Technical => Suspension/Steering => Topic started by: quicksilver on August 14, 2007, 02:34:20 AM
Title: bolt pattern?
Post by: quicksilver on August 14, 2007, 02:34:20 AM
i want to by of weld drag lights rims. but i need to know the bolt pattern.
Post by: Innes on August 14, 2007, 02:44:22 AM
Think its 4 ½ or 4 ¼ but when your order tell them it’s the same as a mustang of your year.
Post by: 84 Fila on August 14, 2007, 03:49:19 AM
It would help to know that your going 5 lug or not. If you are it's 5x4.5 and if not it's 4x4.25
Post by: Cad-T-Bird 500 on August 14, 2007, 09:32:13 AM
Here you go http://store.summitracing.com/egnsearch.asp?Ntt=draglite+wheels&N=700+4294923105+4294755964+115&Nao=0&Ntk=KeywordSearch#rstop
With 10 inch wide wheels and the mustang rear I used a 5.5 backspace and it worked well.
I also have a set of 275 mounted on 8 inch wheels but I don't remember the back spacing right now.
TED
Post by: seanamyers66 on September 04, 2007, 02:47:56 AM
For both 4 and 5 lugs the pattern is 41/2
