Technical => Suspension/Steering => Topic started by: turboranger91 on July 25, 2007, 05:09:57 PM
Title: i've never jacked with tc suspension....
Post by: turboranger91 on July 25, 2007, 05:09:57 PM
what do we use to lower these cars, or at least stiffen up the suspension so it handles a bit better?
Post by: gumby on July 25, 2007, 08:44:45 PM
shocks, struts, springs, and a search button :beatyoass:
Post by: blu84302 on July 25, 2007, 08:49:07 PM
CHE Control arms and ford racing lowering springs...
Post by: 84 Fila on July 25, 2007, 08:50:13 PM
:bowdown: FRPP Springs
Post by: blu84302 on July 25, 2007, 08:54:30 PM
I just said that... why the double post!  POST W!!!11!1ELEVEN!
Post by: Ifixyawata on July 25, 2007, 09:08:04 PM
Quote from: blu84302;163411
To up the post count so he can be smarter than you.
Post by: Ether947 on July 25, 2007, 09:23:20 PM
The search button is broke!
Here's a good place to get your feet wet.
http://www.coolcats.net/tech/advanced/suspension.html
Post by: 84 Fila on July 25, 2007, 09:25:58 PM
I posted less then a min after you?
Post by: Cad-T-Bird 500 on July 25, 2007, 09:25:59 PM
Don't we have to know what year to give this guy a good answer?
TED
Post by: gumby on July 25, 2007, 09:56:00 PM
Quote from: Ether947;163419
awe. take away all my fun :hick:
josh, check here (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=62") too.
TED, his car will be an 87-88 as soon as he goes and gets it.
edit* i got some decent hits (http://"http://www.foxtbirdcougarforums.com/search.php?searchid=240088")
Post by: blu84302 on July 25, 2007, 10:49:40 PM
All i have to say is.... FTW. :D
Post by: *MAYHEM* on July 25, 2007, 11:08:03 PM
ROFLMAO!
Post by: turboranger91 on July 26, 2007, 11:21:16 AM
:shakeass: i'm an idiot.  i swearsss i'm not a noob :punchballs: now that the :flame: is done.... what shocks do you guys recommend for our cars?  what brand is better suited then others?  i know that on the sho's the kyb's suck, but they're a good quality shock, just not on that car.  which one's work well for the tc's
Post by: slamedcat on July 26, 2007, 11:32:10 AM
Since its an 87 88 TC you have a limited selection due to the ride control stuff.
If you wanted to just ditch the ride control I would search ebay for a set of Koni shocks and struts.
Post by: gumby on July 26, 2007, 04:07:58 PM
i havent run any performance shocks/struts on a tbird, yet. i can make comparisons to sn95 cars though. tokico, koni, and bilstein are all nice when properly matched with the spring rate.
my car has factory 04 Cobra bilsteins on it. but i havent driven it yet to evaluate them.
[SIZE="1"]pssssst, josh. Ether947 is sellin a set of FRPP tbird springs in the classifieds....[/SIZE]
Post by: *MAYHEM* on July 26, 2007, 04:18:32 PM
I got a complete set of Koni Sport springs. Supposed to lower it 1.5". Rear rates stay the same, fronts are 420lbs/in. or about 110lbs stiffer.
Post by: Kitz Kat on July 26, 2007, 05:03:58 PM
use the above post it will help or really mess you up.
