oldraven on January 31, 2008, 07:10:26 AM
Quote from: 1WLD BRD;201122
Well, the compressor side of the turbo sucks. That's how they work. The air has to come from somewhere. Sheesh.
Post by: tc² on January 31, 2008, 08:31:13 AM
:shakeass:
Post by: P71 on January 31, 2008, 09:33:36 AM
Quote from: oldraven;201135
Best. Explanation. EVER. :hick:
Post by: stuntmannick on January 31, 2008, 10:37:09 AM
So the argument is which engine sucks more while sucking less?
Post by: oldraven on January 31, 2008, 12:20:54 PM
Quote from: stuntmannick;201160
Since the 2.3T isn't running on vacuum under load, I'd say it's the 5.0L that's sucks more. :hick:
Post by: TurboCoupe50 on January 31, 2008, 12:30:06 PM
Quote from: oldraven;201172
And that's a hard one to argue with...
Post by: V8Demon on January 31, 2008, 03:30:38 PM
The 2.3 swallows a lot for it's size though:hick:
Post by: ZondaC12 on January 31, 2008, 04:00:27 PM
Well at least BOTH swallow and neither....uh nevermind lets not go there :giggle:
Post by: Kitz Kat on January 31, 2008, 04:05:26 PM
Quote from: V8Demon;201199
Then shiznits it self. First and last post on this one.
Post by: V8Demon on January 31, 2008, 05:50:14 PM
No cuddling afterwards!
Post by: Tbird232ci on January 31, 2008, 06:16:13 PM
Quote from: V8Demon;201225
You gotta cuddle with the 2.3L, we all know how they don't like to be shut off hot.
Post by: V8Demon on January 31, 2008, 07:02:28 PM
That's different.....If you shut me off while I'm hot certain parts turn blue.
Post by: Haystack on January 31, 2008, 10:36:04 PM
5.0's more fun... Or so I'll say only owning two v-8's and two v-6 cougars thus far...
However, I am building my new tbird motor as a 5.0, not the v-6.
Really I guess I just wanted to say that the v-6 sucks.
Post by: oldraven on February 01, 2008, 07:25:02 AM
Quote from: V8Demon;201238
You're lucky you're not a 2.3T, and those 'certain parts' don't crack. :eek:
Post by: chri85tc on February 01, 2008, 05:12:27 PM
So this thread is still running ?
Oh well to backup my original post, Aero, you are probably correct as I did a leak down test, 18% loss. Therefore 700 miles later I may or may not have broken rings. Unless of course they are not seated.
At any rate 2 TFI's later and 3 PIP's the car now runs all out with no issues in the upper gears...smooth boost all the way up to 22 PSI. Guess it was an Ignition issue. (Motorcraft Parts were used, Echlin TFI worked, and the Motorcraft PIP)
I have connected 2 Valves to the IC pipes (BPV at the lower end and BOV right before the throttle body) This has almost completely stopped the Trailer Hitching I experianced when I let of the throttle.
So now I will beat the living out of it till it piss's me off again, and see if the rings seat. Or blow it up whichever comes first.
Then I will drop in the 165,000 mile bottom end in and see how long that lasts.
Then I will go V8, maybe something big, I havent decided yet....Hmmmmm
Post by: P71 on February 01, 2008, 05:18:52 PM
They seated, then broke. It's the tenth or so one I've heard about in the last 2 years (and at least 7, including my engine, were confirmed). I honestly think they're might be a manufacturing problem. What brand/part # rings are they?
Beat on it, but it's going to blow oil everywhere like the Valdez.
Post by: chri85tc on February 01, 2008, 06:30:40 PM
The rings are Perfect Circle, of which I believe are made by Mahle.
Yeah it is blowing oil all over, I am rigging up a pcv from under the lower intake to run into a catch can and then into the front of the turbo. Blocking off the port in the upper. for now.
thing leaving oil stains everywhere.........
Post by: P71 on February 01, 2008, 06:55:09 PM
Grab the Summit branded catch can. I ran a hose from the valve cover (aftermarket Esslinger one, it had no breather hole but a tapped hole in front) to the can and one from the PVC to the can (blocked off the intake fitting).
Perfect Circle's are made by Mahle, and that's what I used as well (Mahle bearings too).
Post by: Tbird232ci on February 02, 2008, 10:24:25 AM
I used to have some nasty blowby issues until I set up a catch can than ran back to the intake.
What I did, is threaded a brass barb fitting into where the factory breather/oil separator was on the valve cover, then ran a 3/8" hose to a catch can I bought off of ebay, then ran a 3/8" hose from the catch can, to the intake, between the turbo and the VAM. In the hose that runs to the intake, I put a check valve to only allow air to suck into the intake.
Heres the reason, it may get a bit long.
The PCV system is designed to eliminate pressure from the crankcase. The PCV valve is nothing more than a check valve that only allows suction to occur in the crankcase when the engine is under vacuum . While this works on N/A vehicles, he have a problem, under boost, we have no place to get vacuum from...other than the inlet side of the turbo. Now what makes my particular setup work well, is the check valve between the catch can and the intake. What happens is, while you're under vacuum, (idle, partial throttle), the intake manifold will be sucking from just the crankcase, and under boost, the PVC valve closes, the check valve for the catch can opens, and the turbo inlet creates suction in the crankcase.
This worked very well for me, it eliminated a lot of my blowby/smoking issues, and still keeps my intake clean.
A lot of guys stuff them with steel wool, which is a good idea for keeping the oil in the can, sometimes you'll get oil vapor passing through, but steel wool makes me weary.
Post by: P71 on February 02, 2008, 10:41:06 AM
Sounds like a good setup. I ran the plastic Summit can with a drain valve and just drained the residue whenever I saw it fill up.
