Technical => Misc Tech => Topic started by: JeremyB on October 07, 2007, 11:13:05 PM
Title: I can see clearly now, the rain has gone... (Headlight Install)
Post by: JeremyB on October 07, 2007, 11:13:05 PM
I got a last minute call from my buddy to go hiking in N. GA last weekend, so I decided to take the T-bird. It would involve driving at night so I also decided to slap in my new headlights that had been awaiting installation for almost a year.
R&R is pretty straightforward.
My old headlights were quite yellowed, as you can see in the pictures. The difference between the old/new set is beyond amazing. High beams with the old pieces were noticeably less bright than std. beams with the new ones. On the way over to Atlanta, I put the high beams on and a lil' pee came out from the excitement.
Intermediate bracket.
The three adjuster pieces go into the back of the headlight. There are 4 studs on the opposite side that interface with the chassis.
(http://www.griffshp.com/belchja/forums/headlights/headlight 010_r.jpg)
This is what happens when you mess with 20 year old plastic. I need new adjusters.
Two of the studs can also be seen.
(http://www.griffshp.com/belchja/forums/headlights/headlight 014_r.jpg)
Don't think it is supposed to look like that.
The three slots are for the adjuster pieces.
(http://www.griffshp.com/belchja/forums/headlights/headlight 018_c_r.jpg)
(http://www.griffshp.com/belchja/forums/headlights/headlight 012_r.jpg)
(http://www.griffshp.com/belchja/forums/headlights/headlight 013_c_r.jpg)
(http://www.griffshp.com/belchja/forums/headlights/headlight 002_c_r.jpg)(http://www.griffshp.com/belchja/forums/headlights/headlight 021_c_r.jpg)
Are the adjusters long or short?
E7SZ-13032-D HEADLIGHT ADJUSTER SHORT
E7SZ-13032-C HEADLIGHT ADJUSTER LONG (http://"http://foxtbirdcougarforums.com/showpost.php?p=123077&postcount=7")
Anybody know where I can get NOS outers?
Post by: mjbtbrd on October 07, 2007, 11:56:10 PM
you need 1 short and 2 long per side  if memory serves me
you can also use help brand #'s
42151 headlight  adjuster  long
42152 headlight adjuster short
nos right outer on ebay:  http://cgi.ebay.com/ebaymotors/NEW-Thunderbird-Cougar-OE-Parking-Light-Lamp-Right-1987_W0QQcmdZViewItemQQcategoryZ33710QQihZ001QQitemZ110170153211QQtcZphoto
Post by: 88BlueBird on October 08, 2007, 10:46:18 AM
Looks good! Where did you get the new headlights from?
Post by: thunderjet302 on October 08, 2007, 12:46:04 PM
Looks good. I like the wheels too :D
Post by: EricCoolCats on October 08, 2007, 01:24:23 PM
:rollin:
Post by: Cougar5.0 on October 08, 2007, 02:29:44 PM
I just did this a few weeks back before the Fun Ford Weekend. I replaced every light in the front except the elusive drivers-side corner light (5 new pieces). I noticed the requirement to loosten the inner light to get the headlight out.
One thing I discovered after ruining the adjuster plastic (as you show there) the first time I did this (after polishing the old head-lights) is that you can use a single-edge razor to cut the lock-ramps off of the old headlight. These "ramps" only let you assemble the headlight, but they are not designed to be reversed and efforts to lift the tab before attempting the 90 deg. rotation will usually only result in a broken locking tab. If you slice the lock-ramps off, you can carefully un-key the locks by rotating -90 degrees. No guarantee you can save the old locks anyway, but I was able to reuse mine.
Post by: ipsd on October 09, 2007, 11:09:13 AM
Quote from: JeremyB;181431
That made me laugh so hard that I had to pick my self up off the floor.
Those light sure do make a BIG difference. you need to clean the inners and outers. Get some fine steel wool use that and then go over them with some tire wet.
Post by: JeremyB on October 09, 2007, 11:33:52 AM
Quote from: 88BlueBird;181478
Headlight Warehouse (http://"http://headlightwarehouse.com/")
Quote from: ipsd;181654
How long does the shine last? 5-10 years? I'd like a solution that is set it, and forget it.
Post by: turboranger91 on October 09, 2007, 12:58:04 PM
looks really good.  i got lucky in the fact that the previous owner of my car already replaced them for me.:hick:
Post by: 88turbo on October 09, 2007, 05:38:03 PM
I think you got jipped alittle on those,  you can get a pair on ebay for about $130
Post by: JeremyB on October 09, 2007, 06:11:42 PM
Quote from: 88turbo;181689
I'll pay an extra $20 to keep from using Ebay.
Post by: mjbtbrd on October 09, 2007, 08:14:43 PM
Quote from: JeremyB;181697
I wouldn't buy from ebay either.  AFAIK  you can still get them from Ford for 45-55 bucks each.
Post by: JeremyB on October 09, 2007, 08:54:25 PM
Quote from: mjbtbrd;181710
Lenses, yes. Complete assemblies, no.
Post by: TurboCoupe50 on October 09, 2007, 09:18:40 PM
Quote from: JeremyB;181656
Actually IF you wax them every few months they should maintain the crystal appearance... The key is don't let them get hazy in the first place...
Post by: JeremyB on October 10, 2007, 12:25:48 PM
The headlight adjusters have been discontinued from Ford. I bought 2 short, and 2 long from fastpartsnetwork.com (That is all they could find in the dealer database).
Also, randomly, the non-ATC blower motor is also unavailable from Ford.
Post by: ipsd on October 10, 2007, 03:09:30 PM
For those adjusters check your local parts store HELP section! I got some for my 94 cougar but I'm sure they make them for the foxes too. I'll see If I can get a part number.
Post by: JeremyB on October 10, 2007, 03:14:49 PM
mjbtbrd gave the HELP! part #s in the 2nd post. I just try and buy Motorcraft parts if at all possible.
I'll pick up the remaining two adjusters from Advance.
Post by: JeremyB on March 13, 2008, 10:38:07 PM
Shortly after the install I noticed my left headlight was dimming. Lo and behold, the sumbitch was leaking and fogging inside. Eventually over 1" of standing water accumulated. Glad I bought new. :mad:
I removed the offending piece and tried to find where it was leaking.
Filling it with water didn't do it.
Sealing the bulb and putting it underwater didn't do it.
My dad pressuring the assembly by blowing in it worked. :confused:
So I went to the local part store and bought some sealant. It seemed to work until last Friday, when I noticed more condensation on the lens. :mad: :mad: Oh well. The original leakage caused damage to the internal finish so I'm just going to buy another assembly. I haven't pinpointed the new leak location, but I'll update when I find it.
Also, you don't want to buy 2 long and 1 short adjuster. You want to be 3 long adjusters. The short adjuster doesn't have a hex head - thus you cannot adjust the assembly correctly.
Post by: jcassity on March 14, 2008, 02:24:14 AM
another great thread.  Did you find the outters as well?
Post by: TurboCoupe50 on March 16, 2008, 08:35:43 AM
For leaking assembly's I've used the RTV, BUT also wrapped with Teflon tape before it set up... Never had one leak again...
Post by: Cougar5.0 on March 16, 2008, 11:14:11 AM
I'm glad I don't drive the car in the rain - that would infuriate me :beatyoass:
I do like my new headlights a lot though! I had some assemblies from the junk-yard lying around so I was able to se together enough adjusters to make do. I used a razor to slice off the ramp that makes removing the adjusters difficult without damaging them (the anti-reverse tab). I sprayed them with penetrating oil and they work almost as good as new!
Not to be a nitpicker, but the term is "gypped" - derived from the Gypsies. It's similar to "Ive been Jewed" - based on old derogatory stereotypes.
