Technical => Misc Tech => Topic started by: GrannysBird on July 21, 2007, 01:46:15 PM
Title: Brake lines 11inch conversion
Post by: GrannysBird on July 21, 2007, 01:46:15 PM
Hey guys I'm currently in the middle of an 11 inch front brake conversion and what I wanted to find out was if I can go ahead and use stainless mustang lines since I'm using mustang calipers.
Post by: dudeman351 on July 24, 2007, 07:37:10 AM
yes you can but you need an adapter. i know its readily available at napa but i can't remember what size. try a search i saw it a while back or maybe someone will chime in. good luck.
Post by: 1badcougar on July 25, 2007, 10:16:02 AM
I used napa p/n. 7818 master cylinder adapter 1/4" inverted male to 3/16" inverted female onm the drivers side only. I used the 87-88 tc brake hoses.
Here is the link to my thread: http://www.foxtbirdcougarforums.com/showthread.php?t=12780&highlight=TC+ROTORS (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=12780&highlight=TC+ROTORS")
Hope this helps.
