Technical => Electrical Tech => Topic started by: fordthunderz92 on July 31, 2007, 12:11:02 AM
Title: newbie needs some help
Post by: fordthunderz92 on July 31, 2007, 12:11:02 AM
Hi,
Got a 1992 cougar LS with 3.8L and need a few tips. I ain't that great with electrical issues so heres my problem.
When I turn the key I get all the ignition lights on the dash but the starter doesn't work. If I take the negative cable off for 3 to 5 seconds and put it back on the starter works fine. after I shut the car off for a few minutes I get no starter again so I go through the process of taking the cable off and putting it back on, then it works.
I tried new cable clamps and a different battery and still the same symptoms.
solenoid? bad ground? bad starter?
Any feedback is greatly appreciated!
Thanks
Title: starter issue
Post by: fordthunderz92 on July 31, 2007, 11:34:50 AM
I guess what I'm asking is by pulling off the neg cable am I resetting something having to do with the starter circuit?
Thanks
JR
Post by: atariman on July 31, 2007, 11:45:21 AM
Check all grounds? Make sure good and clean. Solenoid is cheap to replace...Starter can be removed and checked at any parts store. Hope this helps!
:birdsmily:
Post by: jcassity on July 31, 2007, 11:12:55 PM
you have to do what,,,,,,,,for how long,,,,,,, for how many cookies!
ive never seen that problem but ill tell you where id start.
Tap on the starter solenoid prior to starting next go around.
Does this problem seem to effect your battery charge?
Title: starter trouble
Post by: fordthunderz92 on August 01, 2007, 09:19:19 AM
Its the est thing I ever came across, usaully when the solenoid quits it just quits. You have to take them apart and clean the contacts. These new style solenoids are different looking than the old and don't seem repairable.
It does not affect battery power or cause a drain on the battery.
The starter is fairly new, not to say it couldn't be bad.
With these computer controlled engines, all the sensors and relays I was just wondering if they had anything to do with it being how when I shut the electricity off it seems to work fine till it sits awhile.
I guess I'll try the basics first and hope for the best.
Thanks for the feedback
JR
Post by: CougarSE on August 01, 2007, 09:23:37 AM
Solenoids are also like $7.
Post by: jcassity on August 01, 2007, 09:42:04 AM
the only thing i can think of compared to the way you are thinking might be a relay contact sticking instead of relasing contact when the key is turned off.
Several relays come to mind but the start circuit does not have one of those smaller relays.,,, just the starter solenoid (relay).
tap on the solenoid,, next bang on the starter (highly unlikely the way you describe the problem).
Post by: jcassity on August 01, 2007, 09:43:49 AM
wait a min,,,,,,,,, this is an mn12 car,,,,,,,
i may be totally wrong on what i have said.  I have no experiece on thie wiring harness in this car.
Post by: ZondaC12 on August 01, 2007, 10:55:01 AM
Quote from: jcassity;165175
quote]
ya or maybe some "heat overload protection" thingy? it seems like EVERYTHING these days has something like that and theyre often WAY too touchy.
Post by: softtouch on August 01, 2007, 05:45:55 PM
After reviewing my '01 Crown Vic/Grand marquis EVTM (the only thing newer then the fox's that I have) I don't see anything that would be reset by disconnecting the negative battery cable.
Trace the battery cable to where it connects to the engine block. Make sure it is tight. Maybe just moving the cable makes it reconnect just long enough for one more start.
Does the car have any after-market anti-theft devices that may disable the start circuit?
The Grand Marquis has the starter solenoid as part of the starter motor. A start relay picked by the ignition switch, picks the starter solenoid.
Is that what your '93 has?
Are you up for trying to trouble shoot it with a volt meter?
Post by: dudeman351 on August 01, 2007, 10:25:27 PM
do you think it has something to do with the brake pedal and having to push it to start the car?
Post by: t.birdsc on August 01, 2007, 10:37:16 PM
A few questions 1st if you don't mind?
From the factory:
Is the vehicle supercharged?
Is the vehicle an auto or stick?
Does the vehicle have abs?
Does the vehicle have theft deterent?
Are there any aftermarket devices on the vehicle?
Most important, when the vehicle acts up does the starter relay click?
Post by: jcassity on August 02, 2007, 12:22:08 AM
Quote from: dudeman351;165372
humm,, :bowdown:
whos our local mn12 guru?
someone here has these cars nailed down real well.
Post by: ipsd on August 02, 2007, 12:36:08 AM
I just went out and checked. My 94 cougar I don't have to press the brakes pedal to start it. Not sure on the older ones.
Post by: t.birdsc on August 02, 2007, 01:26:59 AM
Make certain the vehicle is in neutral for a manual trans. or park for an automatic and the parking brake fully engaged.
Trace the positive battery cable to the starter relay which is bolted to the fender skirt. Make sure the relay is secure and the metal bracket its bolted to is clean and tight. It is case grounded.
If the problem persists, when the vehicle is acting up, locate the red with a blue stripe pigtail wire going to the starter relay. Disconnect this wire and use a jumper wire(a remote starter switch is ideal) to jump the relay terminal to the pos. battery terminal. If the vehicle cranks then you have an issue with the igniton switch or starter circut. This simple test will give us more info for additonal diagosis.
Title: starter circuit
Post by: fordthunderz92 on August 05, 2007, 09:36:55 PM
I did the test as t.birdsc stated and the starter cranked. I did install a new solenoid and new neg cable to ground and positive cable to solenoid from the battery. With the test being done I assume the iginition switch is not getting power the solenoid all the time. Once in awhile it works okay but most times there is a problem.