Post by: chri85tc on February 02, 2008, 02:04:18 PM
I was thinking about doing something like that too. Could I use a PCV in the same way as the check valve , only have it run to the catch can from below the factory PCV set-up and then to the turbo inlet with a PCV in line to the inlet ? So when it is under boost it will not blow into the crankcase, but will still create a vacuum thru the inlet?
I hope this makes sense.
Post by: Chuck W on February 02, 2008, 02:46:11 PM
When the ring on the #4 broke in mine, it was smoking out the breather and even out the catch-can breather pretty badly.
My breather is set up with a slight vacuum on it from the turbo inlet like you mentioned, but that did nothing to solve the blow-by issue. Mine only stopped blowing out the breather once I swapped the shortblock. The teardown of the old bottom end revealed the rings on the #4 were in about 15 pieces.
Did you do a compression test as well when you did the leakdown?
Post by: P71 on February 02, 2008, 03:02:49 PM
Yours was a stock ring right Chuck?
Post by: chri85tc on February 02, 2008, 04:13:38 PM
No I havent done the compression test yet. The car is at my Friends shop, didnt have a chance yet. He wanted to do the leakdown test first because he said it is more accurate. Well I still want to do the Compression test too.
I also am working on my other shortblock(stock bore, stock pistons, just a hone job), just in case.
Post by: SLEEPER T-BIRD 87 on February 02, 2008, 07:15:35 PM
Quote from: Chuck W;201676
I can only imagine what the ones in the stock 2.3 shortblock i took out of my bird look like. it blew oil out of ever single seal except the cam seal and valve cover when in boost :D
Post by: Chuck W on February 03, 2008, 10:30:32 AM
Quote from: Aerobird Motorsports;201678
No, they were TS Gapless...before TS decided that they didn't have any rings that would work for a boosted application. Thanks guys....I got 30-35K of hard miles out of them though before they finally let go.
Post by: P71 on February 03, 2008, 12:27:18 PM
Was it the gapless ring that broke, or the other one?
Post by: turbo88 on February 03, 2008, 03:44:54 PM
Quote from: 1WLD BRD;200029
yawn , a stock reliable, or done up, unreliable turbo four... that is still slower then a mildly built 302... what century do you live in? very easy and cheap to drop an HO in it... last I checked they had a few more ponies then 140... even if he does swap in a SO 302.... at least it wont sound like a john deere...:hick:
My old man has put 300,000 miles on his 87 tc. never had to replace anything out of the ordinary ie. a few sensors,clutches and tune-up stuff, even had the original brake calipers o and it still beat a 3 series bmw from a light everytime back in 03. not to mention the 4 banger gets considerably better MPG especially on highway trips.
Throwing a 302 in it won't solve anything, all your doing is wasting your time and money especially if your keeping it a daily driver. Your sacrificing handling performance and fuel efficiency, keep in mind gas is over 3 bucks a gallon now a days. Its cheaper to stick with the 4 banger and OVERALL your gaining more performance. My point is theres tons of performance parts out there for these engines to make them every bit as fun as any v8 could be in a straight line.
If you take care of the 2.3 there a bullet proof engine, nearly indestructible. And as for the guy having problems in with his Turbo Coupe. Your car is over 20 years old, things are going to break.
Post by: turbo88 on February 03, 2008, 03:56:00 PM
Quote from: 1WLD BRD;200127
muhaha...... :evilgrin:..... notice nobody has said anything about the sound of them?.....
17psi, and you just barely got past the STOCK power of a 5.0L.... add 14 psi (VERY streetable and reliable) to a 5.0L and you double that number...
Ya after 4 grand for the turbo kit. strap on a t3/t4 turbo and run 17psi and your upwards of 280 plus hp at the crank for 500 bucks.
Post by: turbo88 on February 03, 2008, 04:27:10 PM
looks like i was 20 pages to late.
Post by: 1WLD BRD on February 03, 2008, 04:52:31 PM
Quote from: turbo88;201881
thanks for proving what I already said... cost wasn't the issue, I was getting at, it was the fact that it takes 17 psi to make just about the same amount of power as a near stock HO... add half that boost to a 5.0L and what do you get? TWICE the power for about the same price.... Ever hear of DIY twin turbo's? see this site... http://www.toohighpsi.com You can make a twin turbo 5.0L kit for about $1000 OR less...
and all the 17psi means, on your 4banger, is you need to upgrade you intake and exhaust system to take care of that huge restriction...
Post by: chri85tc on February 03, 2008, 04:54:37 PM
Originally Posted by turbo88 And as for the guy having problems with his Turbo Coupe. Your car is over 20 years old, things are going to break.
The car has been COMPLETELY overhauled, and I have replaced and traced every component, wire and hardware part you can think of.
It is just a matter of me getting the BUGS worked out. By the way I think I have it worked out, No More Trailer-Hitching, and The NEW PIP was bad.
Only have the Blow-By problem to work out. But I will get it done.
I have been working on over 20 year old cars my whole life since I was 8(I am 45), only this is my First Turbo Car. Probably my last, but I do love this thing, and it is not going to kick my ass !
Post by: P71 on February 03, 2008, 05:09:56 PM
Keep on it man! It's probably the rings, but who knows, like you said it could just have still not seated in.
The only advice I can really give is if the car starts to piss you off, take a huge breath and let it sit for a week. I couldn't do that as mine was my daily driver, but I honestly think I'd still have the car (and modifying it) if I had something else to drive or just flat had more patience (granted I did play with it for 3 years!).
Post by: chri85tc on February 03, 2008, 05:36:29 PM
I do have a couple other cars and The TC is not a daily Driver, was never intended to be.
But............. it is keeping me from starting my next project !
