General => Lounge => Topic started by: tireshredder on August 15, 2007, 11:17:29 PM
Title: Open freakin' Sesame!
Post by: tireshredder on August 15, 2007, 11:17:29 PM
Ok, there's a new Bird in my local yard, and it has a nice set of tail lights I want to grab.  Problem is, it has no battery and the keys are missing.  I don't want to pry the trunk open, cause it looks decent and  I might want it too.  Any suggestions?
Post by: 84 Fila on August 15, 2007, 11:19:34 PM
Purple w/ yellow wire from the trunk pop soloniod. Run 12V through it and it should pop the trunk
Post by: daboss351 on August 15, 2007, 11:24:57 PM
i figured pounding a screwdriver in the lock might allow you to be able to turn it
Post by: 84 Fila on August 15, 2007, 11:29:26 PM
Mason's right.. if you don't wana use the locks. I did mine with a dill battery when i locked my keys in the trunk before
Post by: ipsd on August 15, 2007, 11:55:44 PM
For just a one or so pop  deal on that little motor you could use a 9v. Either that or you could pull the back seat and get into the trunk and use a flat blade to turn the back side of the latch. That is if the car isn't nasty and bug coated. If you look under the deck lid above the plate area you might be able to get to the clip that holds the lock in. Pull that clip out and the lock slides straight out of the deck lid. I I think those clips are riveted to the deck lid. So pry it off. Look at your car for ideas.
Post by: *MAYHEM* on August 16, 2007, 12:25:19 AM
First get a blow torch and cut a 27.33333" hole (you must be precise here to avoid complications later) up through the gas tank and into the trunk. Now place 8.63 oz (no more, no less) of TNT just behind the trunk latch and secure it with Orangatan glue. (even better than the stuff they get from gorillas) Insert the end of a 30' cordite fuse (You'll need those extra seconds trust me) and uncoil the remainder to a safe place from which to light it. (NOTE: Do not use electronic detonators as they might look suspicious to passers by) Build a small camp fire using a truck rim as a fire ring (think safety here) and drop the free end of the fuse into it.
In a matter of moments the trunk will magically open.
Post by: tc² on August 16, 2007, 12:28:36 AM
+1 mayhem
Post by: grutinator on August 16, 2007, 12:29:09 AM
OMG!:laughing: :bowdown:  WAY TOO FREAKING FUNNY!
Post by: *MAYHEM* on August 16, 2007, 10:22:40 AM
*Bows* Thank you. Thank you. And tomorrow, boys and girls, I'll tell tou how to remove a stuck lugnut using a forklift, a Dragonov rifle, used chewing gum and dog slobber.
Post by: turboranger91 on August 16, 2007, 10:37:02 AM
just bring the battery in from your car.... violla!!
Post by: daboss351 on August 16, 2007, 10:45:04 AM
you need the key in the ignition to use the electric trunk button with a working battery in the car...
Post by: turboranger91 on August 16, 2007, 10:46:59 AM
Quote from: daboss351;169583
booger up the ignition switch with a screwdriver.
Post by: 84 Fila on August 16, 2007, 11:04:28 AM
Ok,, again. Jumper the purple with yelow stripe wire from the trunk botton to a batter or something, then hit the botton. It will pop the trunk. Not the ignition, you don't need it if your bypassing it.
Post by: tireshredder on August 16, 2007, 01:21:28 PM
Thanks for the tips.  I'll try to save the trunk lid, but if it come to it, :beatyoass: .
Might try Mayhem's on a Tempo......:evilgrin:
Post by: softtouch on August 16, 2007, 03:59:56 PM
Doesn't the yard man have a big ring of keys that fit everything?
Fila's solution sounds pretty simple to me.
Post by: SR71TC on August 16, 2007, 04:30:55 PM
^^^^^^^ I like McGiver's idea better.....He failed to mention the tiny strips of tin foil.
Post by: jncocowboyx on August 16, 2007, 04:50:40 PM
Quote from: 84 Fila;169593
+1
9v should work. if not, get a battery booster pack, touch the wires. i've never done it, but it should work.
Post by: Chooglin on August 16, 2007, 06:30:32 PM
Quote from: *MAYHEM*;169536
WOW !!!!..............what an imagination.............that is some funny stuff,I dont care who you are.
Post by: TurboCoupe50 on August 16, 2007, 08:42:07 PM
A thumbed sized 9v battery is about as much underkill, as MAYHEM's cuttin' and blastin' is over the top(sure be fun though)... In other words a battery that can only supply maybe .1a(thats right... A TENTH OF A AMP) has a snowballs chance in Hell of operating the release solenoid...
Just pull the trunk switch out, and apply power to the purple/yellow wire as already suggested... A portable jump box would be perfect... If you don't have one the junk yard probably does... Simple, easy and you've destroyed nothing...
Post by: 84 Fila on August 16, 2007, 08:44:49 PM
I stated that I used a drill battery. I belive 14.4V. It opened it. If not I'm with TC50, the jumper box woeks perfect as well
Post by: TurboCoupe50 on August 16, 2007, 08:48:56 PM
Quote from: 84 Fila;169730
A 14.4 drill battery would be fine as would a 12v, even a fully charged 9v drill battery would probably do it... Just not one of the small smoke detector batteries...
Post by: 84 Fila on August 16, 2007, 08:57:17 PM
Very true. Tried that and it didn't work,lol
Post by: yellow86coogr on August 18, 2007, 01:32:18 AM
My favorite part.
