Technical => Engine Tech => Topic started by: willywags05 on January 13, 2008, 06:58:54 PM
Title: block id
Post by: willywags05 on January 13, 2008, 06:58:54 PM
does anyone know d9ae 6015 ed 20    9a29?? help think is a 351w
Title: block id
Post by: TurboCoupe50 on January 13, 2008, 08:28:41 PM
A D9 block is '79
Measure the main bearings, the 351 is 3", the 302 is 2.25"...
Title: block id
Post by: SLEEPER T-BIRD 87 on January 13, 2008, 09:44:27 PM
the 351W is 2" wider then a 302 at the heads
It will also be stamped 351W in the valley
Title: block id
Post by: HAVI on January 13, 2008, 10:00:49 PM
January 29th, 1979.  6015 is a basic block casting number.  You will likely need to visually ID it by what was already said.  A crankshaft will have something like 3M stamped on it, a 302 will have 2M stamped on it.
Title: block id
Post by: willywags05 on January 14, 2008, 09:54:45 PM
thank guys
