i need a MAF automatic computer and all the wiring i need to make it work.
Just get the plug from a wreckers and some wiring from the hardware store,solder and heatshrink all connections,no need to change out the whole harness which would be even more work.
A9P is the best auto maf computer to get,it's what i run in my car and it has the most aggressive timing curves.
They can be easily got off ebay or the corral for around 100bucks.
Do not get an A9L(stick puter) as you may have stalling issues with the auto and the A9P will work on both.
I use the A9P as well.Awesome.I have a plug if you need it.Let em know and shoot me your address and I'll get it to you.If you watch Ebay,there are occassionaly good deals on a computer if your patient.Also,check the boneyards.
i have the wiring conversion harness and the a9l computer. let me know
