I need a CHEAP 1989 and up Thunderbird IRS differential cover asap.
Got one....doesn't work.
What's the difference between the IRS and the Live covers?
IRS covers have the differential mount cast into them.
vinnie, what were you attemping, and why didnt it work?
The cover from a T-Bird/Cougar (with an IRS) has mounting holes cast into the back of the cover (in the middle) for the support bracket,and if you remove them,it'll leave a hole in the back of the cover,and if you leave the rear end support intact,the swaybar will hit it.
i coulda saved you whatever $$ you paid for the IRS cover(not much i ASSuME). :punchballs:
you post here made me recall a mod, so i posted about it lastnight. check it out
http://www.foxtbirdcougarforums.com/showthread.php?t=14909
I read that this morning.Fila got a cover for me and is going to send it to me asap so i can finsh the rear for my car.I'm going to install the T-Bird axles and brakes in it (The Stang rear) so I can get it into my car quick.There were no Explorers when I went to the yard.Otherwise I would've snagged one.
P.S.,thanks again Fila.
an explorer cover?
if so, cool. lets see pics when you get it all together :hick:
Will do.
