Technical => Body/Appearance/Interior => Topic started by: BEARMAX on December 23, 2007, 08:29:08 PM
Title: Tail Light Mod
Post by: BEARMAX on December 23, 2007, 08:29:08 PM
i just had to try this and i think it look s sweet
and no the tc header isnt staying but the bumper may
Post by: V8Demon on December 23, 2007, 08:56:46 PM
That bumper with the Cougar header will look pimp.
Post by: slamedcat on December 23, 2007, 09:29:42 PM
Quote from: V8Demon;194162
Yes, Yes it does. I like that look on the tail lights but how visible are they from a distance?
(http://i144.photobucket.com/albums/r170/slamedcat/vbgarage.jpg)
Post by: tc² on December 24, 2007, 12:13:34 AM
I didn't know your car had side pipes... Pretty sweet.  You should take the T-Bird emblem out, bondo in the hole and stick a C-Pillar Cougar emblem there.
Post by: cougarman on December 24, 2007, 08:33:09 AM
why yes it does. :D
Post by: BEARMAX on December 24, 2007, 10:38:37 PM
i see you didnt trim the grill i hope i dont half to trim mine
cougarman is that the car car i did the dalorian photo shop to a wile ago and why is it in the graveyard
Post by: Clayton on December 24, 2007, 11:11:43 PM
he still has that front airdam
:D
Post by: daminc on December 24, 2007, 11:29:01 PM
As I'm looking at the back lights, a thought just popped up.
Is it possible to somehow use the center strip as a running light and the lens around it as brake and turn signal only lights?
mabe LEDs somehow inside the center strip?
Post by: BEARMAX on December 25, 2007, 02:54:38 AM
Quote from: daminc;194337
ya know that would be sweet but i think that would requir adding 4 more light sockets 2 on top and 2 on bottom pluse the center ones ..also u would half to close the center bar off from the inside so all the lights dont run together so id say it may be plauseable
Post by: t3skidoo on December 25, 2007, 03:13:21 PM
What are the dimensions of that center trim piece in the tail light?
daminc,
I think it would be easy* to do  without adding light sockets if you used LEDs.  You might have to modify or ditch the back half of the light, and maybe modify the lense.  I haven't had one apart so am not sure what they look like.  Maybe you could use something like this
http://www.lck-led.com/index.php/cPath/39_114_56
down the middle for running lights, and use the factory incandescent configuration for the brake lights.
* famous last words
Post by: daminc on December 27, 2007, 01:12:20 PM
I was looking at the tail lights and I think it will be real easy to do.
I didn't realize that the strip in the middle was painted on. It'll buff right off. It should work OK with the LEDs from that site. just have to cut the back of the lens off to work inside. Mabe when I take them out In a couple of weeks I'll fiddle with them. Should probably keep the side lens as a driving lamp also
