Technical => Engine Tech => Topic started by: thunderjet302 on September 21, 2007, 02:06:36 PM
Title: 5.0 HO speed density cams
Post by: thunderjet302 on September 21, 2007, 02:06:36 PM
So people don't have to look for this:D  (could make it a sticky)
(http://www.50tech.com/files/sd_cams_137.gif)
Post by: V8Demon on September 21, 2007, 04:20:25 PM
Gee, where'd you get that from:hick:
Post by: ZondaC12 on September 21, 2007, 04:33:55 PM
Now would any of those work with our S.O. stock flat-top pistons? I can never remember what the deal with that was, maybe if this becomes sticky this will be a good FAQ to have re: those cams.
And again I forgot and I wanna know :)
Post by: thunderjet302 on September 21, 2007, 10:11:19 PM
Quote from: V8Demon;177700
http://www.50tech.com ;)
I figured I'd put it up so you and me aren't the only two who know you can stick a cam in a HO speed density engine.
Quote from: ZondaC12;177704
You know I'm not sure. As far as I know no one has tried. Since my engine was rebuilt I have notched flat tops. I think Paul has non-notched flat tops in his and before his curent combo has was running a Crower cam and E5 heads on the same short block.
