Technical => Engine Tech => Topic started by: billboehm on November 11, 2007, 02:54:38 AM
Title: Bad egr valve
Post by: billboehm on November 11, 2007, 02:54:38 AM
my check engine light is on. the guy at autohole used his reader and told me it was the egr valve and cleaning it might do. what do you guys think? if it does need to be swapped, will the one on my 3.6 v6 work? i have a 4.6 v8, just hoping such a small part would be interchangeable.
Post by: softtouch on November 11, 2007, 06:37:24 PM
My 01 Grand Marquis had a code P0401, EGR flow insufficient.
The problem was the "tube mounted EGR pressure sensor".
Part # 9J460
Ford extended the warranty on this part for an additional two years or 24k miles because "the component has recently been improved upon".
Post by: billboehm on November 12, 2007, 12:25:23 AM
Well my question was would i have to replace it or could i just clean it out. $40 parts that don't do much really irritate me.
Post by: softtouch on November 12, 2007, 12:49:33 AM
If needing cleaning is what the problem is, cleaning will fix it.
Post by: billboehm on November 12, 2007, 08:16:50 AM
is it likely that that's all it is though?
