Technical => Engine Tech => Topic started by: Fnkystuf on July 18, 2007, 01:42:59 AM
Title: gasket set for turbo 2.3
Post by: Fnkystuf on July 18, 2007, 01:42:59 AM
Hello, I need a gasket set for an IHI turbo from an 87 turbo coupe. Anyone know where to get a set?
If I have to buy an entire engine gasket set to get it, that would be ok too.
Post by: ipsd on July 18, 2007, 09:11:23 AM
If you need the gaskets to take apart the turbo you need to got a turbo shop. If you want the gaskets to bolt up a new turbo you can get those from Fel-pro. Can't remember the fel-pro number.
