I found the map sensor is toast along with the tps and the egr valve was stuck closed. That explains my troubles getting my thunderous turd running. My question is where is the map sensor located? I have a spare intake laying around that i can swap the sensor out. and also what does it look like? Is it the thing on the side of the throttle body?
In plain view on the firewall..
Ah thank you very much. I could have spent an hour looking for it. Sorry I`m computer illeterate especially with cars. If I had a carb my bird would have been running along time ago
ok i replaced the map sensor and the tps and it keeps saying my tps is out of range. I`m lost
Google adjusting Ford TPS. Or search this forum, the topic has been brought up a few times over the years.
