Technical => Engine Tech => Topic started by: quicksilver on July 29, 2007, 07:13:24 PM
Title: new TB, need help!
Post by: quicksilver on July 29, 2007, 07:13:24 PM
i bought a explorer TB and how do you get that nozzle thing pointed the other directions to hook up with my valve cover hose?
Post by: vinnietbird on July 29, 2007, 07:44:49 PM
I put a pair of vice grips on it side ways (Horizontal with the upper bent part),and not to tight,just snug.GENTLY turn the tube.You may want to put a little WD-40 on first.The tube is just pressed in.I haven't had one break yet.Be gentle.
Post by: vinnietbird on July 29, 2007, 07:45:26 PM
Oh,did you swap the throttle cable arm yet?
Post by: quicksilver on July 29, 2007, 10:20:19 PM
swap the throttle cable arm?
Post by: vinnietbird on August 01, 2007, 01:41:35 PM
Yes,the little arm on thebottom that the throttle cable and cruise cable hook to.It has to be changed with the one you have on your current throttlebody.You'll see where the factory did a little "weld" in the middle of the arm to hold it on to the shaft.If you GENTLY grind it down flush with the arm,you can just slip the arm off of the shaft,then,when both arms are removed,put the T-Bird arm onto the Explorer shaft and add a little tack weld.All done.If it is more than you want to deal with,send them to me with $6.00 shipping money and I'll do it.If you don't want to have your car down,find an extra throttlebody and use it for the arm.Needs to be from a Cougar,Stang or T-Bird 5.0.If I can help in any way,let me know.I've done the swap 3 times myself.
Post by: quicksilver on August 01, 2007, 07:16:21 PM
i just bought a cobra intake manifold and and 65mm FRPP TB, so im just going to use that, i'll give you the explorer 65mm tb if you want it. but thanks for the help!!
Post by: daboss351 on August 01, 2007, 07:27:15 PM
give??? im interested!
Post by: vinnietbird on August 01, 2007, 08:31:43 PM
Send me a PM on how much.Let's deal.
