Technical => Suspension/Steering => Topic started by: cougarpower51 on September 02, 2007, 10:57:56 PM
Title: Bae brakes
Post by: cougarpower51 on September 02, 2007, 10:57:56 PM
Guys I want to know if the Baer Brake kit for the Mustang would fit for a Cougar V6, I like how that kit looks
(http://i24.ebayimg.com/06/i/000/b3/d1/c35b_1.JPG)
(http://i21.ebayimg.com/04/i/000/b3/d2/0056_0.JPG)
(http://i21.ebayimg.com/05/i/000/b3/d2/0ea2_12.JPG)
Title: Bae brakes
Post by: CougarSE on September 02, 2007, 10:59:20 PM
Not without changine the spindles to sn95's... then it would work fine.
Title: Bae brakes
Post by: cougarpower51 on September 02, 2007, 11:07:22 PM
I was checking a kit and the spindles are included
kit includes :2 piston PBR calipers with lightweight 2 piece, cross-drilled, slotted, and zinc washed rotors.  13" front rotors.  12" rear rotors.  Front brakes are mounted on spindles already and ready to bolt on.  Steel braided lines, front to rear proportioning valve, race fluid, master cylinder, bump steer kit, and dutchman hardened racing axles in stock splines
Title: Bae brakes
Post by: turboranger91 on September 02, 2007, 11:22:38 PM
are the part numbers the same for each car?
Title: Bae brakes
Post by: dominator on September 03, 2007, 10:26:27 AM
Wow that's gonna be expensive and a lot of brakes for a little v6.
Will work though if converted with those parts.
Title: Bae brakes
Post by: *MAYHEM* on September 03, 2007, 05:51:06 PM
Quote from: cougarpower51;174045
Howsabout some info on where to get that kit. I'd be interested in one myself.
Title: Bae brakes
Post by: thundr306 on September 03, 2007, 08:40:25 PM
I have to imagine that is a VERY pricey kit. Also, plan on at least 17" wheels to get over the fronts. Beware of what front spindles they are giving you.
Jim
