General => General Fox T-Bird/Cougar Discussion => Topic started by: Beau on November 01, 2007, 11:02:49 PM
Title: 32VFoxBird...I gotta ask ya...
Post by: Beau on November 01, 2007, 11:02:49 PM
just what is the name and shade of that paint in your engine bay?
and what is the areas I've marked with the question marks for?
That's gonna look bad-ass when it's all done...You said something about a Navigator engine...would that be a 5.4? :evilgrin: :D (http://i94.photobucket.com/albums/l110/fordtruckfreeek/vehicle%20pics/motor2.jpg)
Post by: 32VFoxBird on November 02, 2007, 09:13:38 AM
the color is 03/04 mustang mach 1 azure blue. as far as the question marks in your pic, i dont know what you're asking me really. those spots are an open channel from the factory that i sealed off with sheet metal and bondo.
and yes, ive picked up a DOHC 5.4L navigator motor to use. http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=13726&stc=1&d=1193433555
Post by: ipsd on November 02, 2007, 11:45:45 AM
I guess the ? on the left would be the air box area, the ? on the right would be the battery area.
Post by: thunderjet302 on November 02, 2007, 05:54:45 PM
Quote from: 32VFoxBird;185903
Is that going to fit under the stock hood ;)
Post by: 32VFoxBird on November 02, 2007, 07:22:18 PM
Quote from: thunderjet302;185942
hell no. the 4.6 wasnt going to fit either.
Post by: jcassity on November 03, 2007, 01:23:41 AM
its got one cam per head right?  why is that called a dohc?
Post by: Beau on November 03, 2007, 03:41:27 AM
2 heads, 2 cams...dual...overhead..cams ;)
they tend to refer to the Cobra engines as 4-cammers..or quad cams
Post by: 32VFoxBird on November 03, 2007, 08:44:52 AM
DOHC means 2 cams per head.
Post by: thunderjet302 on November 03, 2007, 02:44:41 PM
Quote from: 32VFoxBird;185958
Well perfect time for a shaker hood a la 428 Cobra Jet style ;)
Post by: shame302 on November 04, 2007, 01:05:05 PM
DOHC = 2 cams in each head. each head has an intake and an exhaust cam. 4 cams total. 2 intake valves and 2 exhaust valves for each cylinder. 32 valve engine.
SOHC = 1 cam in each head. each head as one cam that handles both intake and exhaust. 2 cams total. 1 intake valve and 1 exhaust valve per each cylinder. 16 valve engine.
then theres the 3 valve engines. i "think" they are all SOHC.
Post by: Ether947 on November 04, 2007, 02:10:48 PM
Quote from: shame302;186161
Yeppers. 2 Intake - 1 Exhaust
Post by: King_V on November 06, 2007, 03:15:36 PM
I coulda sworn a recent Hot Rod or Car Craft article had something about putting the 4.6 into fox-bodies and getting it to fit . .  but don't hold me to that . . gotta see if I can dig up the article.
Post by: 32VFoxBird on November 06, 2007, 06:47:28 PM
Quote from: King_V;186438
the 4.6L wasnt a problem. it was the 5.4L that'll test your patience.
Post by: Beau on November 06, 2007, 07:17:04 PM
Forgive my lack of knowledge here...I thought that the 4.6 and 5.4 were roughly identical in size?
About all I know of modular engines is that they share a few parts between them. :hick:
Post by: 32VFoxBird on November 06, 2007, 07:35:48 PM
no, they're not. the block, crank, rods, intake, and timing cover are what separate the two.
4.6L = 281ci
5.4L = 330ci
Post by: King_V on November 06, 2007, 09:55:55 PM
Quote from: 32VFoxBird;186452
Ah . . right, though I was responding to the line about the 4.6 "wasn't going to fit, either"
But the article's dealing with the 4.6 DOHC, and it's in the August 2007 issue of Hot Rod.
However, judging by the one picture of the engine in the engine bay . . well, isn't the 5.4 just a taller-deck version?  It'll be wider, sure... but is the width the issue, or will it simply be hood clearance?  I get the impression from the photo that there might just be enough clearance to fit under a stock hood (they're using an 83 mustang)
Post by: 32VFoxBird on November 06, 2007, 11:24:43 PM
Quote from: King_V;186489
it may fit with EFI. i was saying the 4.6L wasnt going to clear the hood, because i would be using a carb setup.
Post by: King_V on November 07, 2007, 06:51:48 PM
Ah, I see!  Definitely intriguing!