Thanks for all the help!
JR
Post by: t.birdsc on August 06, 2007, 12:44:19 AM
Yes, if the vehicle was definately acting up when you "hotwired" the relay as stated earlier and it did crank, then we know it is a problem with the feed going to the starter relay from the ignition switch/crank circut. Just to verify, it would be a good idea to see if it cranks normally with the key after you tried the "hotwire". If it still acts up and doesn't crank, we can diagnose that part of the circut then.
Post by: t.birdsc on August 06, 2007, 12:45:53 AM
Quote from: t.birdsc;165378
From the factory:
QUOTE]
The answer to these questions can help also.
Post by: fordthunderz92 on August 06, 2007, 07:40:05 AM
It did not crank after the test with the key.
not supercharged
automatic transmission
has abs
no anti theft
no aftermarket devices
Title: Problem with trigger wire on what side of neutral switch?
Post by: t.birdsc on August 06, 2007, 08:49:54 PM
Quote from: fordthunderz92;166342
I am assuming the r/lb wire was hooked back up to the relay when retested. If so, good, then we know your starting system is good and there is a problem in the trigger circut going to the relay.
What is very strange about the problem is the fact the engine won't crank unless you remove the ground wire. A good idea would be to pull codes from the eec and abs modules. If you can do this record the codes so we can see if any pertain to the starting system concern.
 Instead of backtracking the harness from the relay to the ignition switch, we will pick a halfway point which is the neutral safety switch.
 You may need a helper for this test and also a test light. Locate the neutral saftey switch which is on the left side of the transmission case around the manual shift lever. There will be the r/lb wire going into it from the ignition switch. This wire should be hot(12v) during crank. The best way to check it would be when the vehicle is acting up, ground the test light, unplug the neutral switch and probe this wire for 12volts while someone cranks the engine. If you have to do it yourself, back probe the connector with a small hat pin and use alligator clips to your test light. If this wire shows 12 volts, plug the connector back in and reverify the no crank with the key. If no crank with the key continues, check the w/pk wire coming out of the neutral switch for power with the connector plugged in, or jump the r/lb wire to the w/pk wire. IMPORTANT!!!! REMEMBER, if you decide to jump this connector make absolutely certain the vehicle is in park and the parking brake is on. I'd rather you back probe the w/pk wire but the choice is yours.
 This test will show us what side of the neutral saftey switch the feed problem is , or possibley a bad neutral switch. Neutral switches are notorious for being out of adjustment and often need replacement along with the connector. If you have power in crank across the neutral switch from the r/lb wire to the w/pk wire in neutral or park, then the neutral switch should be good. If that happens and the vehicle still won't crank, we know the problem is between the neutral switch and the relay. Or if there is no power to the r/lb wire in crank, the trigger problem would be on the ignition side of the neutral sw.
 Once you perform these tests, the results will allow us to diagnose further.
Hope this helps,
    Mike
Post by: fordthunderz92 on August 07, 2007, 08:15:49 AM
This is just to wierd, I ran the test and no power to the neutral switch r/blue wire. I pulled the neg cable off for 5 seconds and reconnected, ran the test again and got power to the r/blue wire. I plugged it back to the switch and tried to start, nothing. Pulled the neg cable as always and the car started.
Post by: t.birdsc on August 07, 2007, 10:42:45 PM
Quote from: fordthunderz92;166755
 I agree it is very strange, but at least we know it is a feed problem on the ignition switch side of the neutral switch.
Post by: t.birdsc on August 07, 2007, 10:54:22 PM
Check and see if you have a feed from the ignition switch, at the ignition switch, on the r/lb wire during crank. I would back probe it 1st, if nothing then take the ignition switch connector off. I believe its either 9/32th's or 5/16th's, try to take that terminal/wire out of the connector. Plug the ignition switch connector back on and probe the terminal on the ignition switch, at the ignition switch terminal, for a feed during crank. Another alternative would be to cut the wire in half, if you make certain the cut is thoroughly repaired after you check the ignition switch side of the wire. The results will determine if your ignition switch is good or not.
Post by: t.birdsc on August 07, 2007, 11:09:54 PM
I am assuming that the neutral saftey switch connector was unplugged when you did this test??
Post by: fordthunderz92 on August 08, 2007, 06:57:04 AM
yes it was unplugged. Well I guess I'll go out and check the ignition switch. Thanks for the help!
Post by: fordthunderz92 on August 08, 2007, 09:40:09 AM
Well now, after getting to the ignition switch, I learned that a prior owner had installed an aftermarket keyless remote system tucked up under the dash, needles to say that was the cause of the problem. For whatever reason the r/ltblu wire runs thru the remote system, which I assume is to auto lock the doors after start up. A simple jumper wire did the trick and the remote still locks and unlocks the doors.
Thanks Mike for all the feedback it was very helpful!
JR
Post by: t.birdsc on August 08, 2007, 09:38:16 PM
Glad you found it!
Title: On 2nd thought...
Post by: t.birdsc on August 08, 2007, 09:48:11 PM
Did the vehicle come with any remote fobs? OR. There might be a disarm switch or valet switch going to the aftermarket module. Some of the switches are to momentary grounds but ultimately depends on the system. It is possible that the system may be designed to "kill" the starter as an anti-theft device. Trace some of those wires and you may find something, however, if the unit is malfunctioning ,you may have done all you needed to do.
Post by: fordthunderz92 on August 10, 2007, 07:51:22 AM
The system has key fobs and I saw a terminal labeled disarm on the control box but there is no wire to it. The car seems to be fine and the starter works everytime with the key.
