Technical => Audio & Other Aftermarket Electronics => Topic started by: hellsing73 on September 13, 2007, 04:01:00 PM
Title: need help
Post by: hellsing73 on September 13, 2007, 04:01:00 PM
i put a cd player in my car and im geting the reave of the motor on the player dose any one know why?
Title: need help
Post by: daboss351 on September 13, 2007, 04:01:49 PM
Your getting what??
Title: need help
Post by: vinnietbird on September 13, 2007, 05:59:29 PM
Do you mean electrical interferance?Did you wire it straight into the harness,or did you use the two plug installation kit (If you didn't use the kit,you should have)?
Title: need help
Post by: atariman on September 13, 2007, 07:07:56 PM
That is the charging system you are hearing(alternator). You can either put a noise filter on there from like radio shack, or do as vinnie says.  I used to have that on a jeep i had, you could hear the change all the way through the gears.
brian
Title: need help
Post by: hellsing73 on September 13, 2007, 10:32:17 PM
how much do the fillters cost
Title: need help
Post by: atariman on September 13, 2007, 10:50:00 PM
Hmmm....I don't know anymore. It has been a looooOOOOooong time since I owned that jeep. But I would bet not over 15 bucks or so. All you do is splice it in the power to your radio and it helps with the charging noise problem. Just go to the shack and ask, they "should" know what you are talking about.
brian
Title: need help
Post by: hellsing73 on September 13, 2007, 11:50:18 PM
ok thx
