General => Lounge => Topic started by: oldraven on August 06, 2007, 10:11:47 AM
Poll
Question: What took the ol' TC down for the past month?
Title: The car is running again
Post by: oldraven on August 06, 2007, 10:11:47 AM
So who here can guess what simple and stupid thing I missed when I went over the engine bay over a month ago?
After fixing the problem I drove it to our new house, down the highway. The first time the TC has ever stretched its legs on a real winding, rising, dipping, Nova Scotia highway, and it ate the 316 right up. I humbled a blindingly yellow late model Z24 and scared a few joggers too.
Post by: TurboCoupe50 on August 06, 2007, 10:18:50 AM
Don't remember the original problem, but it's good to hear the Bird is flying again...
Post by: turboranger91 on August 06, 2007, 10:27:07 AM
i don't know what the problem was, but i can tell you that my 85 sat for a month because i couldn't figure out what was wrong with it after a head gasket swap.  got it all buttoned up, and timed, and no fire.  turns out that i never adjusted the distributor when i was setting the timing... it was WAAAAAAaaaaaaaayyyy off.  haha!
Post by: oldraven on August 06, 2007, 10:32:50 AM
Thanks Tom.
It couldn't idle, kept falling on its face, but would run with throttle holding it at about 2500. Once you started moving it would run smooth until 2000, then it would buck like mad, spitting black smoke, and couldn't rise above 3000. If I shifted early it would run right again, up until 2000.
Post by: turboranger91 on August 06, 2007, 10:39:56 AM
sounds like your timing is off... well, was off.
*edit*  just saw the poll.
Post by: CougarSE on August 06, 2007, 10:47:34 AM
Oh you didn't give us a silly option :(  I don't remember it originally not running so I duno.
Post by: oldraven on August 06, 2007, 10:58:10 AM
Is it too late to add a silly option? :(
*edit*
Yes it is. :P
My brother in law (who gave the old bird cheap rent this month) said he saw a chipmunk run up into my engine bay once or twice.
Post by: TurboCoupe50 on August 06, 2007, 11:02:10 AM
OK I voted...
Post by: oldraven on August 06, 2007, 11:20:35 AM
I think I know what Tom Voted. And he'd be right.
It's kind of a trick question. One option causing the other.
Post by: turboranger91 on August 06, 2007, 11:22:41 AM
so an intercooler hose popped off?  you couldn't hear the boost leak?  upper or lower?
Post by: oldraven on August 06, 2007, 12:18:25 PM
Upper. And I couldn't hear anything but 'BAAAH-BUPBUPBUPBUP-BAAAAH-BUPBUPBUPBUP'
After having the knock sensor go off a couple of times at 18psi I decided to 'turn the boost' all the way down to keep from hurting anything. So I turned the screw in all the way. I drove it again and I was getting full boost, but it fell on its face when I parked it at the in-laws. A quick look around and I saw nothing wrong (yes, I missed something obvious), but started thinking about the spring and ball berring and realised I'd cranked the boost rather than dropped it.
The nut holding the IC bracket was barely on the thread, so when it overboosted that last time it must have pushed the IC far enough away from the TB to get free.
The VAM was reading no air, so it wouldn't idle, but if I forced it the turbo spooled (but not boosted) enough to suck the VAM open.
Funny how it all makes sense after the fact. :P
Post by: turboranger91 on August 06, 2007, 12:25:44 PM
on the gillis valves, turning the screw clockwise will increase boost... but it looks like you figured that out.
as far as the intercooler bracket goes... take it off.  you don't need it and those bolts back out all the time, causing the knock sensor to do funny things.
from now on, anytime your car is down on power, check for boost leaks first.  it'll save you a lot of down time.
Post by: oldraven on August 06, 2007, 01:33:36 PM
I'd rather get a thread locker on that stud than remove the bracket. Had it been tight, the hose never would have let go.
