Looking for the bolts that hold the sn-95 caliper mounts to the spindles.
4 bolts in total(2 per side).
Let me know what you have or can find me at a wreckers,thanks.
You mean just the 12MM bolts?
You can just use some 10.9 grade metric ones. I use them all the time. I get them from McMaster-Carr online, but I'm sure you can find someplace "local" to you. 12mm-1.75x??
Is that what they are 12mm 1.75???
How do i know if there 10.9 grade????
Ford want's a rediculis 11.00 dollars a bolt.
Not payin 50bucks for bolts with tax,this is why i need junkyard ones or aftermarket.
Yes, 12mm-1.75. You'll just have to check the length (35mm MIGHT be it). Just measure the thickness of the bracket and the spindle and see what you need.
10.9 grade is fine.
I just paid $17 for that bolt from ford $11.xx + $4.50 shipping + tax. :rolleyes:
I got target fixation...
