Well, I want to hook the the TV cable and I have a Holley 1850 with a kickdown shaft in it.
Does anyone else have this setup? I called Holley and they said they don't support the hookup to an AOD. So does anyone have any suggestions other than buying more stuff. I really want to get this project done this weekend. Any pics of your setup would be great.
Try Lokar...they have cables for AOD to carb setups
Well a post from masterblaster helped me out.
So now what i'm looking for is pics of a 5.0 cfi linkage. (stock) or how you've hooked up a holley to the tv rod.
betcha wish ya had the 83 there still dontcha?
that one peg behind the main throttle peice is for the kickdown via the cat
I agree with the guy about the TV (on the AOD ). I a 1983 t-bird with a 302 and an AOD in it.And the TV rod is original to the car.
Well folks, could you please explain a little more where the hookup is.
Blackjack I don't know which point you're talking about.
heres what i did to my truck when i put the 500 holley on it. i used a holley choke cable bracket to attach the tv rod to the linkage heres a couple of pics
