So I'm swapping over my heads and drop one of my injectore and break the plastic cap on the end :mad: I want to get some 19# injectors can I use them with my factory ECU and sensors?
you could but it would run way rich. you could toun down the fp a couple of psi to compensate but your talking about an adj fpr. you can buy thoes little caps seperate though.
I have extra caps,brand new.If you need one or two,let me know and I'll mail them to you.Otherwise,parts stores around you should have a little set with the cap,a spacer,and two o-rings in a little box.
I'll check into it today, I sell parts, but If I remember correctly we don't sell just the plastic cap so I might need one from ya vinnie.
