Technical => Engine Tech => Topic started by: CatCarMan2012 on January 24, 2008, 11:55:45 PM
Title: 77 Ford F100 heads
Post by: CatCarMan2012 on January 24, 2008, 11:55:45 PM
Any idea what casting they might be and if they would be a worth wile swap on a SO 5.0?
Thanks,
DZ
Post by: TurboCoupe50 on January 25, 2008, 12:05:23 AM
Prob Be a D6 or maybe D7... Likely have huge combustion chambers to give 8.0-1 compression...
Except for the '69-'71 351 heads, no other common small block head is going to be as good as the E5AE/E5TE('85 HO & truck) or E7TE... Heads prior to '78 use a non adjustable stud type rocker setup...
Post by: CatCarMan2012 on January 25, 2008, 12:10:34 AM
Bummer.  Thanks.
Post by: thunderjet302 on January 25, 2008, 01:35:11 AM
Quote from: TurboCoupe50;199789
GT40 or GT40P iron heads are better than the E5 or E7 heads (though GT40P heads require special headers and neither GT40 or GT40P heads work with SO pistons:hick: ).
Post by: Nate on January 25, 2008, 11:09:37 AM
I don’t know if this makes since or not, but I’d try to stay away from any cylinder head from the late 60s up to now minus the aftermarket ones.  Isn't that when the fuel crises started all that fuel economy bs and they started playing with the heads/pistons to get low compression, or allot of turbulence in the head for better mpg? Anybody else? That’s just what I’ve been told for years here and there, but I don't have any actual hard evidence of it. This also makes me think it would be good to get a list of years that different engines had good heads… maybe I’m just talking out of my ass lol…
Post by: TurboCoupe50 on January 26, 2008, 06:31:13 PM
Quote from: thunderjet302;199794
You are correct, the later GT40s are the exceptioon...
I was kinda thinking old beater material...
Post by: thunderjet302 on January 26, 2008, 07:08:31 PM
Quote from: TurboCoupe50;200085
True. I got my GT40Ps brand new. They cost more than junkyard heads but cheaper than after market iron or aluminium heads (even with the spring upgrade for the cam).
You can pick up GT40 or GT40P heads for cheap off of 5.0 Explorers. The problem is finding a 5.0 Explorer as well as the fact that with out changing the pistons you're gonna smack some valves on a SO. On the cheap I'd go with E5 or E7 heads and port the bejesus out of them.
