Technical => Engine Tech => Topic started by: thunderjet302 on December 11, 2007, 04:34:21 PM
Title: Spark plug wire routing for 5.0s
Post by: thunderjet302 on December 11, 2007, 04:34:21 PM
This is for both the SO and HO motors. This is important as I will atest that on my old SO I had a spark knock problem and tried this TSB and it fixed it. You need to route your wires like this or you will get a miss fire on a few cylinders. It even does it through good wires (ie Ford Racing 9mm wires). Just a tech tipe for you 5.0 guys :D
http://351winsor.com/joel/EEC-IV/SparkWires_Routing.JPG
Post by: Kitz Kat on December 11, 2007, 04:51:08 PM
Might be me but I couldn't read the link.
Post by: Innes on December 11, 2007, 04:51:54 PM
Interesting but I never had a problem before and I had many 5.0 SO & HO.
Good to know though if a problem incurs
Post by: thunderjet302 on December 11, 2007, 04:53:25 PM
Works for me. Try going to the lower right hand corner of the image and a little box with green arrows should show up. Click it and it and the picture becomes really big :D
Post by: Beau on December 11, 2007, 05:56:00 PM
Works with Mozilla...
Anyone notice the URL...
http://351winsor.com/joel/EEC-IV/SparkWires_Routing.JPG (http://"http://351winsor.com/joel/EEC-IV/SparkWires_Routing.JPG")
LOL :hick:
And that's a common tip for 5.0 engines, "crossfiring"...
My truck ran shiznitty bad, I realized the issue, and adjusted the plug wires and fixed it.
Also, good quality wires will help.
Post by: thunderjet302 on December 11, 2007, 06:52:48 PM
Quote from: FordTruckFreeek;192257
LOL :hick:
I noticed. I thought the 351Ws were [COLOR="Red"]Windsors[/COLOR] ;) . Good wires go a long way to prevent this but even with good wires it can happen. Now with py wires (ie Champion) you better use the TSB as a guide to route your wires :hick:
Post by: grutinator on December 11, 2007, 10:01:39 PM
i know those LT1 are notorious for having misfires and such from not routing wires correctly. but i never understood how wires got to be such a mess, if you put them in thier holders, keep them looking nice and neat and dont loop any wires around eachother you wont have any problems. i hate it when people dont take the extra 5 minutes to make it look nice. and it CAN effect performance. not so much in a lower voltage spark like our cars, but c'mon, it is worth for both the appearance and added reliabilty/performance
Post by: ZondaC12 on December 11, 2007, 10:41:22 PM
I got rid of those little plastic clip brackets, I just have all the wires going to each side just kinda globbed together, just sitting there loosely :hick:  I did it to make them easier to work with and remove 1 or 2 or whatever without having to unclip the brackets, not easy to do it quickly with just ur bare hands, it takes some force and I'm lazy :hick:.
No problems here but good to consider!
Post by: thunderjet302 on December 12, 2007, 12:07:49 AM
Wow you are lazy ;)  All it takes to unclip the wire holders is a small screw driver.
