is there anything special that i need to do when installing a aftermarket head unit?? also is there any chance of getting a wiring harness adapter so i dont have to cut the wires???
Search?
Scosche wire adapters will work, they can be found at Walmarts. If you have premium sound, look for an additional harness up between the radio, clock, and glovebox as it'll bypass the amp in the trunk. Otherwise, just wire in and go.
