Hey guys I'm expecting to receive a TC cluster sometime in the mail this week and before it got here I wanted to ask a few questions.
1) How do I size the faces on the website to the correct size? As of now when I print them off they are about 8 inches in diameter.
2) Since I currently have the base cluster how do I run a wire for the tachometer?
are you building a boosted 5.0?
In your print dialog box (assuming it's Acrobat Reader), make sure you UNCHECK the boxes for "Auto Rotate and Center" and "Fit To Page" (or equivalent). This will give you a 100% printout.
Tap onto the dark green/white wire at the ignition coil (+).
Correct wire color, but the polarity is (-).
Yeah, that too LOL.
Thanks guys!. And no it is currently just a NA 5.0 it will be a while before I go ahead and turbo/boost it so I will be eliminating the boost gauge for now.....but later on, much much later on there will be a turbocharged 331 with a viper transmission and cobra independent rear suspension. Right now though I'd be happy with a paint job :bowdown:
Weeeeell tried to open the jpg with adobe and it can't open it sooo any other ideas?
Peel the faces off and scan them? lol thats what I did. I need to make another set for the car. So I may be able to do that to help ya out.
How soon do you need the faces?
I need them eventually but right now I don't have even have the buttstuffogue cluster so no sweat. Still though I'd like to go 140mph so I need to figure out hows to print these up. bleh
Yeah Um problem here... Acrobat reader won't open jpg. files. So how exactly do I manage to print these bad boys off?
You can open JPG files in a web browser...make sure the auto-resize option is turned OFF for the browser.
Auto resize is turned off in the browser, and I saved the image as a PDF and went to print it out in Adobe and I still get a printed image twice as big as I need it. :punchballs: :punchballs: :punchballs: :punchballs:
